ME6203A100PG
ME6203A100PG
    MICRONE(南京微盟)
    SOT-89-3
    10V 100MA 40V
ME6203A100PG 数据手册
ME6203 High Input Voltage LDO Linear Regulators ME6203 Series General Description Features ME6203 series are low-dropout linear voltage  High output accuracy: regulators with a built-in voltage reference module, error ± 1%(VOUT =3.3V、5.0V、10V) correction module and phase compensation module. ±2%(Others) ME6203 series are based on the CMOS process and  Input voltage:up to 40 V allow high voltage input with low quiescent current. This  Output voltage:1.8V ~ 12V series can deliver 100mA output current and allow an  Ultra-low quiescent current (Typ.= 3 µ A) input voltage as high as 40V.This series has the  Output Current:IOUT = 100mA (When VIN = 5.5V and VOUT =3.3V) function of internal feedback resistor setting from 1.8V to 12V. There are two output accuracy levels: ±1%  Short-circuit Current:(Typ.= 20mA) (VOUT = 3.3V, 5.0V, 10.0V) and ±2% (other voltage  Low temperature coefficient values).  Ceramic capacitor can be used Typical Application Package  Electronic weighbridge   SCM  Phones, cordless phones  Security Products  Water meters, power meters 3-pin SOT89-3 、SOT23-3 、TO92 Typical Application Vin Vout ME6203 Vss RL 10uF 10uF Suggesting : The circuit uses the electrolytic capacitors or tantalum capacitors in the best ,when it is applied in the high input voltage. V10 www.microne.com.cn Page 1 of 13 ME6203 Selection Guide ME 62 03 X XX XX G Environment mark Package M3:SOT23-3 P:SOT89-3 T:TO92 Output Voltage Version or Function Product Type Product Series Microne product series product description ME6203A18M3G VOUT =1.8V±2%;Package:SOT23-3 ME6203A18PG VOUT =1.8V±2%;Package:SOT89-3 ME6203A25M3G VOUT =2.5V±2%;Package:SOT23-3 ME6203A25PG VOUT =2.5V±2%;Package:SOT89-3 ME6203A30M3G VOUT =3.0V±2%;Package:SOT23-3 ME6203A30PG VOUT =3.0V±2%;Package:SOT89-3 ME6203A33M3G VOUT =3.3V±1%;Package:SOT23-3 ME6203A33PG VOUT =3.3V±1%;Package:SOT89-3 ME6203A33TG VOUT =3.3V±1%;Package:TO92 ME6203A36M3G VOUT =3.6V±2%;Package:OT23-3 ME6203A36PG VOUT =3.6V±2%;Package:OT89-3 ME6203A36TG VOUT =3.6V±2%;Package:TO92 ME6203A44M3G VOUT =4.4V±2%;Package:SOT23-3 ME6203A44PG VOUT =4.4V±2%;Package:SOT89-3 ME6203A50M3G VOUT =5.0V±1%;Package:SOT23-3 ME6203A50PG VOUT =5.0V±1%;Package:SOT89-3 ME6203A50TG VOUT =5.0V±1%;Package:TO92 ME6203A100M3G VOUT =10.0V±1%;Package:SOT23-3 ME6203A100PG VOUT =10.0V±1%;Package:SOT89-3 NOTE: If you need other voltage and package, please contact our sales staff。 V10 www.microne.com.cn Page 2 of 13 ME6203 Pin Configuration 3 1 2 1 1 2 3 3 SOT-89-3 TO-92 2 SOT23-3 Pin Assignment Pin Number Pin Name Functions 1 VSS Ground 2 3 VIN Power Input 3 2 VOUT Output SOT89-3 / TO92 SOT23-3 1 Block Diagram V10 www.microne.com.cn Page 3 of 13 ME6203 Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 40 V Output Current IOUT 150 mA Output Voltage VOUT Vss-0.3~VIN +0.3 V SOT23-3 Power Dissipation SOT89-3 Thermal resistance 0.54 PD 1.25 TO-92 0.83 SOT23-3 230 SOT89-3 θJA TO-92 W ºC /W 100 150 Operating Ambient Temperature Range TOPR -40 ~ +85 ℃ Storage Temperature Range TSTG -55 ~ +150 ℃ Maximum junction temperature TJ -40 ~ +150 ºC Lead Temperature Tsolder 260℃,10sec Electrical Characteristics ME6203A18(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+3.7V 100 Load Regulation ∆VOUT VIN= VOUT +3.7V, 1mA≤IOUT≤100mA 30 Dropout Voltage (Note 3) VDIF IOUT =100mA 3.7 Supply Current ISS VIN= VOUT +2V 2.0 4 μ A Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V 0.03 0.1 %/V Short-circuit Current ISHORT VOUT=VSS 20 40 mA Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT =10mA -40℃≤Ta≤85℃ 80 IOUT=10mA 3.0 mA 60 mV V ppm/℃ ME6203A25(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max V10 Conditions IOUT=10mA Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V 40 V 3.0 VIN= VOUT+3.0V www.microne.com.cn 100 mA Page 4 of 13 ME6203 Load Regulation ∆VOUT VIN= VOUT +3.0V, 1mA≤IOUT≤100mA 32 Dropout Voltage (Note 3) VDIF IOUT =100mA 3.0 Supply Current ISS VIN= VOUT +2V 2.5 4 μ A Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V 0.02 0.1 %/V Short-circuit Current ISHORT VOUT=VSS 20 40 mA Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT =10mA -40℃≤Ta≤85℃ 80 60 mV V ppm/℃ ME6203A30(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+2.5V 100 Load Regulation ∆VOUT VIN= VOUT +2.5V, 1mA≤IOUT≤100mA 30 Dropout Voltage (Note 3) VDIF Supply Current ISS VIN= VOUT +2V Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V Short-circuit Current ISHORT Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT=10mA 3.0 mA 60 mV IOUT =10mA 0.25 V IOUT =50mA 1.2 V 3 4 μ A 0.02 0.1 %/V VOUT=VSS 20 40 mA IOUT =10mA -40℃≤Ta≤85℃ 80 ppm/℃ ME6203A33 (VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.99 VOUT (T) (Note 1) X 1.01 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+2.2V 100 Load Regulation ∆VOUT VIN= VOUT +2.2V, 1mA≤IOUT≤100mA 30 Dropout Voltage (Note 3) VDIF Supply Current ISS V10 IOUT=10mA 3.3 mA 60 mV IOUT =10mA 0.22 V IOUT =50mA 1.1 V VIN= VOUT +2V www.microne.com.cn 3 4 Page 5 of 13 μ A ME6203 Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V Short-circuit Current ISHORT Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa 0.04 0.1 %/V VOUT=VSS 20 40 mA IOUT =10mA -40℃≤Ta≤85℃ 80 ppm/℃ ME6203A36 (VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+2.2V 100 Load Regulation ∆VOUT VIN= VOUT +2.2V, 1mA≤IOUT≤100mA 30 Dropout Voltage (Note 3) VDIF Supply Current ISS VIN= VOUT +2V Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V Short-circuit Current ISHORT Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT=10mA 3.6 mA 60 mV IOUT =10mA 0.20 V IOUT =50mA 1.0 V 3 4 μ A 0.02 0.1 %/V VOUT=VSS 20 40 mA IOUT =10mA -40℃≤Ta≤85℃ 80 ppm/℃ ME6203A44(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+2.0V 100 Load Regulation ∆VOUT VIN= VOUT +2.0V, 1mA≤IOUT≤100mA 31 Dropout Voltage (Note 3) VDIF Supply Current ISS VIN= VOUT +2V Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V Short-circuit Current ISHORT Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa V10 IOUT=10mA 4.4 mA 60 mV IOUT =10mA 0.17 V IOUT =50mA 0.82 V 3 4 μ A 0.02 0.1 %/V VOUT=VSS 20 40 mA IOUT =10mA -40℃≤Ta≤85℃ 80 www.microne.com.cn ppm/℃ Page 6 of 13 ME6203 ME6203A50(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.99 VOUT (T) (Note 1) X 1.01 V 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+2.0V 100 Load Regulation ∆VOUT VIN= VOUT +2.0V, 1mA≤IOUT≤100mA 33 Dropout Voltage (Note 3) VDIF Supply Current IOUT=10mA 5.0 mA 60 mV IOUT =10mA 0.13 V IOUT =50mA 0.68 V ISS VIN= VOUT +2V 3.3 4.5 μ A Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V 0.03 0.1 %/V Short-circuit Current ISHORT VOUT=VSS 25 40 mA Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT =10mA -40℃≤Ta≤85℃ 80 ME6203A100 ppm/℃ (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted)) Parameter Symbol Conditions Min. Typ. Max. Units X 0.99 VOUT (T) (Note 1) X 1.01 V 10.0 - 40 V Output Voltage VOUT(E) (Note 2) Input Voltage VIN Maximum Output Current IOUT _max VIN= VOUT+1.5V - 100 - mA Load Regulation ∆VOUT VIN= VOUT +1.5V, 1mA≤IOUT≤100mA - 20 60 mV Dropout Voltage (Note 3) VDIF IOUT =10mA - 0.09 - V IOUT =50mA - 0.45 - V Supply Current ISS VIN= VOUT +1.5V - 5 7.5 μA Line Regulations ΔVOUT ΔVIN  VOUT IOUT =1mA VOUT +1V ≤VIN≤40V - 0.02 0.1 %/V Short-circuit Current ISHORT VOUT=VSS - 30 40 mA Temperature Coefficient(Note 4) ΔVOUT VOUT  ΔTa IOUT =10mA -40℃≤Ta≤85℃ - 80 - ppm/℃ IOUT=10mA Note : 1. VOUT (T) :Specified Output Voltage 2.VOUT (E) :Effective Output Voltage ( ie. The output voltage when “VOUT (T)+ 2.0V”is provided at the VIN pin while maintaining a certain IOUT value.) 3.VDIF:VIN1 –VOUT (E)’ VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized IOUT and {VOUT (T)+2.2V} is input. 4. guaranteed by design. V10 www.microne.com.cn Page 7 of 13 ME6203 Type Characteristics (1)Intput Voltage VS. Output Voltage( Ta = 25 °C) (2)Quiescent Current VS. Input Voltage(Ta = 25 °C) (3)Output Voltage VS. Output Current ( Ta = 25 °C) (4) Output Voltage VS.Temperature (5)Max output current VS. Input Voltage( Ta = 25 °C) (6)Quiescent Current VS. Temperature V10 www.microne.com.cn Page 8 of 13 ME6203 (7)Start Time(CH1:VIN=18V,CH2:VOUT=3.3V,TA=25℃) V10 www.microne.com.cn Page 9 of 13 ME6203 Packaging Information  Packaging Type: SOT89-3 DIM Millimeters Inches Min Max Min Max A 1.4 1.6 0.0551 0.0630 b 0.32 0.52 0.0126 0.0205 b1 0.4 0.58 0.0157 0.0228 c 0.35 0.45 0.0138 0.0177 D 4.4 4.6 0.1732 0.1811 D1 1.55(TYP) 0.061(TYP) D2 1.75(TYP) 0.0689(TYP) e1 3.0(TYP) 0.1181(TYP) E 2.3 2.6 0.0906 0.1023 E1 3.94 4.4 0.1551 0.1732 E2 1.9(TYP) 0.0748(TYP) e 1.5(TYP) 0.0591(TYP) L 0.8 θ 1.2 45° V10 0.0315 0.0472 45° www.microne.com.cn Page 10 of 13 ME6203  Packaging Type: TO92 DIM Millimeters Inches Min Max Min Max A 3.3 3.7 0.1299 0.1457 A1 1.1 1.4 0.0433 0.0551 b 0.38 0.55 0.015 0.0217 c 0.36 0.51 0.0142 0.0201 D 4.3 4.7 0.1693 0.185 D1 3.43 一 0.135 一 E 4.3 4.7 0.1693 0.185 e 1.27TYP 0.05TYP e1 2.44 2.64 0.0961 0.1039 L 14.1 14.5 0.5551 0.5709 h 0 0.38 0 0.015 Φ 一 1.6 一 0.063 V10 www.microne.com.cn Page 11 of 13 ME6203  Packaging Type: SOT23-3 DIM Millimeters Inches Min Max Min Max A 1.05 1.45 0.0413 0.0571 A1 0 0.15 0.0000 0.0059 A2 0.9 1.3 0.0354 0.0512 A3 0.6 0.7 0.0236 0.0276 b 0.25 0.5 0.0098 0.0197 c 0.1 0.25 0.0039 0.0098 D 2.8 3.1 0.1102 0.1220 E 2.6 3.1 0.1023 0.1220 E1 1.5 1.8 0.0591 0.0709 e 0.95(TYP) L 0.25 L1 0.0374(TYP) 0.6 0.0098 0.59(TYP) θ 0 c1 0.0232(TYP) 8° 0.2(TYP) V10 0.0236 www.microne.com.cn 0.0000 8° 0.0079(TYP) Page 12 of 13 ME6203  The contents of this document will be updated with the product's improvement without prior notice. Please consult our sales staff before using this document to ensure that you are using  The application circuit examples described in this document are only used to indicate the representative use of the prod  Please use this product within the limits stated in this document. We will not be responsible for  The products described in this document are not allowed to be used in equipment or devices that affect the human body without the written permission of our company, including but not limited to: health equipment, medical equipment, disaster prevention equipment, fuel control equipment, automobile equipment, aviation equipme  Although our company has always been committed to improving product quality and reliability, semiconductor products have a certain probability of malfunction or wrong work. To prevent personal injury or property damage caused by such accidents, please pay full attention to safety design, for example: Alternate design, fire protection design, and prevention of wrong  When exporting this product or this document overseas, you should abide by applicable import and exp  Copying or reprinting part or all of this document in any form without the permission of our company is strictly prohibited. V10 www.microne.com.cn Page 13 of 13
ME6203A100PG 价格&库存
很抱歉,暂时无法提供与“ME6203A100PG”相匹配的价格&库存,您可以联系我们找货
