HP6215S3-36
HP6215S3-36
    HYPWR(瀚昕微)
    SOT23-3
    HP6215S3-36
HP6215S3-36 数据手册
HP6215 16V, 500mA, Low Power Consumption LDO GENERAL DESCRIPTION FEATURES The HP6215 series is a set of three-terminal, low power, ⚫ Input voltage: 3V~16V high CMOS ⚫ Output range: 2.5V~5.0V technology. The series features extremely low quiescent ⚫ Output current: 500mA (Within Max Power Dissipation) current which is typically 2.0µA. They allow input ⚫ Dropout voltage: 200mV @ VOUT=3.3V, voltage regulators implemented in voltages as high as 16V. The device provides large IOUT=100mA current with a significantly small dropout voltage. ⚫ Quiescent current: 2μA Typ. The HP6215 consists of a high-precision voltage ⚫ Good line regulation: 0.01%/V reference, an error correction circuit, an over ⚫ Good load regulation: 5mV@1mA≤Io≤50mA temperature protection circuit, and a current limited output driver. They are available with several fixed ⚫ Low temperature coefficient: 0.07mV/℃ output voltages ranging from 2.5V to 5.0V. CMOS ⚫ Soft start technology ensures low dropout voltage and low current consumption. APPLICATIONS The HP6215 regulators are available in standard SOT89- ⚫ Battery powered equipment 3L and SOT23-3L packages. Standard products are Pb- ⚫ Voltage regulator for microprocessor free and Halogen-free. ⚫ Voltage regulator for LAN cards ⚫ Wireless communication equipment ⚫ Audio/Video equipment TYPICAL APPLICATION CIRCUIT VIN VIN VOUT VOUT HP6215 C1 10uF C2 10uF GND GND PIN ASSIGNMENT 1 2 GND HP6215T3 SOT89-3L 3 VIN VOUT SOT89-3L(Top View) VIN 3 1 GND HP6215S3 HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. SOT23-3L 2 VOUT SOT23-3L(Top View) Page 1 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO ORDER INFORMATION PART NO PACAKGE TEMPERATURE TAPE & REEL HP6215S3-XX SOT23-3L -40 ~ +85℃ 3000/REEL HP6215T3-XX SOT89-3L -40 ~ +85℃ 1000/REEL “XX”: several fixed output voltages ranging from 2.5V to 5.0V PART NUMBER RULES MARKING DESCRIPTION: HP6215□ 1 -□ 2 SOT23-3L: Code Description 1 □ Package: VIN NXYWV S3: SOT23-3L T3: SOT89-3L (B type pin-out) 2 □ GND VOUT Voltage version: XX: several fixed output voltages “N”: product code, here use “T” stands for “HP6215”. ranging from 2.5V to 5.0V Example: “X”: Internal Control Code “Y”: Internal Control Code 33: 3.3V “W”: The week of manufacturing. “A” stands for week 1, “Z” stands for week 26, “a” stands for week 27, “z” stands for week 52. “V”:Output voltage code. SOT89-3L: 2 XXXX X YM XX V XX 1 2 3 Part Number Internal Control Code V:Output Voltage Code XX:Serial Number GND VIN VOUT Y: Year M: Month X: Internal Control Code TYPICAL OUTPUT VOLTAGE CODE TABLE VOUT CODE VOUT CODE 2.8V M 3.0V G 3.3V H 3.6V I 4.0V J 5.0V K PIN DESCRIPTION PIN NO SYMBOL I/O DESCRIPTTION 1 GND Ground Ground 2 3 VIN Power Input 3 2 VOUT O Output HP6215T3 HP6215S3 1 HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. Page 2 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO ABSOLUTE MAXIMUM RATINGS (Note) SYMBOL ITEMS VALUE UNIT VIN Input Voltage -0.3~20 V VOUT Output Voltage -0.3~VIN V PDMAX Power Dissipation OTP Limited W TJ Junction Temperature -40~125 ℃ TSTG Storage Temperature -55 to 150 ℃ Package Lead Soldering Temperature 260℃, 10s TSOLDER Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. RECOMMANDED OPERATING RANGE SYMBOL ITEMS VIN VIN Supply Voltage RθJA Thermal Resistance on PCB TOPT Operating Temperature VALUE UNIT 3 to 16 V 75 ℃/W -40 to +85 ℃ ELECTRICAL CHARACTERISTICS The following specifications apply for VOUT=3.3V TA=25℃, unless specified otherwise. SYMBOL ITEMS CONDITIONS MIN TYP MAX UNIT 3 5 16 V VOUT*0.98 VOUT VOUT*1.02 V 500 mA 2 3 µA VOUT = 3.3 V, IOUT = 100 mA, ΔV=2% 200 215 VOUT = 5.0 V, IOUT = 100 mA, ΔV=2% 115 130 VIN Input Voltage VOUT VOUT Range VIN= VOUT + 2 V, IOUT = 1 mA IOUT Output Current Within Maximum Power Dissipation Quiescent Current No Load IQ VDROP Dropout Voltage △VLINE Line Regulation VIN = 5~12V, IOUT = 1 mA 0 6 mV △VLOAD Load Regulation VIN = 12V, IOUT = 1~100 mA 7 36 mV Short Current VOUT Short to GND with 3Ω 90 200 mA Temperature coefficient IOUT=1mA, 0≤Ta≤70℃ 0.07 0.2 mV/℃ 160 180 ℃ ISHORT ΔVOUT/ΔTa TSD Thermal Shutdown Protection HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. VIN= VOUT + 2 V, IOUT = 1 mA 140 mV Page 3 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO SIMPLIFIED BLOCK DIAGRAM VIN VOUT Fold back Current Limit VREF HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. OTP - + Page 4 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO TYPICAL PERFORMANCE CHARACTERISTICS CIN=10μF, COUT=10μF, TOPT=25C, VIN=5.3V, VOUT=3.3V, unless specified otherwise. (Package:SOT89-3L) Quiescent Current vs. Input Voltage Output Voltage vs. Input Voltage 6 Output Voltage(V) Quiescent Current(uA) 2 1.5 1 0.5 5 4 3 2 Vout=3.3V 1 Vout=5.0V 0 0 0 4 8 12 0 16 4 8 Output Voltage vs. Load Current Output Voltage vs. Load Current 3.5 6 3 Output Voltage(V) Output Voltage(V) 16 Input Voltage(V) Input Voltage(V) 2.5 2 VOUT=3.3V 1.5 Vin=5.3V Vin=8V Vin=10V Vin=16V 1 0.5 0 0 150 300 450 5 4 VOUT=5.0V 3 Vin=7V Vin=10V Vin=12V Vin=16V 2 1 0 0 600 150 Dropout Voltage(V) 3.35 3.3 3.25 3.2 Io=1mA 3.1 3.05 3 -40 10 60 450 600 Dropout Voltage vs. Output Current Output Voltage vs. Temperature 3.15 300 Load Current(mA) Load Current(mA) Output Voltage(V) 12 110 160 450 400 350 300 250 200 150 100 50 0 Vout=3.3V Vout=5.0V 0 50 100 150 200 Output Current(mA) Temperature(℃) HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. Page 5 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO Power ON CH1:VIN CH2:VOUT Package:SOT89-3L Package:SOT89-3L VIN=5.3V VIN=5.3V VOUT=3.3V VOUT=3.3V IOUT=10mA IOUT=1mA Package:SOT89-3L Package:SOT89-3L Line Transient CH1:VIN CH2:VOUT VIN=5.3V-6.3V VIN=6.3V-5.3V VOUT=3.3V VOUT=3.3V IOUT=10mA IOUT=10mA Package:SOT89-3L Package:SOT89-3L VIN=5.3V-6.3V VIN=6.3V-5.3V VOUT=3.3V VOUT=3.3V IOUT=1mA IOUT=1mA Load Transient CH1:VIN CH2:VOUT CH4:IOUT Package:SOT89-3L Package:SOT89-3L VIN=5.3V VIN=5.3V VOUT=3.3V VOUT=3.3V IOUT=1-50mA IOUT=1-100mA HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. Page 6 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO PACKAGE OUTLINE Package SOT23-3L Devices per reel 3000Pcs Unit mm Package Dimension: Ɵ D 0.2 E1 E L b c e A1 A2 A e1 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0℃ 8℃ 0℃ 8℃ HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. Page 7 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO PACKAGE OUTLINE Package SOT89-3L Devices per reel 1000Pcs Unit mm Package Dimension: D A L b1 e E E1 D1 b c e1 D2 E2 θ Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF 0.061 REF D2 1.750 REF 0.069 REF E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 E2 1.900 REF 0.075 REF e 1.500 TYP 0.060 TYP e1 3.000 TYP 0.118 TYP L 0.900 θ HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. 1.200 45° 0.035 0.047 45° Page 8 sales@hypwr.com HP6215 16V, 500mA, Low Power Consumption LDO Revision History Version No. Date Description Preliminary 2017-05-12 Initial preliminary release Version 0.1 2017-12-15 -Update features -Update electrical characteristics -Update typical performance characteristics Version 0.2 2018-01-15 -Update package description Version 0.3 2018-01-23 -Update features description Version 0.4 2018-03-02 -Add HP6215S3 product package Version 1.0 2018-03-29 -Change HP6215T3B to HP6215T3 -Update marking description Version 1.1 2018-05-16 -Update typical performance characteristics -Add OTP description Version 1.2 2018-06-21 -Update electrical characteristics Version 1.3 2018-06-22 -Update Part Number Version 1.4 2018-10-31 -Add output voltage code table Version 1.5 2019-12-02 Update marking description HP6215 Datasheet, 2019 Version 1.5 Hypower Microelectronics(Shanghai)Co., Ltd. Page 9 sales@hypwr.com
HP6215S3-36 价格&库存
很抱歉,暂时无法提供与“HP6215S3-36”相匹配的价格&库存,您可以联系我们找货
