SK6206-28NR
SK6206-28NR
    SUNTEK(洺太电子)
    SOT23-3
    300mA LDO
SK6206-28NR 数据手册
SK6206 300mA Low Power LDO General Description SK6206 series are a highly precise, lower regulators manufactured using CMOS and laser trimming technologies. The series provides large currents with a significantly small consumption, 3 terminal, positive voltage dropout voltage. The SK6206 consists of a current limiter circuit, a driver transistor, a precision Features ⚫ Input voltage : 2.5V~7V ⚫ Output range : 1.2V~5.0V ⚫ Low power consumption ⚫ Low voltage drop ⚫ Low temperature coefficient ⚫ Low Quiescent Current: 3uA at 6V ⚫ PSRR: 50dB @ 1KHz ⚫ Output voltage accuracy: tolerance ±2% reference voltage and an error correction circuit. The series is compatible with low Applications ESR ceramic capacitors. The current ⚫ Battery-powered equipment limiter’s feedback circuit operates as a short ⚫ Reference voltage sources circuit protection as well as the output ⚫ Cameras, video cameras current limiter for the output pin. Output ⚫ Portable AV systems voltages are internally by laser trimming ⚫ Mobile phones technologies. It is selectable in 0.1V ⚫ Portable games increments within a range of 1.2V to 5.0V. SK6206 series are available in SOT-23, SOT23-3 and SOT-89 packages. Block Diagram 上海洺太电子科技有限公司 SUNTEK MICRO LTD Ordering Information SK6206-①②③④ Designator Symbol Description ①② Integer Output Voltage(1.2~5.0V) ③ ④ N Package:SOT23 M Package:SOT23-3 P Package:SOT89A P1 Package:SOT89B R RoHS / Pb Free G Halogen Free Note:”①②” stands for output voltages. Other voltages can be specially customized Pin Assignment SOT23 & SOT23-3 (Top View) 2 Mark 1 3 SOT89 (Top View) Mark 1 2 Table1: SK6206-XXNR/SK6206-XXMR series (SOT23/SOT23-3 PKG) PIN NO. PIN NAME FUNCTION 1 GND GND pin 2 VIN Input voltage pin 3 VOUT Output voltage pin Table2: SK6206-XXPR series (SOT89A PKG) PIN NO. PIN NAME FUNCTION 1 GND GND pin 2 VIN Input voltage pin 3 VOUT Output voltage pin Table3: SK6206-XXP1R series (SOT89B PKG) 3 上海洺太电子科技有限公司 PIN NO. PIN NAME FUNCTION 1 VOUT Output voltage pin 2 GND GND pin 3 VIN Input voltage pin SUNTEK MICRO LTD Marking Rule ① represents product number MARK PRODUCT SERIES 6 SK6206**** ② represents 3 pins regulator MARK VOLTAGE=0.1~3.0V VOLTAGE=3.1V~6.0V 5 PRODUCT SERIES 6 SK6206 ③ represents output voltage MARK VOLTAGE(V) MARK VOLTAGE(V) 0 - 3.1 - F 1.6 4.6 - 1 - 3.2 - H 1.7 4.7 - 2 - 3.3 - K 1.8 4.8 - 3 - 3.4 - L 1.9 4.9 - 4 - 3.5 - M 2.0 5.0 - 5 - 3.6 - N 2.1 - - 6 - 3.7 - P 2.2 - - 7 - 3.8 - R 2.3 - - 8 - 3.9 - S 2.4 - - 9 - 4.0 - T 2.5 - - A - 4.1 - U 2.6 - - B 1.2 4.2 - V 2.7 - - C 1.3 4.3 - X 2.8 - - D 1.4 4.4 - Y 2.9 - - E 1.5 4.5 - Z 3.0 - - ④ X 上海洺太电子科技有限公司 SUNTEK MICRO LTD Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 8 V Output Current IOUT 300* mA Output Voltage VOUT VSS-0.3~VIN+0.3 V 0.20 W Pd 0.25 W 0.50 W Operating Temperature Range Topr -40~+85 ℃ Storage Temperature Range Tstg -55~+125 ℃ SOT-23 Power Dissipation SOT23-3 SOT-89 *IOUT=Pd/(VIN-VOUT) Electrical Characteristics SK6206 for any output voltage(Ta=25℃) Parameter Symbol Output Voltage Vout Output Current*1 Iout Low dropout*2 Vdrop Line Regulation Load Regulation Conditions Vin=Vout+1V 1.0mA≤Iout≤30mA Typ. Max. Unit Vout×0.98 -- Vout×1.02 V -- 300 -- mA Vin-Vout=1V Refer to the next table 1.6V≤Vin≤8V △Vout1/(Vin·Vo ut) Iout=40mA △Vout /ΔIout Vin= Vout+1V 1.0mA≤Iout≤80mA Output voltage Temperature Min. Iout=30mA △Vout/(Ta·Vout) 0℃≤Ta≤70℃ Coefficiency -- 0.05 0.2 %/V -- 12 30 mV -- ±100 -- Ppm/℃ Supply Current Iss -- -- 3 5 uA Input Voltage Vin -- -- 6 8 V PSRR PSRR -- 50 -- dB Output Noise EN -- 30 -- uVrms F=1KHz Vin=Vout+1V BW=10Hz~100KHz Electrical Characteristics by Output Voltage: Dropout Voltage Vdif(V) Output Voltage Vout(V) Conditions Vout≤1.5V 1.8 ≤ Vout ≤ 2 2.8 ≤ Vout ≤ 5.0 上海洺太电子科技有限公司 Iout=100 mA Typ. Max. 0.35 0.57 0.28 0.42 0.19 0.35 SUNTEK MICRO LTD Typical Application SK6206 Typical Performance Characteristics (1) Output Voltage vs Input voltage and Output Voltage vs Output Current and Input Transient Response (2) Output Voltage vs. Ambient Temperature 上海洺太电子科技有限公司 SUNTEK MICRO LTD Package Information 3-pin SOT23 Outline Dimensions 上海洺太电子科技有限公司 SUNTEK MICRO LTD 3-pin SOT23-3 Outline Dimensions 上海洺太电子科技有限公司 SUNTEK MICRO LTD 3-pin SOT89 Outline Dimensions 上海洺太电子科技有限公司 SUNTEK MICRO LTD
SK6206-28NR 价格&库存
很抱歉,暂时无法提供与“SK6206-28NR”相匹配的价格&库存,您可以联系我们找货
SK6206-28NR
    • 10+0.35252
    • 100+0.27994
    • 300+0.24365
    • 3000+0.21039
    • 6000+0.18857
    • 9000+0.17766
    库存:2714
