Low Voltage Detector
MD70XX SERIES
(NMOS/CMOS)
General Description
The MD70XX series is a set of three-terminal low power
voltage detectors implemented in CMOS technology. Each
voltage detector in the series detects a particular fixed voltage
ranging from 1.2V to 7V. The voltage detectors consist of a
high-precision and low power consumption standard voltage
source, a comparator, hysteresis circuit, and an output driver.
CMOS technology ensures low power consumption. Although
designed primarily as fixed voltage detectors, these devices
can be used with external components to detect user
specified threshold voltages
Features
Applications
· Low power consumption
· Low temperature coefficient
· Built-in high-stability reference source
· Open drain types:
NMOS: MD70XX
CMOS: 70XXC
· Built-in hysteresis characteristic
· TO-92 package
· SOT-89 package
· SOT-23-3/5 package
· SSOT-24 package
· Battery checkers
· Level selectors
· Power failure detectors
· Microcomputer reset
· Battery memory backup
· Non-volatile RAM signal storage protectors
Absolute Maximum Ratings
Supply Voltage.................... ............. -0.3V to 18V
Output Voltage ..................VSS-0.3V to VDD+0.3V
Storage Temperature.......................-50℃to 125℃
Operating Temperature..............-40℃to 85℃
Output Current......................... 10mA
Power Consumption:
SOT89-3
500mW
TO-92
300mW
SOT23-/5
250mW
SSOT-24
250mW
Note: These are stress ratings only. Stresses exceeding the range specified under _Absolute Maximum
Ratings_ may cause substantial damage to the device. Functional operation of this device at other
conditions beyond those listed in the specification is not implied and prolonged exposure to extreme
conditions may affect device reliability.
1
MD70XX SERIES
(NMOS/CMOS)
Selection Table
Part No.
Detectable
Voltage
Hysteresis Width
Marking
NMOS Drain output
Tolerance
TO92/SOT89-3
SOT23-3/5
CMOS output
SOT23-3/5
MD7015
1.5V
0.075V
±3%
MD7019
1.9V
0.095V
±3%
MD7020
2.0V
0.100V
±3%
MD7021
2.1V
0.105V
±3%
MD7022
2.2V
0.110V
±3%
MD7023
2.3V
0.115V
±3%
MD7024
2.4V
0.120V
±3%
MD7025
2.5V
0.125V
±3%
MD7027
2.7V
0.135V
70XXC
±3%
70XX
0XX
MD7030
3.0V
0.150V
±3%
MD7033
3.3V
0.165V
±3%
MD7036
3.6V
0.180V
±3%
MD7039
3.9V
0.195V
±3%
MD7042
4.2V
0.210V
±3%
MD7044
4.4V
0.220V
±3%
MD7050
5.0V
0.250V
±3%
MD7070
7.0V
0.350V
±3%
For example: The MD7044 is a 4.4V, NMOS open drain active low output
For semi-custom parts,selectable regulated voltage range is from 1.2V to 12V in 0.1V increment.
For semi-custom parts,selectable output type CMOS .
Block Diagram
N channel open drain output (normal open; active low)
CMOS output (normal high; active low)
2
MD70XX SERIES
(NMOS/CMOS)
Logical Characteristic(NMOS/CMOS TYPE)
(1) Solid Line ......VIN from Hi→Lo
(2) Dash Line ......VIN from Hi→Lo
Pin Assignment
3
MD70XX SERIES
(NMOS/CMOS)
Electrical Characteristic
MD7015
Symbol
Parameter
Test Conditions
VDD
Conditions
VDET
VHYS
Hi→Lo Detectable Voltage
Hysteresis Width
IDD
VDD
IOL
△V DET
△T A
Operating Current
Operating Voltage
Output Sink Current
Temperature Coefficient
2.5
-1.45
No load
-VOUT=0.2V
0℃
很抱歉,暂时无法提供与“MD7040”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.27033
- 50+0.26363
- 150+0.25910
- 500+0.25456
