MMBT5401W
MMBT5401W
    CBI(创基)
    SOT-323-3
    MMBT5401W K4M
MMBT5401W 数据手册
Plastic-Encapsulate Transistors TRANSISTOR ( PNP) SOT–323 FEATURES  Complementary to MMBT5551W  Small Surface Mount Package  Ideal for Medium Power Amplificationand Switching MARKING:K4M 1. BASE 2. EMITTER MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage -160 V VCEO Collector-Emitter Voltage -150 V VEBO Emitter-Base Voltage -5 V IC Collector Current -600 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA 3. COLLECTOR ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=-100µA, IE=0 -160 V Collector-emitter breakdown voltage V(BR)CEO IC=-1mA, IB=0 -150 V Emitter-base breakdown voltage V(BR)EBO IE=-10µA, IC=0 -5 V Collector cut-off current ICBO VCB=-120V, IE=0 -50 nA Emitter cut-off current IEBO VEB=-3V, IC=0 -50 nA DC current gain hFE Collector-emitter saturation voltage VCE(sat) Base-emitter saturation voltage VBE(sat) Transition frequency Collector output capacitance fT Cob VCE=-5V, IC=-1mA 50 VCE=-5V, IC=-10mA 60 VCE=-5V, IC=-50mA 50 300 IC=-50mA, IB=-5mA -0.5 V IC=-10mA, IB=-1mA -0.2 V IC=-50mA, IB=-5mA -1 V IC=-10mA, IB=-1mA -1 V VCE=-10V,IC=-10mA , f=100MHz 100 VCB=-10V, IE=0, f=1MHz 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MHz 6 pF Typical Characteristics hFE Static Characteristic COMMON EMITTER Ta=25℃ (mA) IC -14 -0.08mA -12 -0.07mA -10 -0.06mA -8 -0.05mA DC CURRENT GAIN hFE -0.09mA -0.04mA -6 -4 300 250 Ta=100℃ 200 150 Ta=25℃ 100 -0.03mA -0.02mA -2 50 IB=-0.01mA 0 -0 -0 -1 -2 -3 -4 -5 -6 COLLECTOR-EMITTER VOLTAGE VBEsat -1000 —— VCE -7 -1 -8 COLLECTOR CURRENT VCEsat IC COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) Ta=25℃ Ta=100℃ -400 -200 -1 -10 (mA) IC (mA) IC (mA) -100 -200 -100 -200 IC IC -200 —— IC -1 Ta=100℃ -0.1 Ta=25℃ -0.01 -200 -100 COLLECTOR CURRENT -1 COLLECTOR CURRENT VBE fT 1000 COMMON EMITTER VCE=-5V TRANSITION FREQUENCY Ta=25℃ -1 -400 -600 -800 -1000 Ta=25℃ 100 10 1 -1 -1200 —— COLLECTOR CURRENT VCB/ VEB PC 250 100 COLLECTOR POWER DISSIPATION PC (mW) f=1MHz IE=0/IC=0 Ta=25℃ C (pF) Cib 10 Cob -1 REVERSE VOLTAGE -10 V -70 -10 BASE-EMMITER VOLTAGE VBE (mV) Cob/ Cib IC —— COMMON EMITTER VCE= -10V (MHz) fT (mA) IC Ta=100℃ -10 (mA) -10 1 -0.1 IC β=10 -600 -0.1 -200 —— -10 -800 -100 -10 (V) β=10 COLLECTOR CURRENT IC COMMON EMITTER VCE=-5V 350 -0.1mA -16 COLLECTOR CURRENT -18 CAPACITANCE —— 400 -20 -35 (V) —— Ta 200 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 ( ℃) 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 150 SOT-323 Package Outline Dimensions 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
MMBT5401W
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过内部发光二极管和光电晶体管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于开关电源、测量设备、通信设备等领域。
7. 封装信息:EL817采用DIP-6封装。
MMBT5401W 价格&库存
很抱歉,暂时无法提供与“MMBT5401W”相匹配的价格&库存,您可以联系我们找货
MMBT5401W
  • 20+0.16298
  • 200+0.12680
  • 600+0.10671
  • 3000+0.09116
  • 9000+0.08068
  • 21000+0.07506
库存:3191
