DN3134KW
DN3134KW
    DOESHARE(德芯)
    SOT-323-3
    NOMS 20V 750mA RDS(on)=300mΩ WITH ESD SOT-323
DN3134KW 数据手册
DN3134KW DN3134KW N-Channel Enhancement Mode Field Effect Transistor General description N-Channel Enhancement Mode Field Effect Transistor Features: • VDS : 20V • ID : 0.75A • RDS(ON)( at VGS=4.5V) <270 mohm • RDS(ON)( at VGS=2.5V) <330 mohm Applications • Drivers: Relays, Solenoid, Lamps, Hammers, Displays, Memories • Battery Operated Systems • Power Supply Converter Circuits • Load/Power Switching Cell Phones, Pagers Device Marking Code: Device Type Device Marking DN3134KW 34K Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Symbol Value Drain-source Voltage VDS 20 V Gate-source Voltage VGS ±8 V Continuous Drain Current ID 750 mA Pulsed Drain Current A IDM 1000 mA Power Dissipation with no heat sink @ TA=25℃ PD 150 mW 275 mW RthJA 833 ℃/W TJ 150 ℃ TSTG -55~+150 ℃ Maximum Power Dissipation with infinite heat sink @ TC=25℃ Thermal Resistance From Junction To Ambient Operation Junction Temperature Storage Temperature www.doeshare.net Unit Page 1 of 5 DN3134KW Electrical Characteristics (TJ=25℃ unless otherwise noted) Parameter Symbol Test conditions Min Typ Max Unit Static Characteristics Drain-source breakdown voltage V(BR)DSS VGS= 0V, ID=250μA Zero gate voltage drain current IDSS VDS=20V,VGS=0V Gate-body leakage current IGSS1 Gate threshold voltage VGS(th) Drain-source on-resistance RDS(ON) 20 V 1 μA ±10 μA 0.75 1.2 V VGS= 4.5V, ID=750mA 220 300 VGS= 2.5V, ID=400mA 260 400 VGS= ±8V, VDS=0V VDS= VGS, ID=250μA 0.45 mΩ Dynamic characteristics B Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 21 VDS=15V,VGS=0V,f=1MHZ 15 pF 8 Switching Characteristics B Turn-on delay time Turn-on rise time Turn-off delay time Turn-off fall time td(on) tr VGS=4.5V,VDD=10V,RG=10Ω,ID=50 0mA 6.7 ns 4.8 td(off) 17.3 tf 7.4 Source-Drain Diode characteristics Diode Forward voltage C VDS VGS=0V,IS=150mA 1.2 V Notes: A. Repetitive Rating: Pulse width limited by maximum junction temperature. B. These parameters have no way to verify. C. Pulse Test: Pulse Width≤300us, Duty Cycle≤0.5%. www.doeshare.net Page 2 of 5 DN3134KW Typical Performance Characteristics www.doeshare.net Page 3 of 5 DN3134KW SOT-323 Package Outline Suggested Pad Layout www.doeshare.net Page 4 of 5 DN3134KW Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net Page 5 of 5
DN3134KW 价格&库存
很抱歉,暂时无法提供与“DN3134KW”相匹配的价格&库存,您可以联系我们找货
