30V /36A Single N Power MOSFET
SMIRF8N60
N-Channel Enhancement Mode Power MOSFET
Description
SMIRF8N60 is an N-channel enhancement mode
power MOS field effect transistor. The improved
planar stripe cell and the improved guard ring
terminal have been especially tailored to minimize
on-state resistance, provide superior switching
performance, and withstand high energy pulse in
ID
8A
VDSS
600V
Rdson(max)
1.2Ω(VGS=10V, ID=4A)
Qg
20nC
the avalanche and commutation mode.
These devices are widely used in AC-DC power
suppliers, DCDC converters and H-bridge PWM
motor drivers.
General Features
● 8A,600V,RDS(on)(typ.)= 0.9ohm@VGS=10V
● Low Gate charge
● Low Crss
● Fast Switching
● Improved dv/dt Capability
Application
● Power switching application
● Hard switched and high frequency circuits
● Uninterruptible power supply
TO-220
1
V01
www.sourcechips.com
TO-220F
SMIRF8N60
Order Information
Order Information
Marking ID
Package
SMIRF8N60T2TL
IRF8N60
TO220F-3L
SMIRF8N60T1TL
IRF8N60
TO220-3L
Packing Type Supplied As
1000 units on Box、5000 units on Carton
1000 units on Box 5000 units on Carton
Absolute Maximum Ratings Ta=25 ºC unless otherwise noted
Parameter
Symbol
Value
Unit
Drain-source Voltage
VDS
600
V
Gate-source Voltage
VGS
±30
V
Continuous Drain Current(Ta=25 )
ID
8
A
Drain Current-Pulsed
IDM
32
A
Total
Dissipation(Ta=25 )
TO220
152
PD
W
TO220F
48
Junction Temperature
TJ
150
ºC
Storage Temperature
TSTG
-65 to 150
ºC
Single Pulse Avalanche Energy
EAS
550
mJ
ESD HBM(Human Body Mode)
≥2000
V
ESD MM(Machine Mode)
≥200
V
Electrical Characteristics Ta = 25ºC
PARAMETER
Drain-source Breakdown Voltage
Symbol
Test Condition
MIN
BVDSS
VGS=0V, ID=250μA
500
VGS(TH)
VGS=VDS ,ID=250μA
2.0
Drain-source Leakage Current
IDSS
Drain-Source Diode Forward Voltage
VSD
VGS=0V IS=8A
Gate-body Leakage Current (VDS = 0)
IGSS
VGS=±30V
Static Drain-source On Resistance
RDS(ON)
Gate Threshold Voltage
Typ
MAX
UNIT
V
4.0
V
VDS=600V,VGS=0V
1
uA
1.4
V
±100
nA
1.2
Ω
VGS=10V,ID=4A
3.0
0.9
Note: Using continuously under heavy loads (e.g. the application of high temperature/current/voltage and the
significant in temperature etc.) may cause this product to decrease in the reliability significantly even if
the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute
maximum ratings
V01
2
www.sourcechips.com
SMIRF8N60
Thermal Characteristics Ta=25℃
PARAMETER
Symbol
TYP
MAX
UNIT
Maximum Junction-to-case
TO220F,TO220
RQJC
2.5
ºC/W
Maximum Junction-to-Ambient
TO220F,TO220
RQJA
62.5
ºC/W
Note1: Ensure that the channel temperature does not exceed 150ºC
Note2: VDD=50V,Tch=25 ºC(initial),IAS=8A Rg=25Ω
Note3: This transistor is sensitive to electrostatic and should be handled with care
Dynamic Characteristics Ta = 25 ºC
PARAMETER
Symbol
Input Capacitance
Ciss
output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate Resistance
Rg
Test Condition
MIN
VDS=25V,VGS=0V, f=1.0MHZ
VDS=0V,VGS=0V,f=1.0MHz
TYP
MAX
UNIT
1160
pF
110
pF
8
pF
2
Ω
Switching Characteristics Ta=25 ºC
PARAMETER
Symbol
Turn-On Delay Time
Td(on)
Turn-On Rise Time
Tr
Turn-Off Delay Time
Td(off)
Turn-Off Rise Time
Test Condition
MIN
TYP
MAX
UNIT
nS
27
nS
60
nS
Tf
30
nS
Total Gate Charge
Qg
nC
Gate-Source Charge
Qgs
6
nC
Gate-Drain Charge
Qgd
5.5
nC
VDS=300V,ID=8A,
VGS=10V ,RG=25Ω
VDS=520V
,I =8A,V
D
=10V
GS
Drain-Source Diode Maximum Ratings and Characteristics Ta=25 ºC
PARAMETER
Symbol
Max. Diode Forward Current
Is
Test Condition
TYP
MAX
UNIT
8
A
32
A
1.5
V
Pulsed Source Current
Ism
Integral Reverse P-N Junction
Diode in the MOSFET
VSD
VGS=0V,IS=8A
0.85
VGS=0V,IS=8A,
dIF/dt=100A/μs
320
nS
2.5
μC
Reverse Recovery Time
Reverse Recovery Charge
trr
Qrr
3
V01
MIN
www.sourcechips.com
Test Circuit
Gate Charge Test Circuit & Waveform
Resistive Switching Test Circuit & Waveform
Unclamped Inductive Switching Test Circuit & Waveform
4
V01
www.sourcechips.com
SMIRF8N60
SMIRF8N60
Typical Characteristics Curve
Figure 1: Output Characteristics
Transfer Characteristics
Figure 2:
Figure 3: On Resistance Vs Drain Current
Gate Source Voltage
Figure5: On Resistance Vs Junction Temperature
5
V01
www.sourcechips.com
Figure 4: On Resistance Vs
Figure6: Capacitance
SMIRF8N60
Characteristics
Figure7: Gate Charge Waveform
Forward Voltage
Figure8: Source-Drain Diode
Figure9: Breakdown Voltage Vs Junction Temperature
Note: The above characteristics curves are presented for reference only and not guaranteed by production test
6
V01
www.sourcechips.com
Outline Information (TO220F-3L)
Outline Information (TO220-3L)
7
V01
www.sourcechips.com
SMIRF8N60
8
V01
www.sourcechips.com
SMIRF8N60
很抱歉,暂时无法提供与“SMIRF8N60T1TL”相匹配的价格&库存,您可以联系我们找货
