SMIRF5N65T1TL
SMIRF5N65T1TL
    SPS(源芯)
    TO-220-3
    SMIRF5N65T1TL
SMIRF5N65T1TL 数据手册
30V /36A Single N Power MOSFET SMIRF5N65 N-Channel Enhancement Mode Power MOSFET Description SMIRF5N65 is an N-channel enhancement mode power MOS field effect transistor. The improved planar stripe cell and the improved guard ring terminal have been especially tailored to minimize on-state resistance, provide superior switching performance, and withstand high energy pulse in ID 5A VDSS 650V Rdson(max) 2.3Ω(VGS=10V, ID=2.5A) Qg 15nC the avalanche and commutation mode. These devices are widely used in AC-DC power suppliers, DC/DC converters and H-bridge PWM motor drivers. General Features ● 5A,650V,RDS(on)(typ.)= 1.9ohm@VGS=10V ● Low Gate charge ● Low Crss ● Fast Switching ● Improved dv/dt Capability Application ● Power switching application ● Hard switched and high frequency circuits ● Uninterruptible power supply TO-220 TO-252 1 V01 www.sourcechips.com TO-220F TO-251 30V /36A Single N Power MOSFET SMIRF5N65 Order Information Order Information Marking ID Package Packing Type Supplied As SMIRF5N65TBRL IRF5N65 TO251-3L 2400 Units on Box SMIRF5N65T9RL IRF5N65 TO252-2L 3000 Units on Reel SMIRF5N65T2TL IRF5N65 TO220F-3L 1000 units on Box 5000 units on Carton SMIRF5N65T1TL IRF5N65 TO220-3L 、 1000 units on Box、5000 units on Carton Absolute Maximum Ratings Ta=25 ºC unless otherwise noted Parameter Symbol Value Unit Drain-source Voltage VDS 650 V Gate-source Voltage VGS ±30 V Continuous Drain Current(Ta=25 ) ID 5 A Drain Current-Pulsed IDM 20 A ℃ TO251 Total Dissipation (Ta=25 ) ℃ 55 TO252 50 PD W TO220 30 TO220F 30 Junction Temperature TJ 150 ºC Storage Temperature TSTG -65 to 150 ºC Single Pulse Avalanche Energy EAS 210 mJ ESD HBM(Human Body Mode) ≥2000 V ESD MM(Machine Mode) ≥200 V Electrical Characteristics Ta = 25ºC PARAMETER Drain-source Breakdown Voltage Gate Threshold Voltage Symbol BVDSS Test Condition VGS=0V, ID=250μA TYP MAX 650 UNIT V 4.0 V 25 uA VGS=0V IS=5A 1.4 V IGSS VGS=±30V ±100 nA RDS(ON) VGS=10V,ID=2.5A 2.3 Ω VGS(TH) VGS=VDS ,ID=250μA Drain-source Leakage Current IDSS VDS=650V,VGS=0V Drain-Source Diode Forward Voltage VSD Gate-body Leakage Current (VDS = 0) Static Drain-source On Resistance V01 MIN 2.0 , 2 www.sourcechips.com 1.9 SMIRF5N65 30V /36A Single N Power MOSFET Thermal Characteristics Ta=25℃ PARAMETER Symbol TYP TO251,TO252 Maximum Junction-to-case (note1) MAX UNIT 2.5 ºC/W 3 ºC/W RQJC TO220F,TO220 TO251,TO252 63 Maximum Junction-to-Ambient RQJA ºC/W 80 TO220F,TO220 Note1: Surface Mounted on FR4 Board, t ≤ 10 sec Dynamic Characteristics Ta = 25 ºC PARAMETER Symbol Input Capacitance Ciss output Capacitance Coss TYP MAX UNIT 560 600 pF 70 78 pF 8 10 pF TYP MAX UNIT 13 26 nS 45 8 nS Td(off) 38 120 nS Turn-Off Rise Time Tf 35 85 nS Total Gate Charge Qg 15 nC Gate-Source Charge Qgs 2.5 nC Gate-Drain Charge Qgd 6.6 nC Reverse Transfer Capacitance Test Condition MIN VDS=25V,VGS=0V, f=1.0MHZ Crss Switching Characteristics Ta=25 ºC PARAMETER Symbol Turn-On Delay Time Td(on) Turn-On Rise Time Turn-Off Delay Time Test Condition MIN Tr VDS=300V,ID=5A,RG=25Ω VDS=480V ,I =5A,V D =10V GS Drain-Source Diode Maximum Ratings and Characteristics Ta=25 ºC PARAMETER Symbol Max. Diode Forward Current Is Test Condition Pulsed Source Current Ism Integral Reverse P-N Junction Diode in the MOSFET Diode Forward Voltage VSD VGS=0V,IS=5A Reverse Recovery Time Reverse Recovery Charge Trr Qrr VGS=0V,IS=5A, dIF/dt=100A/μs 3 V01 www.sourcechips.com MIN TYP MAX UNIT 5 A 20 1.5 V 270 nS 1.9 μC 30V /36A Single N Power MOSFET Test Circuit Gate Charge Test Circuit & Waveform Resistive Switching Test Circuit & Waveform Unclamped Inductive Switching Test Circuit & Waveform V01 4 www.sourcechips.com SMIRF5N65 30V /36A Single N Power MOSFET Typical Electrical SMIRF5N65 And Thermal Characteristics Figure 1: Output Characteristics Figure 2: Transfer Characteristics Figure 3: On Resistance Vs Drain Current Figure 4: On Resistance Vs Gate Source Voltage Figure5: On Resistance Vs Junction Temperature Characteristics 5 V01 www.sourcechips.com Figure6: Capacitance 30V /36A Single N Power MOSFET SMIRF5N65 Characteristics Curve Figure7: Gate Charge Waveform Forward Voltage Figure8: Source-Drain Diode Figure9: Breakdown Voltage Vs Junction Temperature 6 V01 www.sourcechips.com 30V /36A Single N Power MOSFET Outline Information (TO251-3L) 7 V01 www.sourcechips.com SMIRF5N65 30V /36A Single N Power MOSFET Outline Information (TO252-2L) Outline Information (TO220F-3L) 8 V01 www.sourcechips.com SMIRF5N65 30V /36A Single N Power MOSFET Outline Information (TO220-3L) 9 V01 www.sourcechips.com SMIRF5N65
SMIRF5N65T1TL 价格&库存
很抱歉,暂时无法提供与“SMIRF5N65T1TL”相匹配的价格&库存,您可以联系我们找货
