BRCS3205RA
BRCS3205RA
    BLUEROCKET(蓝箭电子)
    TO-220-3
    1个N沟道 耐压:55V 电流:110A
BRCS3205RA 数据手册
BRCS3205RA Rev.I Jan.-2019 描述 / DATA SHEET Descriptions N 沟道 TO-220 塑封封装场效应管。 N-CHANNEL MOSFET in a TO-220 Plastic Package. 特征 / Features 阻抗低,开关速度快。 Low On-Resistance, fast switching. 用途 / Applications 用于高效 DC/DC 转换和功率开关。 These devices are well suited for high efficiency switching DC/DC converters and switch mode power supplies. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S / hFE Classifications & Marking 见印章说明。 See Marking Instructions. http://www.fsbrec.com 1/6 BRCS3205RA Rev.I Jan.-2019 极限参数 DATA SHEET / Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 55 V ID(Tc=25℃) 110 A ID(Tc=100℃) 80 A Pulsed Drain Current IDM 390 A Gate-Source Voltage VGSS ±20 V Avalanche Current IAR 62.3 A Single Pulsed Avalanche Energy EAS 1.3 J PD(Tc=25℃) 200 W TJ,TSTG -55 to 150 ℃ Drain-Source Voltage Drain Current Total Power Dissipation Junction and Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter 符号 Symbol 测试条件 Test Conditions 最小值 典型值 最大值 单位 Min Typ Max Unit Zero Gate Voltage Drain Current BVDSS VGS=0V ID=250μA Zero Gate Voltage Drain Current IDSS VDS=55V VGS=0V 1 μA Gate-Body Leakage Current Forward IGSS VGS=±20V VDS=0V ±0.1 μA VGS(th) VDS=VGS ID=250μA 4 V RDS(on) VGS=10V ID=90A 8 mΩ gFS VDS=10V ID=30A Forward On Voltage VSD VGS=0V IS=90A Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 211 Turn-On Delay Time td(on) 14 Turn-On Rise Time tr Turn-Off Delay Time td(off) Gate Threshold Voltage Static Drain-Source On-Resistance Forward Transconductance Turn-Off Fall Time http://www.fsbrec.com tf 55 V 2 38 S 1.3 V 3140 VDS=25V f=1MHz VDD=28V RG=4.5Ω VGS=0V ID=62A 806 101 50 pF ns 65 2/6 BRCS3205RA Rev.I Jan.-2019 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BRCS3205RA Rev.I Jan.-2019 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BRCS3205RA Rev.I Jan.-2019 印章说明 / DATA SHEET Marking Instructions BR **** 3205 说明: BR:   为公司代码 3205:     为产品型号 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   3205: ****: http://www.fsbrec.com Product Type.  Lot No. Code, code change with Lot No. 5/6 BRCS3205RA Rev.I Jan.-2019 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 TO-220/F 套管包装 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 散件包装 TO-220/F 时间:10±1 sec. / BULK Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 Inner Box 盒 Outer Box 箱 200 10 2,000 5 10,000 135×190 237×172×102 560×245×195 Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×31.4×5.5 555×164×50 575×290×180 / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) / Notices http://www.fsbrec.com 6/6
BRCS3205RA 价格&库存
很抱歉,暂时无法提供与“BRCS3205RA”相匹配的价格&库存,您可以联系我们找货
BRCS3205RA
  • 1+6.24240
  • 10+5.31360
  • 50+4.84920
  • 100+4.38480
  • 500+4.10400
  • 1000+3.96360
库存:958
