SE40160A
SE40160A
    SINO-IC(光宇睿芯)
    TO-220-3
    1个N沟道 耐压:40V 电流:160A
SE40160A 数据手册
SE40160A N-Channel Enhancement-Mode MOSFET Revision: A Features General Description Thigh Density Cell Design For Ultra Low On-Resistance Fully Characterized Avalanche Voltage and Current Improved Shoot-Through For a single MOSFET   VDS = 40V RDS(ON) = 4mΩ @ VGS=10V FOM  Simple Drive Requirement  Small Package Outline  Surface Mount Device Pin configurations See Diagram below Absolute Maximum Ratings Parameter Symbol Rating Units Drain-Source Voltage VDS 40 V Gate-Source Voltage VGS ±20 V Drain Current Total Power Dissipation Continuous Pulsed @TA=25℃ Operating Junction Temperature Range ShangHai Sino-IC Microelectronic Co., Ltd. ID 160 340 A PD 100 W TJ -55 to 175 ℃ 1. SE40160A Electrical Characteristics Symbol (TJ=25℃ unless otherwise noted) Parameter Test Conditions Min Typ Max Units OFF CHARACTERISTICS (Note 2) BVDSS Drain-Source Breakdown Voltage ID=250μA, VGS=0 V 40 V IDSS Drain to Source Leakage Current VDS=40V, VGS=0V 20 μA IGSS Gate-Body Leakage Current VGS=20V 100 nA VGS(th) Gate Threshold Voltage VDS= VGS, ID=250μA 2 4 V RDS(ON) Static Drain-Source On-Resistance VGS=10V, ID=16A - 5 mΩ 4 DYNAMIC PARAMETERS Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance VGS=0V, VDS=15V, f=1MHz 7032 pF 898 pF 743 pF 80 nC 19 nC 38 nC SWITCHING PARAMETERS Qg Total Gate Charge 2 VGS=10V, VDS=15V, Qgs Gate Source Charge Qgd Gate Drain Charge td(on) Turn-On Delay Time VGS=10V, VDS=15V, 20 ns td(off) Turn-Off Delay Time RGEN=1Ω 80 ns td(r) Turn-On Rise Time ID=1A 36 ns td(f) Turn-Off Fall Time 33 ns ID=30A Thermal Resistance Symbol RθJC Parameter Thermal Resistance Junction to Case(t≤10s) ShangHai Sino-IC Microelectronic Co., Ltd. Typ Max Units - 1.5 ℃/W 2. SE40160A Typical Characteristics ShangHai Sino-IC Microelectronic Co., Ltd. 3. SE40160A Typical Characteristics ShangHai Sino-IC Microelectronic Co., Ltd. 4. SE40160A Package Outline Dimension TO-220 ShangHai Sino-IC Microelectronic Co., Ltd. 5. The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd. © 2005 SINO-IC – Printed in China – All rights reserved. SHANGHAI SINO-IC MICROELECTRONICS CO., LTD Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China Phone: +86-21-33932402 33932403 33932405 33933508 33933608 Fax: +86-21-33932401 Email: webmaster@sino-ic.net Website: http://www.sino-ic.net ShangHai Sino-IC Microelectronic Co., Ltd. 6.
SE40160A 价格&库存
很抱歉,暂时无法提供与“SE40160A”相匹配的价格&库存,您可以联系我们找货
SE40160A
    • 1+2.94840
    • 10+2.38680
    • 50+2.03580
    • 100+1.76040
    • 500+1.59300
    • 1000+1.50660
    库存:38
