SE100180GA
SE100180GA
    SINO-IC(光宇睿芯)
    TO-220-3
    1个N沟道 耐压:100V 电流:180A
SE100180GA 数据手册
SE100180GA N-Channel Enhancement-Mode MOSFET Revision: A General Description Advanced trench technology to provide excellent RDS(ON), low gate charge and low operation voltage. This device is suitable for using as a load switch or in PWM applications.  Synchronous Rectification in SMPS  Hard Switching and High Speed Circuit Power Tools  UPS  Motor Control  Features For a single MOSFET   VDS = 100V RDS(ON) = 2.5mΩ @ VGS=10V Pin configurations See Diagram below Absolute Maximum Ratings Parameter Symbol Rating Units Drain-Source Voltage VDS 100 V Gate-Source Voltage VGS ±20 V Drain Current Continuous Pulsed Single Pulse Avalanche Energy Total Power Dissipation @TC=25℃ Operating Junction Temperature Range ShangHai Sino-IC Microelectronic Co., Ltd. ID 180 400 A EAS 1000 mJ PD 300 W TJ -55 to 175 ℃ 1. SE100180GA Electrical Characteristics Symbol (TJ=25℃ unless otherwise noted) Parameter Test Conditions Min Typ Max Units OFF CHARACTERISTICS (Note 2) BVDSS Drain-Source Breakdown Voltage ID=250μA, VGS=0 V IDSS Drain to Source Leakage Current VDS=100V, VGS=0V IGSS Gate-Body Leakage Current VGS=20V VGS(th) Gate Threshold Voltage VDS= VGS, ID=250μA RDS(ON) Static Drain-Source On-Resistance VGS=10V, ID=40A Forward Transconductance VDS=10V, ID=20A gFS 100 V 1 μA 100 nA 2.0 2.8 4.0 V - 2.5 2.8 mΩ 90 S 7300 pF 580 pF 18 pF 118 nC 27 nC 21 nC DYNAMIC PARAMETERS Ciss Input Capacitance VGS=0V, VDS=50V, Coss Output Capacitance Crss Reverse Transfer Capacitance f=1MHz SWITCHING PARAMETERS Qg Total Gate Charge 2 VGS=10V, VDS=50V, Qgs Gate Source Charge Qgd Gate Drain Charge td(on) Turn-On Delay Time VGS=10V, VDS=50V, 35 ns td(off) Turn-Off Delay Time RGEN=10Ω 92 ns td(r) Turn-On Rise Time 56 ns td(f) Turn-Off Fall Time 26 ns ID=20A Thermal Resistance Symbol RθJC Parameter Thermal Resistance Junction to Case(t≤10s) ShangHai Sino-IC Microelectronic Co., Ltd. Typ Max Units - 0.53 ℃/W 2. SE100180GA Typical Characteristics ShangHai Sino-IC Microelectronic Co., Ltd. 3. SE100180GA Typical Characteristics ShangHai Sino-IC Microelectronic Co., Ltd. 4. SE100180GA Package Outline Dimension TO-220 ShangHai Sino-IC Microelectronic Co., Ltd. 5. The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd. © 2005 SINO-IC – Printed in China – All rights reserved. SHANGHAI SINO-IC MICROELECTRONICS CO., LTD Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China Phone: +86-21-33932402 33932403 33932405 33933508 33933608 Fax: +86-21-33932401 Email: webmaster@sino-ic.net Website: http://www.sino-ic.net ShangHai Sino-IC Microelectronic Co., Ltd. 6.
SE100180GA 价格&库存
很抱歉,暂时无法提供与“SE100180GA”相匹配的价格&库存,您可以联系我们找货
SE100180GA
  • 1+3.46140
  • 10+2.80800
  • 50+2.48400
  • 100+2.16000
  • 500+1.96560
  • 1000+1.86300
库存:52
