BR40P03
Rev.F Jul.-2018
DATA SHEET
Descriptions
TO-220 塑封封装 P 沟道 MOS 场效应管。P-CHANNEL MOSFET in a TO-220 Plastic Package.
特征
/ Features
超低电阻、大电流、开关速度快。
Low On-Resistance, High Current, High Speed switching, fast switching.
用途
Applications
用于 LED 电源控制器、DC/DC 转换、DC/AC 转换。
LED Power Controller,DC-DC&DC-AC Converters.
内部等效电路
引脚排列
1
2
/ Equivalent Circuit
/ Pinning
3
PIN1:G
放大及印章代码
PIN 2:D
PIN 3:S
/ hFE Classifications & Marking
见印章说明。 See Marking Instructions.
http://www.fsbrec.com
1/6
BR40P03
Rev.F Jul.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
VDS
-30
V
Drain Current
ID(Tc=25℃)
-40
A
Drain Current
ID(Tc=100℃)
-20
A
Pulsed Drain Current
IDM
-120
A
Gate-Source Voltage
VGS
±25
V
Avalanche Current
IAS
62
A
PD(Tc=25℃)
80
W
Junction Temperature Range
Tj
-55~150
Storage Temperature Range
Tstg
-55~150
Thermal Resistance Junction-Ambient
RθJA
65
℃/W
Thermal Resistance Junction-Case
RθJC
3.72
℃/W
Drain-Source Voltage
Total Power Dissipation
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Zero Gate Voltage Drain Current
符号
Symbol
BVDSS
测试条件
Test Conditions
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
VGS=0V
ID=-250μA
ID=-1mA
Ta=25℃
VGS=-10V
ID=-24A
14
VDS=-30V
VGS=0V
-1.0
VDS=-24V
TC=150℃
-25
VGS=±25V
VDS=0V
VGS(th)
VDS=VGS
ID=-250μA
Forward Transconductance
gfs
VDS=-10V
ID=-24V
Total Gate Charge
Qg
VDS=-24A
VGS=-4.5V
ID=-24V
BVDSS Temperature Coefficient
Static Drain-Source
On-Resistance
△BVDSS
/△TJ
RDS(ON)
IDSS
Gate-Body Leakage Current
Forward
IGSS
Gate Threshold Voltage
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
-30
V
-0.01
-1
V/℃
μA
±100
nA
-3
V
35
30
mΩ
S
55
6
nC
25
2200
VDS=-25V
f=1.0MHz
VGS=0V
635
3395
pF
560
2/6
BR40P03
Rev.F Jul.-2018
电性能参数
DATA SHEET
参数
Parameter
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
符号
Symbol
td(on)
tr
td(off)
Fall Time
tf
Reverse Recovery Time2
trr
Reverse Recovery Charge
Qrr
Diode Forward Voltage2
VSD
测试条件
Test Conditions
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
10
VDD=-15V
RG=3.3Ω
RD=0.63Ω
ID=-24A
VGS=-10V
65
ns
60
100
VGS=0V
IS=-24A
di/dt=-100A/μs
VGS=0V
TJ=25℃
IS=-24A
39
nC
38
-1.2
V
3/6
BR40P03
Rev.F Jul.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
BR40P03
Rev.F Jul.-2018
印章说明
DATA SHEET
BR
40P03
说明:
BR:
为公司代码
40P03:
为型号代码
为生产批号代码,随生产批号变化。
Company Code
Note:
BR:
40P03:
Product Type.
Lot No. Code, code change with Lot No.
5/6
BR40P03
Rev.F Jul.-2018
DATA SHEET
波峰焊温度曲线图(无铅)
Temperature Profile for Dip Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 255±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:255±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:270±5℃
包装规格
Package Type
封装形式
TO-220/F
套管包装
Package Type
封装形式
使用说明
Temp.:270±5℃
Time:10±1 sec
/ Packaging SPEC.
散件包装
TO-220/F
时间:10±1 sec.
/ BULK
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Bag
只/袋
Bags/Inner Box
袋/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Bag 袋
Inner Box 盒
Outer Box 箱
200
10
2,000
5
10,000
135×190
237×172×102
560×245×195
Units/Tube
只/套管
Tubes/Inner Box
套管/盒
Units/Inner Box
只/盒
盒/箱
Units/Outer Box
只/箱
Tube 套管
Inner Box 盒
Outer Box 箱
50
5
5,000
532×31.4×5.5
555×164×50
575×290×180
/ TUBE
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
/ Notices
6/6
很抱歉,暂时无法提供与“BR40P03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.19068
- 50+1.80965
- 150+1.64636
