GOFORD
8680A
General Description
The 8680A is N-channel MOS Field Effect Transistor
designed for high current switching applications. Rugged
EAS capability and ultra low RDS(ON) is suitable for PWM,
load switching especially for E-Bike controller applications.
Schematic Diagram
Features
VDSS
RDS(ON)
@10V (typ)
80V
ID
92A
6.6 mΩ
Marking and pin assignment
● Special Designed for E-Bike Controller Application
● Ultra Low On-Resistance
● High UIS and UIS 100% Test
Application
● 64V E-Bike Controller Applications
● Hard Switched and High Frequency Circuits
● Uninterruptible Power Supply
To-220 Top View
Package Marking and Ordering Information
Device Marking
8680A
Device
Device Package
Reel Size
Tape width
Quantity
8680A
TO-220
Table 1. Absolute Maximum Ratings (TA=25℃)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
80
V
VGS
Gate-Source Voltage (VDS=0V)
±25
V
ID (DC)
Drain Current (DC) at Tc=25℃
92
A
ID (DC)
Drain Current (DC) at Tc=100℃
64.4
A
368
A
Peak Diode Recovery Voltage
30
V/ns
Maximum Power Dissipation(Tc=25℃)
139
W
Derating Factor
0.93
W/℃
625
mJ
-55 To 175
IDM (pluse)
dv/dt
PD
EAS
Drain Current-Continuous@ Current-Pulsed
Single Pulse Avalanche Energy
(Note 1)
(Note 2)
Operating Junction and Storage Temperature Range
TJ,TSTG
Notes 1.Repetitive Rating: Pulse width limited by maximum junction temperature
2.EAS condition:TJ=25℃,VDD=40V,VG=10V,RG=25Ω
B
B
HTTP://www.gofordsemi.com TEL:0755-29961262 FAX:0755-29961466
Page 1
GOFORD
8680A
Table 2. Thermal Characteristic
Symbol
Parameter
RJC
Thermal Resistance,Junction-to-Case
Table 3. Electrical Characteristics (TA=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Value
Unit
1.08
℃/W
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
82
IDSS
Zero Gate Voltage Drain Current(Tc=25℃)
VDS=82V,VGS=0V
1
μA
IDSS
Zero Gate Voltage Drain Current(Tc=125℃)
VDS=82V,VGS=0V
10
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
2.8
4
V
RDS(ON)
Drain-Source On-State Resistance
6.6
7.8
mΩ
2
VGS=10V, ID=40A
V
Dynamic Characteristics
gFS
Forward Transconductance
Ciss
Input Capacitance
VDS=10V,ID=15A
VDS=25V,VGS=0V,
f=1.0MHz
S
5053
PF
442
PF
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
145
PF
Qg
Total Gate Charge
106
nC
Qgs
Gate-Source Charge
19
nC
Qgd
Gate-Drain Charge
47.9
nC
15
nS
18
nS
31
nS
38
nS
VDS=50V,ID=40A,
VGS=10V
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
tf
VDD=30V,ID=40A,RL=15Ω
VGS=10V,RG=2.5Ω
Turn-Off Delay Time
Turn-Off Fall Time
Source-Drain Diode Characteristics
ISD
Source-drain Current(Body Diode)
92
A
ISDM
Pulsed Source-Drain Current(Body Diode)
368
A
VSD
(Note 1)
Forward On Voltage
TJ=25℃,ISD=40A,VGS=0V
(Note 1)
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ton
Forward Turn-on Time
(Note 1)
TJ=25℃,IF=75A
di/dt=100A/μs
0.78
0.95
V
56
nS
113
nC
Intrinsic turn-on time is negligible(turn-on is dominated by LS+LD)
Notes 1.Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 1.5%, RG=25Ω, Starting TJ=25℃
Page 2
GOFORD
8680A
Test Circuit
1) EAS Test Circuits
2) Gate Charge Test Circuit:
3) Switch Time Test Circuit:
Page 3
GOFORD
8680A
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS (Curves)
Figure2. Transfer Characteristics
ID-Drain Current (A)
Figure1. Output Characteristics
VDS Drain-Source Voltage (V)
VGS Gate-Source Voltage (V)
Figure3. Rdson Vs Drain Current
Figure4. Rdson Vs Junction Temperature
Normalized On-Resistance
RDS(ON) On-Resistance (mΩ)
3.0
ID- Drain Current (A)
TJ-Junction Temperature(℃)
Figure6. Source- Drain Diode Forward
IS - Source Current (A)
Figure5. Gate Charge
Qg Gate Charge (nC)
VSD Source-Drain Voltage (V)
Page 4
GOFORD
8680A
Figure8. Safe Operation Area
ID-Drain Current(A)
C Capacitance (pF)
Figure7. Capacitance vs Vds
Figure10. VGS(th) vs Junction Temperature
Normalized BVDSS
Figure9. BVDSS vs Junction Temperature
R(t), Normalized Effective
Transient Thermal Impedance
Figure11. Normalized Maximum Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Page 5
很抱歉,暂时无法提供与“8680A”相匹配的价格&库存,您可以联系我们找货
