GOFORD
8070
Features
Applications
z VDSS=80V/VGSS=±25V/ID=88A
RDS(ON)=11mΩ(Max.)@VGS=10V
z Avalanche Rated
z Reliable and Rugged
z Advanced trench process technology
z High Density Cell Design For Ultra Low
On-Resistance
z
z
Pin Description
TO-252
Synchronous Rectification
Power Management in Inverter System
Switching Time Test Circuit and
Waveforms
TO-220
HTTP://www.gofordsemi.com TEL 0755-29961262 FAX 0755-29961466
Page 1
GOFORD
8070
Absolute Maximum Ratings (TA=25°C unless otherwise noted)
Symbol
VDSS
VGSS
Parameter
Drain-Source Voltage
Gate –Source Voltage
TC=100°C
ID
Continuous Drain Current
IDP
IS
300us Pulsed Drain Current Tested
Diode Continuous Forward Current
EAS
Single PulseAvalanche Energy
TJ
TSTG
Operating Junction Temperature
Storage Temperature Range
TC=25°C
Typical
80
±25
50
88
280
70
Unit
V
V
A
A
A
A
550
mJ
175
-55 ~ 175
°C
°C
Electrical Characteristics (TA=25°C Unless otherwise noted)
Symbol
Parameter
Test Conditions
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage VGS=0V,ID=250uA
Min.
Zero Gate Voltage Drain Current
VGS(th)
Gate Threshold Voltage
IGSS
Gate Leakage Current
1
RDS(on)
Drain-Source On-Resistance
Diode Characteristics
VSD1
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Dynamic Characteristics2
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(on)
Turn-On Delay Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Gate Charge Characteristics2
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
Max. Unit
80
ΔBVDSS/ΔTJ Breakdown Voltage Temp. Coe
IDSS
Typ
V
0.073
VDS=-24V,VGS=0V
TJ=85°C
VDS=VGS,ID=-250uA
VGS=±25V, VDS=0V
VGS=10V, ID=40A
2
3
7
ISD=20A,VGS=0V
ISD=40A,
dISD/dt=100A/us
0.8
50
90
VGS=0V, VDS=0V,
Frequency=1MHz
1.3
VGS=0V, VDS=30V
Frequency=1MHz
VDD=30V,RL=30Ω
ID=1A,VGEN=10V
RG=6Ω
VDS=40V,VGS=10V
ID=40A
1
30
4
±100
11
1.3
uA
V
nA
mΩ
V
ns
nC
Ω
3000
350
250
22
14
58
25
4200
77
22
23
108
pF
40
25
104
45
ns
nC
Note: 1: Pulse test ; pulse width ≦ 300ns, duty cycle ≦ 2%.
2: Guaranteed by design, not subject to production testing.
Page 2
GOFORD
8070
Typical Characteristics
Page 3
GOFORD
8070
Typical Characteristics (Cont.)
Page 4
GOFORD
8070
Page 5
很抱歉,暂时无法提供与“8070.0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.99314
- 50+1.51082
- 150+1.32419
- 500+1.09134
- 2000+0.98766
- 4000+0.92546
