SE80100GA
N-Channel Enhancement-Mode MOSFET
Revision: A
Features
General Description
Thigh Density Cell Design For Ultra Low
On-Resistance Fully Characterized Avalanche
Voltage and Current Improved Shoot-Through
For a single MOSFET
VDS = 80V
RDS(ON) = 6.0mΩ @ VGS=10
FOM
Simple Drive Requirement
Small Package Outline
Surface Mount Device
Pin configurations
See Diagram below
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
80
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Total Power Dissipation
Continuous
Pulsed
@TA=25℃
Operating Junction Temperature Range
ShangHai Sino-IC Microelectronic Co., Ltd.
ID
100
370
A
PD
125
W
TJ
-55 to 175
1.
SE80100GA
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
ID=250μA, VGS=0 V
IDSS
Drain to Source Leakage Current
VDS= 64V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS=20V
Gate Threshold Voltage
VDS= VGS, ID=250μA
VGS(th)
RDS(ON)
Static Drain-Source On-Resistance
2
VGS=10V, ID=40A
80
V
1.5
1
μA
100
nA
2.5
V
6.0
mΩ
4120
pF
520
pF
200
pF
58
nC
15
nC
19
nC
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V, VDS=40V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
f=1MHz
SWITCHING PARAMETERS
Qg
Total Gate Charge
VGS=10V,
VDS=64V,
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VGS=10V, VDS=40V,
34
ns
td(off)
Turn-Off Delay Time
RGEN=4.7Ω
103
ns
td(r)
Turn-On Rise Time
ID=2A
95
ns
td(f)
Turn-Off Fall Time
33
ns
ID=40A
Thermal Resistance
Symbol
RθJC
Parameter
Thermal Resistance Junction to Case(t≤10s)
Typ
Max
Units
1.2
℃/W
2.
SE80100GA
Typical Characteristics
3.
SE80100GA
4.
SE80100GA
Package Outline Dimension
TO-220
5.
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402
33932403
33932405
33933508
33933608
Fax: +86-21-33932401
Email: webmaster@sino-ic.net
Website: http://www.sino-ic.net
6.
很抱歉,暂时无法提供与“SE80100GA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.67300
- 10+2.16540
- 50+1.91700
- 100+1.66860
- 500+1.51740
- 1000+1.44180
