KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
1. Features
n
Proprietary New Planar Technology
n
RDS(ON)=50m Ω(typ.)@VGS=10V
n
Low Gate Charge Minimize Switching Loss
n
Fast Recovery Body Diode
2. Application
n
DC-DC Converters
n
DC-AC Inverters for UPS
n
SMPS and Motor controls
3. Pin configuration
1 of 8
Pin
Function
1
Gate
2
Drain
3
Source
4
Drain
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
4. Ordering Information
Part Number
Package
Brand
KNP9120A
TO-220
KIA
5. Absolute maximum ratings
(TC= 25ºC , unless otherwise specified)
Parameter
Drain-source voltage[1]
Gate-source voltage
Continuous Drain Current
Continuous Drain Current @Tc=100ºC
Pulsed Drain Current at VGS=10V[2]
Avalanche energy
Single pulse
Peak Diode Recovery dv/dt[3]
Power Dissipation
Derating Factor above 25 ºC
Maximum Temperature for Soldering
Leads at 0.063in(1.6mm) form Case for 10
Seconds
Storage temperature
Symbol
Rating
Units
VDSS
VGSS
ID
ID @
TC=100ºC
IDM
EAS
dv/dt[3]
200
±20
40
V
V
A
Figure3
A
Figure6
1200
5.0
125
1.0
A
mJ
V/ns
W
W/ºC
300
260
ºC
-55~+150
ºC
PD
TL
TPAK
TSTG
Caution: Stresses greater than those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device.
6. Thermal Characteristics
Symbol
RθJC
RθJA
Parameter
Thermal Resistance, Junction-to-Case
Thermal Resistance, Junction-to-Ambient
2 of 8
Rating
1.0
62
Rev 1.0 MAR 2017
Unit
ºC/W
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
7. Electrical characteristics
Parameter
Off characteristics
Drain-source breakdown voltage
Symbol
Drain-to-Source Leakage Current
IDSS
Gate-to-source Leakage Current
IGSS
Conditions
Min
Typ
Max
Unit
(TJ=25°C,unless otherwise specified)
VGS=0V,ID=250μA
200
V
VDS=200V ,VGS=0V
1
μA
VDS=160V , VGS=0V
100
μA
TJ=125 ºC
VGS=+20V, VDS=0V
+100
nA
VGS=-20V, VDS=0V
-100
nA
VDS=VGS, ID=250μA
2.0
4.0
V
BVDSS
On characteristics
Gate threshold voltage
VGS(TH)
Static drain-source on-resistance
RDS(ON)
VgS=10V,ID=20A
50
65
mΩ
GFS
VDS=15V,ID=20A
65
S
Forward Transconductance[4]
Dynamic characteristics
Input capacitance
Output capacitance
Reverse transfer capacitance
Turn-on delay time
Rise time
Turn-off delay time
Fall time
Switching characteristics
Total gate charge
Gate-source charge
Gate-drain charge
Drain-source diode forward voltage
Continuous drain-source current[4]
Pulsed drain-source current[4]
Reverse recovery time
Reverse recovery charge
(Essentially independent of operating temperature)
CISS
2800 3700
pF
VDS=25V,VGS=0V,
COSS
305
400
pF
f=1.0 MHz
CRSS
110
150
pF
tD(ON)
ns
tR
30
ns
VDD=100V,ID=20A,
RG=3.9Ω,VGS=10V
tD(OFF)
65
ns
tF
25
ns
97
120
nC
QG
VDD=100V,
QGS
ID=20A
14
nC
VGS=0 to10V
QGD
39
nC
VSD
VGS=0V, IS=40A
1.5
V
ISD
40
A
Integral PN-diode in
MOSFET
ISM
160
A
trr
280
ns
VGS=0V,IF=20A
diF/dt=100A/μs
Qrr
420
μC
NOTE:[1] TJ=+25ºC to +150ºC ;
[2] Repetitive rating; pulse width limited by maximum junction temperature;
[3] ISD= 20A di/dt < 100 A/μs, VDD < BVDSS, TJ=+150ºC;
[4] Pulse width≤380μs; duty cycle≤2%.
3 of 8
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
8.Test circuits and waveforms
4 of 8
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
5 of 8
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
6 of 8
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
7 of 8
Rev 1.0 MAR 2017
KIA
40A 200V
N-CHANNEL MOSFET
9120A
SEMICONDUCTORS
8 of 8
Rev 1.0 MAR 2017
很抱歉,暂时无法提供与“KNP9120A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.36320
- 10+3.55320
- 50+3.14280
