GOFORD
G120N04A
Description
The G120N04A uses advanced trench technology and
design to provide excellent RDS(ON) with low gate charge. It
can be used in a wide variety of applications.
General Features
VDSS
RDS(ON)
RDS(ON)
ID
5.5 mΩ
3.2mΩ
120 A
@ 4.5V(Typ) @10V (Typ)
40V
Schematic diagram
● High density cell design for ultra low Rdson
● Fully characterized avalanche voltage and current
● Good stability and uniformity with high EAS
● Excellent package for good heat dissipation
● Special process technology for high ESD capability
Marking and pin assignment
Application
● Load switching
● Hard switched and high frequency circuits
● Uninterruptible power supply
TO-220
Absolute Maximum Ratings (TC=25℃unless otherwise noted)
Symbol
Limit
Unit
Drain-Source Voltage
Parameter
VDS
40
V
Gate-Source Voltage
VGS
±20
V
ID
120
A
ID (100℃)
85
A
Pulsed Drain Current
IDM
330
A
Maximum Power Dissipation
PD
130
W
0.87
W/℃
EAS
1080
mJ
TJ,TSTG
-55 To 175
Drain Current-Continuous
Drain Current-Continuous(TC=100℃)
Derating factor
Single pulse avalanche energy
(Note 5)
Operating Junction and Storage Temperature Range
HTTP://www.gofordsemi.com TEL:0755-29961262 FAX:0755-29961466
Page 1
GOFORD
G120N04A
Thermal Characteristic
Thermal Resistance,Junction-to-Case(Note 2)
RθJC
1.15
℃/W
Electrical Characteristics (TC=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
40
45
V
Zero Gate Voltage Drain Current
IDSS
VDS=40V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=250μA
1.2
1.9
2.5
V
Drain-Source On-State Resistance
RDS(ON)
VGS=10V, ID=20A
3.2
4.0
VGS=4.5V, ID=10A
5.5
7.0
VDS=10V,ID=20A
26
S
5400
PF
970
PF
380
PF
15
nS
Off Characteristics
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
gFS
mΩ
(Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
VDS=20V,VGS=0V,
F=1.0MHz
Crss
(Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=20V,ID=2A,RL=1Ω
18
nS
td(off)
VGS=10V,RG=3Ω
52
nS
23
nS
75
nC
10.5
nC
17
nC
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=20V,ID=20A,
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage
(Note 3)
VSD
Diode Forward Current
(Note 2)
IS
Reverse Recovery Time
VGS=0V,IS=40A
trr
Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
1.2
V
120
A
TJ = 25°C, IF = 40A
42
nS
(Note3)
45
nC
di/dt = 100A/μs
Intrinsic turn-on time is negligible (turn-on is dominated by LS+LD)
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
5. EAS condition : Tj=25℃,VDD=20V,VG=10V,L=1mH,Rg=25Ω,IAS=46.5A
Page 2
GOFORD
G120N04A
Test circuit
1) EAS Test Circuit
2) Gate Charge Test Circuit
3) Switch Time Test Circuit
Page 3
GOFORD
G120N04A
ID- Drain Current (A)
Normalized On-Resistance
Typical Electrical and Thermal Characteristics (Curves)
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance(mΩ)
Vsd Source-Drain Voltage (V)
Figure 6 Source- Drain Diode Forward
Figure 3 Rdson- Drain Current
Page 4
GOFORD
C Capacitance (pF)
Power Dissipation (W)
G120N04A
TJ-Junction Temperature (℃)
Figure 7 Capacitance vs Vds
Figure 9 Power De-rating
Figure 8 Safe Operation Area
Figure 10 VGS(th) vs Junction Temperature
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
Page 5
很抱歉,暂时无法提供与“G120N04A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.26160
- 10+2.58120
- 50+2.06280
