BR13N50
BR13N50
    BLUEROCKET(蓝箭电子)
    TO-220-3
    N沟道MOSFET,电流:13A,耐压:500V
BR13N50 数据手册
BR13N50 Rev.F Jul.-2018 描述 / DATA SHEET Descriptions TO-220 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-220 Plastic Package. 特征 / Features 低的门槛电压、反向传输电容小、开关速度快。 Low gate charge, Low Crss , Fast switching. 用途 / Applications 用于小型化高效率的开关电源的 AC/DC 功率转换。 It is very suitable for various AC/DC power conversion in switching mode operatio for system miniaturization and higher efficiency. 内部等效电路 引脚排列 1 2 / Equivalent Circuit / Pinning 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S / hFE Classifications & Marking 见印章说明。 See Marking Instructions. http://www.fsbrec.com 1/6 BR13N50 Rev.F Jul.-2018 极限参数 DATA SHEET / Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 500 V Drain Current ID(Tc=25℃) 13 A Drain Current ID(Tc=100℃) 8 A IDM 52 A Gate-Source Voltage VGSS ±30 V Single Pulsed Avalanche Energy EAS 860 mJ Repetitive Avalanche Energy EAR 19.5 mJ Avalanche Current IAR 13 A Power Dissipation PD(Tc=25℃) 195 W TJ,TSTG -55 to 150 ℃ Drain-Source Voltage Drain Current - Pulsed Operating and Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Drain-Source Breakdown Voltage Zero Gate Voltage Drain Current Gate-Body Leakage Current, Forward Gate Threshold Voltage Static Drain-Source On-Resistance Forward Transconductance Drain-Source Diode Forward Voltage Input Capacitance 符号 测试条件 Symbol Test Conditions BVDSS VGS=0V ID=250μA VDS=500V VGS=0V 1.0 μA VDS=400V TC=125℃ 10 μA VGS=±30V VDS=0V ±0.1 μA VGS(th) VDS=VGS ID=250μA 4.0 V RDS(on) VGS=10V ID=6.5A 0.39 0.48 Ω gFS VDS=40V ID=6.5A 15 VSD VGS=0V IS=13A VDS=25V f=1.0MHz VGS=0V IDSS IGSS Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Turn-On Delay Time td(on) Turn-On Rise Time tr Turn-Off Delay Time td(off) Turn-Off Fall Time http://www.fsbrec.com 最小值 典型值 最大值 单位 Min Typ Max Unit 500 V tf VDD=300V RG=25Ω ID=13A 2.0 S 1.4 V 1580 2055 pF 180 235 pF 20 25 pF 25 60 ns 100 210 ns 130 270 ns 100 210 ns 2/6 BR13N50 Rev.F Jul.-2018 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BR13N50 Rev.F Jul.-2018 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BR13N50 Rev.F Jul.-2018 印章说明 / DATA SHEET Marking Instructions BR **** 13N50 说明: BR: 为公司代码 13N50:  为型号代码 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   13N50: ****: http://www.fsbrec.com Product Type.  Lot No. Code, code change with Lot No. 5/6 BR13N50 Rev.F Jul.-2018 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 TO-220/F 套管包装 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 散件包装 TO-220/F 时间:10±1 sec. / BULK Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 Inner Box 盒 Outer Box 箱 200 10 2,000 5 10,000 135×190 237×172×102 560×245×195 Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×31.4×5.5 555×164×50 575×290×180 / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) / Notices http://www.fsbrec.com 6/6
BR13N50 价格&库存
很抱歉,暂时无法提供与“BR13N50”相匹配的价格&库存,您可以联系我们找货
