STP30NF20-VB
STP30NF20-VB
    VBSEMI(微碧)
    TO-220-3
    类型:N沟道;漏源电压(Vdss):200V;连续漏极电流(Id):40A;功率(Pd):-;导通电阻(RDS(on)@Vgs,Id):60mΩ@10V,40A;阈值电压(Vgs(th)@Id):-;...
STP30NF20-VB 数据手册
STP30NF20 www.VBsemi.com N-Channel 200 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) RDS(on) (:) 200 0.058at VGS = 10 V • • • • ID (A) 35 TrenchFET® Power MOSFETS 175 °C Junction Temperature New Low Thermal Resistance Package Compliant to RoHS Directive 2002/95/EC RoHS COMPLIANT APPLICATIONS • Industrial TO-220AB D G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) Symbol Limit Drain-Source Voltage Parameter VDS 200 Gate-Source Voltage VGS ± 20 Continuous Drain Current (TJ = 175 °C) TC = 25 °C TC = 125 °C Pulsed Drain Current Avalanche Current Repetitive Avalanche Energya Maximum Power Dissipationa Operating Junction and Storage Temperature Range L = 0.1 mH TC = 25 °C TA = 25 °C c ID V 35 23 IDM 70 IAR 35 EAR 61 PD Unit A mJ b 300 3.75 W TJ, Tstg - 55 to 175 °C Symbol Limit Unit THERMAL RESISTANCE RATINGS Parameter Junction-to-Ambient (PCB Mount)c Junction-to-Case (Drain) RthJA 40 RthJC 0.5 °C/W Notes: a. Duty cycle  1 %. b. See SOA curve for voltage derating. c. When mounted on 1" square PCB (FR-4 material). 服务热线:400-655-8788 1 STP30NF20 www.VBsemi.com SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min . VDS VDS = 0 V, ID = 250 µA 200 VGS(th) VDS = VGS, ID = 250 µA 2 IGSS VDS = 0 V, VGS = ± 30 V Typ. Max. Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current On-State Drain Currenta IDSS a Forward Transconductance ± 250 VDS = 200 V, VGS = 0 V 1 VDS = 200 V, VGS = 0 V, TJ = 125 °C 50 VDS = 200 V, VGS = 0 V, TJ = 175 °C 250 ID(on) Drain-Source On-State Resistancea 4 VDS 5 V, VGS = 10 V RDS(on) gfs 70 V nA µA A VGS = 10 V, ID = 20 A 0.058 VGS = 10 V, ID = 20 A, TJ = 125 °C 0.130 VGS = 10 V, ID = 20 A, TJ = 175 °C 0.170 VGS = 6 V, ID = 15 A 0.070 VDS = 15 V, ID = 20 A 70  S Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Chargec Qg c Gate-Source Charge Qgs Gate-Drain Chargec Qgd Gate Resistance Turn-On Delay Timec Rise Timec Turn-Off Delay Timec Fall Timec 2690 VGS = 0 V, VDS = 25 V, f = 1 MHz 200 pF 110 95 VDS = 100 V, VGS = 10 V, ID = 45 A Rg td(off) nC 28 34 f = 1 MHz 1.6 22 35 VDD = 100 V, RL = 2.78  ID  45 A, VGEN = 10 V, Rg = 2.5  220 330 40 60 145 220 td(on) tr 140 tf  ns Source-Drain Diode Ratings and Characteristics (TC = 25 °C)b IS 45 Pulsed Current ISM 70 Forward Voltagea VSD Continuous Current Reverse Recovery Time Peak Reverse Recovery Current Reverse Recovery Charge IF = 45 A, VGS = 0 V trr IRM(REC) Qrr IF = 45 A, di/dt = 100 A/µs A 1 1.5 V 150 225 ns 12 18 A 0.9 2 µC Notes: a. Pulse test; pulse width  300 µs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 STP30NF20 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 100 VGS = 10 thru 7 V 5V 80 I D - Drain Current (A) I D - Drain Current (A) 80 60 40 20 3V 0 2 4 6 8 40 TC = 125 °C 20 4V 0 60 25 °C - 55 °C 0 10 0 1 2 3 4 5 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 6 0.10 150 120 25 °C 90 RDS(on) - On-Resistance () g fs - Transconductance (S) TC = - 55 °C 125 °C 60 30 0.06 VGS = 10 V 0.04 0.02 0.00 0 0 10 20 30 40 50 0 60 20 40 60 80 ID - Drain Current (A) ID - Drain Current (A) Transconductance On-Resistance vs. Drain Current 3500 100 20 V GS - Gate-to-Source Voltage (V) 3000 C - Capacitance (pF) 0.08 Ciss 2500 2000 1500 1000 Crss 500 Coss 0 VDS = 100V ID = 45 A 16 12 8 4 0 0 40 80 120 160 200 0 30 60 90 120 VDS - Drain-to-Source Voltage (V) Qg - Total Gate Charge (nC) Capacitance Gate Charge 150 180 服务热线:400-655-8788 3 STP30NF20 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 VGS = 10 V ID = 20 A 2.4 I S - Source Current (A) R DS(on) - On-Resistance (Normalized) 2.8 2.0 1.6 1.2 TJ = 150 °C 10 TJ = 25 °C 0.8 0.4 - 50 - 25 0 25 50 75 100 125 150 1 0 175 0.3 TJ - Junction Temperature (°C) 0.6 0.9 1.2 VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage 100 300 290 ID = 1.0 mA 280 I Dav (A) 10 V DS (V) IAV (A) at TA = 25 °C 1 270 260 250 240 IAV (A) at TA = 150 °C 0.1 0.00001 0.0001 0.001 0.01 0.1 tin (s) Avalanche Current vs. Time 1 230 - 50 - 25 0 25 50 75 100 125 150 175 TJ - Junction Temperature (°C) Drain Source Breakdown vs. Junction Temperature 服务热线:400-655-8788 4 STP30NF20 www.VBsemi.com THERMAL RATINGS 100 50 10 I D - Drain Current (A) 40 I D - Drain Current (A) 10 µs *Limited by rDS(on) 30 20 10 100 µs 1 ms 1 10 ms, 100 ms, dc 0.1 TC = 25 °C Single Pulse 0.01 0.001 0 0 25 50 75 100 125 150 175 0.1 TC - Ambient Temperature (°C) Maximum Avalanche and Drain Current vs. Case Temperature 100 1 10 1000 VDS - Drain-to-Source Voltage (V) *VGS > minimum V GS at which rDS(on) is specified Safe Operating Area, Case Temperature 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10- 4 10- 3 10- 2 10- 1 1 Square Wave Pulse Duration (sec) Normalized Thermal Transient Impedance, Junction-to-Case 服务热线:400-655-8788 5 STP30NF20 www.VBsemi.com TO-220AB MILLIMETERS A E F D H(1) Q ØP 3 2 L(1) 1 M* L b(1) INCHES MAX. DIM. MIN. MAX. MIN. A 4.25 4.65 0.167 0.183 b 0.69 1.01 0.027 0.040 b(1) 1.20 1.73 0.047 0.068 c 0.36 0.61 0.014 0.024 D 14.85 15.49 0.585 0.610 D2 12.19 12.70 0.480 0.500 E 10.04 10.51 0.395 0.414 e 2.41 2.67 0.095 0.105 e(1) 4.88 5.28 0.192 0.208 0.055 F 1.14 1.40 0.045 H(1) 6.09 6.48 0.240 0.255 J(1) 2.41 2.92 0.095 0.115 0.552 L 13.35 14.02 0.526 L(1) 3.32 3.82 0.131 0.150 ØP 3.54 3.94 0.139 0.155 Q 2.60 3.00 0.102 0.118 ECN: T14-0413-Rev. P, 16-Jun-14 DWG: 5471 b Note * M = 1.32 mm to 1.62 mm (dimension including protrusion) Heatsink hole for HVM C e J(1) e(1) D2 服务热线:400-655-8788 6 STP30NF20 Disclaimer www.VBsemi.com All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. 7
