HSP6016
HSP6016
    HUASHUO(华朔)
    TO-220-3
    1个N沟道 耐压:60V 电流:60A
HSP6016 数据手册
HSP6016 N-Ch 60V Fast Switching MOSFETs Description Product Summary The HSP6016 is the high cell density trenched Nch MOSFETs, which provide excellent RDSON VDS 60 V and gate charge for most of the synchronous RDS(ON),max 12 mΩ ID 60 A buck converter applications. The HSP6016 meet the RoHS and Green Product requirement, 100% EAS guaranteed with full function reliability approved. l l l l l Super Low Gate Charge 100% EAS Guaranteed Green Device Available Excellent CdV/dt effect decline Advanced high cell density Trench technology TO220 Pin Configuration Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage 60 V VGS Gate-Source Voltage ID@TC=25℃ ID@TC=100℃ ID@TA=25℃ ID@TA=70℃ IDM ±20 V Continuous Drain Current, VGS @ 10V 1 60 A Continuous Drain Current, VGS @ 10V 1 38 A Continuous Drain Current, VGS @ 10V 1 9.2 A Continuous Drain Current, VGS @ 10V 1 7.5 A 165 A 73 mJ Pulsed Drain Current 2 EAS Single Pulse Avalanche Energy IAS Avalanche Current 3 38 A 86.8 W 2 W PD@TC=25℃ Total Power Dissipation 4 PD@TA=25℃ Total Power Dissipation 4 TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter Typ. RθJA Thermal Resistance Junction-Ambient RθJC 1 www.hs-semi.cn Thermal Resistance Junction-Case Ver 2.0 1 Max. Unit --- 62 ℃/W --- 1.44 ℃/W 1 HSP6016 N-Ch 60V Fast Switching MOSFETs Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Conditions Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) Static Drain-Source On-Resistance VGS(th) Gate Threshold Voltage 2 Min. Typ. Max. Unit VGS=0V , ID=250uA 60 --- --- V Reference to 25℃ , ID=1mA --- 0.052 --- V/℃ VGS=10V , ID=30A --- --- 12 VGS=4.5V , ID=15A --- --- 15 1.2 --- 2.5 V --- -5.76 --- mV/℃ VDS=48V , VGS=0V , TJ=25℃ --- --- 1 VDS=48V , VGS=0V , TJ=55℃ --- --- 5 VGS=VDS , ID =250uA mΩ △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=5V , ID=30A --- 42 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.5 --- Ω Qg Total Gate Charge (4.5V) --- 28.7 --- Qgs Gate-Source Charge --- 10.5 --- Qgd Gate-Drain Charge --- 9.9 --- Td(on) VDS=48V , VGS=4.5V , ID=15A nC --- 10.4 --- Rise Time VDD=30V , VGS=10V , RG=3.3Ω, --- 9.2 --- Turn-Off Delay Time ID=15A --- 63 --- Fall Time --- 4.8 --- Ciss Input Capacitance --- 3240 --- Coss Output Capacitance --- 210 --- Crss Reverse Transfer Capacitance --- 146 --- Min. Typ. Max. Unit --- --- 60 A --- --- 165 A Tr Td(off) Tf Turn-On Delay Time uA VDS=15V , VGS=0V , f=1MHz ns pF Diode Characteristics Symbol IS ISM Parameter Conditions 1,5 Continuous Source Current Pulsed Source Current 2,5 VG=VD=0V , Force Current VSD Diode Forward Voltage 2 VGS=0V , IS=A , TJ=25℃ --- --- 1.2 V trr Reverse Recovery Time IF=15A , dI/dt=100A/µs , --- 18 --- nS Qrr Reverse Recovery Charge TJ=25℃ --- 14 --- nC Note : 2 1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=38A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. www.hs-semi.cn Ver 2.0 2 HSP6016 N-Ch 60V Fast Switching MOSFETs Typical Characteristics 11.5 150 ID=12A VGS=10V 11.0 VGS=7V 100 RDSON (mΩ) ID Drain Current (A) 125 VGS=5V VGS=4.5V 75 10.5 VGS=3V 50 10.0 25 0 9.5 0 1 2 3 4 VDS , Drain-to-Source Voltage (V) 5 4 Fig.1 Typical Output Characteristics 6 VGS (V) 8 10 Fig.2 On-Resistance v.s Gate-Source 12 IS Source Current(A) 10 8 6 TJ=150℃ TJ=25℃ 4 2 0 0.2 0.4 0.6 0.8 1 VSD , Source-to-Drain Voltage (V) Fig.3 Forward Characteristics of Reverse Fig.4 Gate-Charge Characteristics 2.0 Normalized On Resistance Normalized VGS(th) 1.5 1.5 1 1.0 0.5 0.5 0 -50 0 50 100 TJ ,Junction Temperature ( ℃) -50 150 Fig.5 Normalized VGS(th) v.s TJ www.hs-semi.cn 0 50 100 150 TJ , Junction Temperature (℃) Fig.6 Normalized R DSON v.s TJ Ver 2.0 3 HSP6016 N-Ch 60V Fast Switching MOSFETs 10000 1000.00 F=1.0MHz Capacitance (pF) 10us 100us 100.00 Ciss 1000 10.00 ID (A) Coss 100 10ms 100ms DC 1.00 Crss 0.10 TC=25℃ Single Pulse 0.01 10 1 5 9 13 17 VDS Drain to Source Voltage(V) 21 0.1 25 Fig.7 Capacitance 1 10 100 VDS (V) 1000 Fig.8 Safe Operating Area Normalized Thermal Response (RθJC) 1 DUTY=0.5 0.3 0.1 0.1 0.05 PDM T 0.02 D = TON/T 0.01 0.01 0.00001 TON TJpeak = TC + PDM x RθJC SINGLE PULSE 0.0001 0.001 0.01 0.1 1 10 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance EAS= VDS 90% Td(on) Tr Ton Td(off) VDD IAS Tf VGS Toff Fig.10 Switching Time Waveform www.hs-semi.cn BVDSS BVDSS-VDD BVDSS 10% VGS 1 L x IAS2 x 2 Fig.11 Unclamped Inductive Switching Ver 2.0 4
HSP6016 价格&库存
很抱歉,暂时无法提供与“HSP6016”相匹配的价格&库存,您可以联系我们找货
