10N50TF
10N50TF
    PINGWEI(平伟)
    TO-220-3
    10N50TF
10N50TF 数据手册
10N50TF 10 Amps,500 Volts N-CHANNEL Power MOSFET FEATURE TO-220TF 10A,500V,RDS(ON)MAX=0.75Ω@VGS=10V/5A Low gate charge Low Ciss Fast switching 100% avalanche tested Improved dv/dt capability  Halogen free       Absolute Maximum Ratings(TC=25℃,unless otherwise noted) Symbol 10N50TF Drain-Source Voltage VDSS 500 Gate-Source Voltage VGSS ±30 Continuous Drain Current ID 10 Pulsed Drain Current(Note1) IDM 40 Single Pulse Avalanche Energy (Note 2) EAS 580 mJ dv/dt 5 V/ns TJ,TSTG -55to+150 ℃ TL 260 ℃ 10 lbf·in 1.1 N·m Parameter Reverse Diode dV/dt (Note 3) Operating Junction and Storage Temperature Range Maximum lead temperature for soldering purposes, 1/8"from case for 5 seconds Mounting Torque 6-32 or M3 screw UNIT V A Parameter Symbol 10N50TF Units Thermal resistance , Channel to Case Rth(ch-c) 3.13 ℃/W Thermal resistance , Channel to Ambient Rth(ch-a) 62.5 ℃/W PD 40 W Maximum Power Dissipation TC=25℃ http:// www.perfectway.cn Electrical Characteristics (Tc=25℃,unless otherwise noted) Parameter Off Characteristics Drain-Source Breakdown Voltage Breakdown Temperature Coefficient Symbol BVDSS Test Conditions VGS=0V,ID=250uA ΔBVDSS Reference /ΔTJ ID=250uA to 25℃ , Min Typ Max Units 500 - - V - 0.6 - V/℃ Zero Gate Voltage Drain Current IDSS VDS=500V,VGS=0V - - 1 uA Gate-Body Leakage Current,Forward IGSSF VGS=30V,VDS=0V - - 100 nA Gate-Body Leakage Current,Reverse IGSSR VGS=-30V,VDS=0V - - -100 nA On Characteristics Gate-Source Threshold Voltage VGS(th) VDS=VGS,ID=250uA 2 - 4 V Drain-Source On-State Resistance RDS(on) VGS=10V,ID=5A - 0.5 0.75 Ω Dynamic Characteristics Input Capacitance Ciss VDS=25V,VGS=0V, - 1620 - pF Output Capacitance Coss f=1.0MHZ - 154 - pF Reverse Transfer Capacitance Crss - 8.4 - pF Switching Characteristics Turn-On Delay Time td(on) VDD=250V,ID=10A, - 26 - ns tr RG=10Ω (Note3,4) - 20 - ns td(off) - 52 - ns Turn-Off Fall Time tf - 21 - ns Total Gate Charge Qg VDS=400V,ID=10A, - 32 - nC Gate-Source Charge Qgs VGS=10V, (Note3,4) - 7.9 - nC Gate-Drain Charge Qgd - 12 - nC IS - - 10 A Pulsed Diode Forward Current ISM - - 40 A Diode Forward Voltage VSD IS=10A,VGS=0V - - 1.5 V Reverse Recovery Time trr VGS=0V,IS=10A, - 411 - ns Reverse Recovery Charge Qrr dIF/dt=100A/us, - 2.588 - uC Turn-On Rise Time Turn-Off Delay Time Drain-Source Body Diode Charcteristics and Maximum Ratings Continuous Diode Forward Current (Note4) Notes 1. Repetitive Rating:pulse width limited by maximum junction temperature. 2. L=10mH,IAS=10.8A , starling TJ=25℃. 3. ISD=10A,dI/dt≤100A/us,VDD≤BVDSS,starting TJ=25℃,Pulse width≤300us;duty cycle≤2%. 4. Repetitive rating; pulse width limited by maximum junction temperature. http:// www.perfectway.cn TEST CIRCUIT AND WAVEFORM http:// www.perfectway.cn http:// www.perfectway.cn RATINGAND CHARACTERISTIC CURVES 10 Vgs=10V TJ =25℃ 24 VGS,Gate-to-Source Voltage(V) ID,Drain-to-Source Current(A) 32 7V 6V 16 5V 8 4.5V 0 0 5 10 15 20 VDS,Drain-to-Source Voltage(V) 2 0 0 8 24 16 32 Qg ,Total Gate Charge(nC) 40 TJ =25℃ Capacitance(pF) TJ =150℃ 1 VGS =0V 0.2 0.4 0.6 0.8 1.0 1.2 VDS,Source-Drain Voltage(V) 100 10 1 1.4 0.1 700 3 650 2.5 600 550 500 450 400 -60 -40 -20 0 25 50 75 100 125 150 175 Tj,Juntion Temperature(℃) Ciss 1000 RDS(ON) , Rrain-Source On-Resistance ,Nomalized ISD , Reverse Drain Current(A) 4 10000 10 0.1 VDS=400V 6 25 100 Vds, Drain-to-Source Brakdown Voltage(V) 8 Coss Crss 100 1 10 VDS,Drain-to-Source Voltage(V) 1000 50 25 75 100 125 Tj,Juntion Temperature(℃) 150 2 1.5 1 0.5 0 0 http:// www.perfectway.cn 10 10 100μs 1 Limited by RDS(on) 1ms 10ms RDS(ON) , Rrain-Source On-Resistance (Ω) ID, Drain Current(A) Operation in this Area Limited by RDS(on) IDM=Limited 100 0.1 TC=25℃ DC TJ=150℃ BVDSS Limited Single Pulse 0.01 1 10 100 1000 VDS,Drain-to-Source Voltage(V) VTH , Gate Threshold Voltage(V) EAS , Avalanche Energy(mJ) 450 300 150 Nomalized Effective Transient Thermal Impedance VGS =10V 1 10 ID, Drain Current(A) 100 5 600 4 3 2 1 0 -80 25 50 75 100 125 150 TCH , Channel Temperature(Initial) (℃) 1 1 0.1 0.1 750 0 Common Source Tc=25℃ Pulse Test Common Source VDS=10V ID=1mA Pulse Test -40 0 40 80 120 TC, Case Temperature(℃) 140 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 0.01 0.0001 Single Pulse 0.001 0.01 0.1 1 10 Pulse Time(s) http:// www.perfectway.cn PACKAGE OUTLINE DIMENSIONS TO-220TF B L G I C H A PIN 1 2 D 3 E J F P K TO-220TF Min Max A .590(15.0) .650(16.5) B .393(10.0) .414(10.5) C .118(3.00) .138(3.50) D .118(3.00) .146(3.70) E .512(13.0) .551(14.0) F .028(0.70) .035(0.90) G .114(2.90) .138(3.50) H .255(6.50) .280(7.10) I .173(4.40) .197(5.00) J .102(2.60) .110(2.80) K .018(0.45) .026(0.65) L .092(2.35) .109(2.75) P .890(2.25) .113(2.85) Dim http:// www.perfectway.cn
10N50TF 价格&库存
很抱歉,暂时无法提供与“10N50TF”相匹配的价格&库存,您可以联系我们找货
