BTA08-600CRG
BTA08-600CRG
    JSMSEMI(杰盛微)
    TO-220-3
    Triac, 600V, 8A, To-220Ab; Peak Repetitive Off State Voltage:600V; On State Rms Current:8A; Triac Ca...
BTA08-600CRG 数据手册
BTA08-600B/CRG 8A Snubberless Triacs ct or FEATURES ·With TO-220AB non insulated package ·Suitables for general purpose AC switching. Which can be used as an ON/OFF function in applications such as static relays, heating regulation,induction motor starting circuits. Or for phase control operation in light dimmers, motor speed controllers etc. ABSOLUTE MAXIMUM RATINGS(Ta=25℃) Repetitive peak off-state voltage VRRM Repetitive peak off-state voltage IT(RMS) RMS on-state current (full sine wave) ITSM Non-repetitive peak on-state current Tstg Operating junction temperature Storage temperature 600 V 600 V 8 A 80 A 125 ℃ -40~150 ℃ em Tj UNIT tp=20ms ic VDRM MIN du PARAMETER on SYMBOL Thermal resistance, junction to case 2.4 ℃/W Rth(j-a) Thermal resistance, junction to ambient 60 ℃/W  S Rth(j-c) SYMBOL IRRM PARAMETER IGT CONDITIONS Repetitive peak reverse current Repetitive peak off-state current JS IDRM MI CR O ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise specified) VR=VRRM, VR=VRRM, Tj=110℃ VD=VDRM, VD=VDRM, Tj=110℃ Ⅰ Ⅱ B C 0.01 0.5 0.01 0.5 0.01 0.5 0.01 0.5 50 25 50 25 VD=12V; RL= 30Ω Gate trigger current UNIT mA mA mA Ⅲ 50 25 Ⅳ 100 50 50 25 IH Holding current IGT= 0.5A, Gate Open VGT Gate trigger voltage all quadrant VD=12V; RL= 30Ω 1.3 V VTM On-state voltage IT= 11A; tp= 380μs 1.55 V www.jsmsemi.com mA 第1/2页 BTA08-600B/CRG 8A Snubberless Triacs  S em ic on du ct or AB Max A 9.8 10.4 0.385 0.409 B 2.65 3.1 0.104 0.122 C 2.8 4.2 0.110 0.165 D 0.7 0.92 0.027 0.036 E 3.75 3.95 0.147 0.155 F 14.8 16.1 0.582 0.633 G 13.05 13.6 0.513 0.535 H 2.4 2.7 0.094 0.106 I 4.38 4.61 0.172 0.181 J 1.15 1.36 0.045 0.053 K 5.85 6.82 0.230 0.268 L 2.35 2.75 0.092 0.108 M 0.35 0.65 0.013 0.025 N 1.18 1.42 0.046 0.055 Dimensions In Millimeters Min JS MI CR O Symbol www.jsmsemi.com Dimensions In Inches Min Max 第2/2页
BTA08-600CRG 价格&库存
很抱歉,暂时无法提供与“BTA08-600CRG”相匹配的价格&库存,您可以联系我们找货
