BTA08-600TWRG
BTA08-600TWRG
    JSMSEMI(杰盛微)
    TO-220-3
    Triac, 800V, 8A, To-220Ab; Peak Repetitive Off State Voltage:600V; On State Rms Current:8A; Triac Ca...
BTA08-600TWRG 数据手册
BTA08-600TWRG 8A Snubberless Triacs FEATURES ·With TO-220AB insulated package ·Suitables for general purpose AC switching . which can be used as an ON/OFF function in applications such as static relays, heating regulation, Induction motor starting circuits or for phase control in light dimmers, motor speed controllers etc. ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL VRRM ITSM V 600 V RMS on-state current (full sine wave)Tj=105℃ 8 A Non-repetitive peak on-state current tp=20ms 80 A Operating junction temperature 110 ℃ -45~150 ℃ 2.5 ℃/W 60 ℃/W Repetitive peak reverse voltage Storage temperature O Tstg UNIT 600 CR Tj Repetitive peak off-state voltage MI IT(RMS) MIN JS VDRM PARAMETER Thermal resistance, junction to case Rth(j-a) Thermal resistance, junction to ambient mi Se Rth(j-c) co ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise specified) PARAMETER IRRM Repetitive peak reverse current IDRM Repetitive peak off-state current IGT Gate trigger current IH Holding current VGT Gate trigger voltage VTM On-state voltage CONDITIONS Ⅰ-Ⅱ-Ⅲ Ⅰ-Ⅱ-Ⅲ VR =VRRM, V R=VRRM, Tj=110℃ VD=VDRM, VD=VDRM, Tj=110℃ MAX 0.01 0.5 0.01 0.5 r to uc nd SYMBOL UNIT mA mA VD=12V; RL= 30Ω 5 mA IGT= 0.1A, Gate Open 10 mA VD=12V; RL= 30Ω 1.3 V IT= 11A; tp= 380μs 1.55 V www.jsmsemi.com 第1/2页 BTA08-600TWRG 8A Snubberless Triacs  S mi Se em ic O CR on MI du JS ct or AB Dimensions In Millimeters Max A 9.8 10.4 B 2.65 3.1 C 2.8 4.2 D 0.7 0.92 E 3.75 3.95 F 14.8 16.1 G 13.05 13.6 H 2.4 I Min Max 0.385 0.409 r to uc nd JS MI CR O Min co Symbol Dimensions In Inches 0.104 0.122 0.110 0.165 0.027 0.036 0.147 0.155 0.582 0.633 0.513 0.535 2.7 0.094 0.106 4.38 4.61 0.172 0.181 J 1.15 1.36 0.045 0.053 K 5.85 6.82 0.230 0.268 L 2.35 2.75 0.092 0.108 M 0.35 0.65 0.013 0.025 N 1.18 1.42 0.046 0.055 www.jsmsemi.com 第2/2页
BTA08-600TWRG 价格&库存
很抱歉,暂时无法提供与“BTA08-600TWRG”相匹配的价格&库存,您可以联系我们找货
