MP18N20
1
Description
MP18N20, the silicon N-channel Enhanced
MOSFETs, is obtained by advanced MOSFET
technology which reduce the conduction loss,
improve switching performance and enhance the
avalanche energy. The transistor is suitable
device for SMPS, high speed switching and
general purpose applications.
KEY CHARACTERISTICS
Parameter
Value
Unit
V DS
200
V
ID
18
A
R DS(ON).Typ
0.13
Ω
FEATURES
Fast Switching
Low Crss
100% avalanche tested
Improved dv/dt capability
RoHS product
APPLICATIONS
High frequency switching mode power supply
ORDERING INFORMATION
Ordering Codes
Package
MP18N20
TO-220
MPF18N20
TO-220F
MDP18N20
TO-251
MDT18N20
TO-252
Product Code
18N20
Packing
Tube
Tube
Tube
Tape Reel
MP18N20
XXXX:Product Code
(2) Package type
(1) Chip name
(1)MP18N20:200V 18A
(2) TO-220F TO-220
TO-251 TO-252
SHENZHEN MINOS TECHNOLOGY CO.,LTD
XXXX
YYWW ZZ
SSSSS
YYWW : Year&Week
ZZ : Assembly Code
SSSSS : Lot Code
www.mns-kx.com
MP18N20
2
ABSOLUTE RATINGS
at TC = 25°C, unless otherwise specified
Symbol
Parameter
V DSS
Drain-to-Source Voltage
ID
I DM
V GS
E AS
dv/dt
PD
PD
Rating
Units
200
18
11
72
±30
580
5.0
V
A
A
A
V
mJ
V/ns
130
W
Derating Factor above 25°C
1.2
W/℃
Power Dissipation
TO-220F
42
W
0.33
W/℃
150,–55 to 150
300
Continuous Drain Current
Continuous Drain Current T C = 100 °C
Pulsed Drain Current(Note1)
Gate-to-Source Voltage
Single Pulse Avalanche Energy(Note2)
Peak Diode Recovery dv/dt(Note3)
Power Dissipation
TO-220, TO-251,TO-252
3
T J ,T stg
Operating Junction and Storage Temperature Range
TL
Maximum Temperature for Soldering
Thermal characteristics
Thermal characteristics (No FullPAK) TO-220\TO-251\TO-252
Symbol
Parameter
RATINGS
Units
R θJC
Junction-to-Case
0.84
℃/W
R θJA
Junction-to-Ambient
62.5
℃/W
RATINGS
Units
3.0
℃/W
62.5
℃/W
Thermal characteristics (FullPAK) TO-220F
Symbol
Parameter
R θJC
Junction-to-Case
R θJA
Junction-to-Ambient
www.mns-kx.com
MP18N20
4
Electrical Characteristics
OFF Characteristics
Values
Symbol
Parameter
Test
Conditions
Mi n.
T yp.
Max.
V DSS
Drain to Source Breakdown
Voltage
V GS =0V,
I D =250µA
200
ΔBV DSS /Δ
TJ
Bvdss Temperature
Coefficient
ID=250uA,
Reference25℃
0.25
V/℃
1
µA
Drain to Source Leakage
Current
V DS =200V,
V GS = 0V,
Tj = 25℃
V DS =160V,
V GS = 0V,
Tj = 125℃
100
µA
V GS =+30V
100
nA
V GS =-30V
-100
nA
I DSS
I GSS(F)
I GSS(R)
Gate to Source Forward
Leakage
Gate to Source Reverse
Leakage
Units
V
ON Characteristics
Symbol
Parameter
Test Conditions
R DS(ON)
Drain-to-Source OnResistance
VGS=10V,
ID=7.5A(Note4)
V GS(TH)
Gate Threshold Voltage
VDS = VGS,
ID = 250µA(Note4)
g fs
Forward Transconductance
VDS=15V,
ID =9A(Note4)
Values
Min.
Typ.
Max.
0.13 0.18
Units
Ω
2.0
4.0
V
12
S
Dynamic Characteristics
Symbol
Parameter
Test Conditions
Rg
C iss
C oss
Gate resistance
f = 1.0MHz
C rss
Reverse Transfer
Capacitance
Input Capacitance
Output Capacitance
VGS = 0V
VDS = 25V
f = 1.0MHz
Values
Min.
Typ.
Max.
2
1320
450
130
Units
Ω
PF
www.mns-kx.com
MP18N20
Switching Characteristics
Symbol
Parameter
t d(ON)
Tr
t d(OFF)
tf
Qg
Q gs
Q gd
Turn-on Delay Time
Rise Time
Turn-Off Delay Time
Test Conditions
ID =18A
VDD = 100V
VGS = 10V
RG =20Ω
Fall Time
Total Gate Charge
Gate to Source Charge
Gate to Drain (“Miller”)Charge
ID =18A
VDD =160V
VGS = 10V
Values
Mi n.
T yp.
Max.
15
52
46
37
23
8
6
Units
ns
nC
Source-Drain Diode Characteristics
Symbol
Parameter
Test
Conditions
IS
TC=25 °C
I SM
Continuous Source Current (Body
Diode)
Maximum Pulsed Current (Body
Diode)
V SD
Diode Forward Voltage
T rr
Reverse Recovery Time
Q rr
Reverse Recovery Charge
IS=18A,
VGS=0V(Note4)
IS=18A,
Tj = 25°C
dIF/dt=100A/us,
VGS=0V
Values
Units
Mi n.
T yp.
Max.
18
A
72
A
1.2
V
350
ns
3600
nC
Note1: Pulse width limited by maximum junction temperature
Note2: L=2.7mH, VDs=50V, Start TJ=25℃
Note3: ISD =18A,di/dt ≤100A/us,VDD≤BVDS, Start TJ=25℃
Note4: Pulse width tp≤300µs, δ≤2%
www.mns-kx.com
MP18N20
5. Characteristics Curves
Figure 1a Safe Operating Area (No FullPAK)
Figure 1b Safe Operating Area (FullPAK)
Figure 2a Power Dissipation (No FullPAK)
Figure 2b Power Dissipation (FullPAK)
www.mns-kx.com
MP18N20
Figure 3a Max Thermal Impendance (No FullPAK)
Figure 4 Typical Output Characteristics
Figure 3b Max Thermal Impendance (FullPAK)
Figure 5 Typical Transfer Characteristics
www.mns-kx.com
MP18N20
Figure 6 Typical Drain to Source ON Resistance
vs Drain Current
Figure 7 Typical Drian to Source on Resistance
vs Junction Temperature
Figure 8 Typical Theshold Voltage vs Junction
Temperature
Figure 9 Typical Breakdown Voltage vs Junction
Temperature
www.mns-kx.com
MP18N20
Figure 10 Capacitance Characteristics
Figure 11 Gate Charge Characteristics
www.mns-kx.com
MP18N20
6. Test Circuit and Waveform
Figure 12 Gate Charge Test Circuit
Figure 13 Gate Charge Waveforms
Figure 14 Resistive Switching Test Circuit
Figure 15 Resistive Switching Waveforms
www.mns-kx.com
MP18N20
Figure 16 Diode Reverse Recovery Test Circuit
Figure 17 Diode Reverse Recovery Waveform
Figure 18 Unclamped Inductive Switching Test Circuit
Figure 19 Unclamped Inductive Switching Waveform
www.mns-kx.com
MP18N20
7. Package Description
C
A
D
G
C1
E
F
N
Items
N
Values(mm)
MIN
MAX
A
9.60
10.4
B
B1
C
C1
15.4
8.90
4.30
2.10
2.40
16.2
9.50
4.90
3.00
3.00
L
0.60
0.30
1.12
3.40
1.60
12.0
1.00
0.60
1.42
3.80
2.90
14.0
N
Q
2.34
3.15
2.74
3.55
2.90
3.30
D
E
F
G
H
TO-220F Package
www.mns-kx.com
MP18N20
Values(mm)
Items
MIN
MAX
A
9.60
10.6
B
B1
C
C1
D
E
F
G
H
L
N
Q
15.0
8.90
4.30
2.30
1.20
0.70
0.30
1.17
2.70
12.6
2.34
2.40
3.50
16.0
9.50
4.80
3.10
1.40
0.90
0.60
1.37
3.80
14.8
2.74
3.00
3.90
TO-220
Package
www.mns-kx.com
MP18N20
Items
A
B
B1
B2
C
D
E
F
G
H
L*
M
N
MIN
6.30
5.70
1.00
6.80
2.10
0.30
0.50
0.30
0.70
1.60
3.9
5.10
2.09
Values(mm)
MAX
6.90
6.30
1.20
7.40
2.50
0.60
0.70
0.60
1.00
2.40
4.3
5.50
2.49
adjustable
TO-251 Package
www.mns-kx.com
MP18N20
Items
A
A1
B
C
D
E1
E2
F
G
L1
L2
H
M
N
R
T
Y
MIN
6.30
2.10
0.30
0.60
0.70
0.30
0.70
9.60
2.70
0.60
5.10
2.09
1.40
5.10
Values(mm)
0 .3
MAX
6.90
0.13
6.30
2.50
0.60
0.90
1.00
0.60
1.20
10.50
3.10
1.00
5.50
2.49
1.60
6.30
TO-252 Package
www.mns-kx.com
很抱歉,暂时无法提供与“MP18N20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.14758
- 50+1.67033
- 150+1.48371
- 500+1.25086
- 2000+1.14718
- 5000+1.08497
