HSP100N15
N-Ch 150V Fast Switching MOSFETs
General Description
Product Summary
100% EAS Guaranteed
Green Device Available
Super Low RDS(ON)
Advanced high cell density Trench
technology
150
V
RDS(ON),typ
7.3
mΩ
ID
100
A
TO220 Pin Configuration
Applications
VDS
MOTOR Driver.
BMS.
High frequency switching and
synchronous rectification.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
150
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @
10V1,6
100
A
ID@TC=100℃
Continuous Drain Current, VGS @ 10V1,6
63
A
IDM
Pulsed Drain Current2
400
A
EAS
Single Pulse Avalanche Energy3
785
mJ
IAS
Avalanche Current
56
A
178
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient 1
60
℃/W
RθJC
Thermal Resistance Junction-Case1
0.7
℃/W
www.hs-semi.cn
Ver 2.0
Typ.
1
HSP100N15
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
150
V
VGS=10V , ID=20A
7.3
9
m
VGS=VDS , ID =250uA
2.0
3.0
4.0
V
VDS=120V , VGS=0V , TJ=25℃
1
VDS=120V , VGS=0V , TJ=125℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.9
100
25
Drain-Source Breakdown Voltage
On-Resistance2
RDS(ON)
Static Drain-Source
VGS(th)
Gate Threshold Voltage
IDSS
IGSS
Rg
Drain-Source Leakage Current
Conditions
Qg
Total Gate Charge (10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
31
Td(on)
Turn-On Delay Time
32
Tr
Rise Time
VDD=30V , VGS=10V , RG=3.3,
25
Td(off)
Turn-Off Delay Time
ID=1A
98
VDS=75V , VGS=10V , ID=20A
uA
nC
ns
Tf
Fall Time
89
Ciss
Input Capacitance
5880
Coss
Output Capacitance
401
Crss
Reverse Transfer Capacitance
9.5
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
100
A
VGS=0V , IS=1A , TJ=25℃
1.2
V
VDS=75V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source Current1,5
Diode Forward
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=50V,VGS=10V,L=0.5mH,IAS=56A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
6.Package limitation current.
www.hs-semi.cn
Ver 2.0
2
HSP100N15
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs G-S Voltage
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized VTH vs TJ
Fig.6 Normalized RDSON vs TJ
www.hs-semi.cn
Ver 2.0
3
HSP100N15
Fig.8 Safe Operating Area
Fig.7 Capacitance
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Switching Waveform
Ver 2.0
4
HSP100N15
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSP100N15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.05764
- 10+4.60404
- 50+3.95388
- 100+3.67416
- 500+3.55320
- 1000+3.49272
