VBFB165R04
VBFB165R04
    VBSEMI(微碧)
    TO-251-3
    1个N沟道 耐压:650V 电流:4.5A
VBFB165R04 数据手册
VBFB165R04 www.VBsemi.com /$IBOOFM7 %4 Power MOSFET FEATURES PRODUCT SUMMARY VDS (V) RDS(on) (Ω) • Low Gate Charge Qg Results in Simple Drive Requirement 650 VGS = 10 V 2.1 Qg (Max.) (nC) 48 Qgs (nC) 12 Qgd (nC) 19 Configuration Single RoHS • Improved Gate, Avalanche and Dynamic dV/dt Ruggedness COMPLIANT • Fully Characterized Capacitance and Avalanche Voltage and Current • Compliant to RoHS directive 2002/95/EC TO-251 D G S N-Channel MOSFET G D S Top View ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted PARAMETER Drain-Source Voltage Gate-Source Voltage Continuous Drain Currente TC = 25 °C VGS at 10 V Continuous Drain Current TC = 100 °C Pulsed Drain Currenta Linear Derating Factor Single Pulse Avalanche Energyb Repetitive Avalanche Currenta Repetitive Avalanche Energya TC = 25 °C Maximum Power Dissipation Peak Diode Recovery dV/dtc Operating Junction and Storage Temperature Range Soldering Recommendations (Peak Temperature)d for 10 s Mounting Torque 6-32 or M3 screw SYMBOL LIMIT UNIT VDS VGS 650 ± 30 V ID 4.5 4.2 IDM EAS IAR EAR PD dV/dt TJ, Tstg 18 0.48 325 4 6 60 2.8 - 55 to + 150 300 10 1.1 A W/°C mJ A mJ W V/ns °C lbf · in N·m Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Starting TJ = 25 °C, L = 24 mH, RG = 25 Ω, IAS = 3.2 A (see fig. 12). c. ISD ≤ 3.2 A, dI/dt ≤ 90 A/µs, VDD ≤ VDS, TJ ≤ 150 °C. d. 1.6 mm from case. e. Drain current limited by maximum junction temperature. 服务热线:400-655-8788 1 VBFB165R04 www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL TYP. Maximum Junction-to-Ambient RthJA - 65 Maximum Junction-to-Case (Drain) RthJC - 2.1 PARAMETER MAX. UNIT °C/W SPECIFICATIONS TJ = 25 °C, unless otherwise noted PARAMETER SYMBOL TEST CONDITIONS VDS VGS = 0 V, ID = 250 µA MIN. TYP. MAX. UNIT 650 - - V - 670 - mV/°C 2.0 - 4.0 V nA Static Drain-Source Breakdown Voltage VDS Temperature Coefficient Gate-Source Threshold Voltage Gate-Source Leakage Zero Gate Voltage Drain Current Drain-Source On-State Resistance Forward Transconductance ΔVDS/TJ VGS(th) Reference to 25 °C, ID = 1 VDS = VGS, ID = 250 µA IGSS IDSS RDS(on) gfs mAd VGS = ± 30 V - - ± 100 VDS = 650 V, VGS = 0 V - - 25 VDS = 520 V, VGS = 0 V, TJ = 125 °C - - 250 - 2.1 - Ω 3.9 - - S - 1417 - - 177 - - 7.0 - VDS = 1.0 V, f = 1.0 MHz - 1912 - VDS = 520 V, f = 1.0 MHz - 48 - - 84 - - - 48 - - 12 - - 19 - 14 - - 20 - - 34 - - 18 - - - 4 - - 21 ID = 3.1 Ab VGS = 10 V VDS = 50 V, ID = 3.1 A µA Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Output Capacitance Coss Effective Output Capacitance Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-On Delay Time td(on) Turn-Off Delay Time Fall Time VGS = 0 V Coss eff. Total Gate Charge Rise Time VGS = 0 V, VDS = 25 V, f = 1.0 MHz, see fig. 5 tr td(off) VDS = 0 V to 520 VGS = 10 V Vc ID = 3.2 A, VDS = 400 V see fig. 6 and 13b VDD = 325 V, ID = 3.2 A RG = 9.1 Ω, RD = 62 Ω, see fig. 10b tf pF nC ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current Pulsed Diode Forward Currenta Body Diode Voltage IS ISM VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the integral reverse p - n junction diode D A G TJ = 25 °C, IS = 3.2 A, VGS = 0 S Vb TJ = 25 °C, IF = 3.2 A, dI/dt = 100 A/µsb - - 1.5 V - 493 739 ns - 2.1 3.2 µC Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width ≤ 300 µs; duty cycle ≤ 2 %. c. Coss eff. is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 % to 80 % VDS. d. t = 60 s, f = 60 Hz. 服务热线:400-655-8788 2 VBFB165R04 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 10 10 VGS 15V 10V 8.0V 7.0V 6.0V 5.5V 5.0V BOTTOM 4.5V 5 I D , Drain-to-Source Current (A) I D , Drain-to-Source Current (A) TOP 1 20µs PULSE WIDTH 4.5V TJ = 25 °C 0.1 0.1 1 10 5 TJ = 150 ° C TJ = 25 ° C 1 0.1 4.0 100 VDS , Drain-to-Source Voltage (V) I D , Drain-to-Source Current (A) 4.5V 1 20µs PULSE WIDTH TJ = 150 ° C 1 10 VDS , Drain-to-Source Voltage (V) Fig. 2 - Typical Output Characteristics 100 RDS(on) , Drain-to-Source On Resistance (Normalized) 8.0 VGS 15V 10V 8.0V 7.0V 6.0V 5.5V 5.0V BOTTOM 4.5V 0.1 6.0 7.0 8.0 9.0 Fig. 3 - Typical Transfer Characteristics TOP 5 5.0 VGS , Gate-to-Source Voltage (V) Fig. 1 - Typical Output Characteristics 10 V DS = 100V 20µs PULSE WIDTH ID = 3.2A 5.5 5.0 3.5 2.0 0.5 0.0 -60 -40 -20 VGS = 10V 0 20 40 60 80 100 120 140 160 TJ , Junction Temperature ( °C) Fig. 4 - Normalized On-Resistance vs. Temperature 服务热线:400-655-8788 3 VBFB165R04 www.VBsemi.com 2000 ISD , Reverse Drain Current (A) 1600 C, Capacitance (pF) 10 V GS = 0V, f = 1MHz C iss = Cgs + C gd , Cds SHORTED C rss = C gd C oss = C ds + C gd iss 1200 oss 800 400 rss 0 10 100 TJ = 150 ° C 1 TJ = 25 ° C 0.1 0.2 A 1 5 1000 Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage 0.8 1.0 1.2 Fig. 7 - Typical Source-Drain Diode Forward Voltage 10 ID = 3.2 A OPERATION IN THIS AREA LIMITED BY RDS(on) VDS = 520V VDS = 325V VDS = 130V 16 10us ID , Drain Current (A) VGS , Gate-to-Source Voltage (V) 0.6 VSD ,Source-to-Drain Voltage (V) VDS , Drain-to-Source Voltage (V) 20 V GS = 0 V 0.4 12 8 5 100us 1ms 1 10ms 4 FOR TEST CIRCUIT SEE FIGURE 13 0 0 10 20 30 40 50 0.1 TC = 25 ° C TJ = 150 ° C Single Pulse 10 100 1000 QG , Total Gate Charge (nC) VDS , Drain-to-Source Voltage (V) Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage Fig. 8 - Maximum Safe Operating Area 10000 服务热线:400-655-8788 4 VBFB165R04 www.VBsemi.com RD VDS 6.0 VGS D.U.T. RG 5.0 + ID , Drain Current (A) - VDD 4.0 10 V Pulse width ≤ 1 µs Duty factor ≤ 0.1 % 3.0 Fig. 10a - Switching Time Test Circuit 2.0 VDS 90 % 1.0 0.0 25 50 75 100 125 150 10 % VGS TC , Case Temperature ( ° C) t d(on) Fig. 9 - Maximum Drain Current vs. Case Temperature tr t d(off) t f Fig. 10b - Switching Time Waveforms Thermal Response (Z thJC ) 10 D = 0.50 1 0.20 0.10 PDM 0.05 0.1 t1 0.02 t2 0.01 Notes: 1. Duty factor D = t 1 / t 2 2. Peak T J = P DM x Z thJC + TC SINGLE PULSE (THERMAL RESPONSE) 0.01 0.00001 0.0001 0.001 0.01 0.1 1 10 t1 , Rectangular Pulse Duration (s) Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case V DS tp 15 V L VDS D.U.T. RG IAS 20 V tp Driver + A - VDD 0.01 Ω Fig. 12a - Unclamped Inductive Test Circuit A I AS Fig. 12b - Unclamped Inductive Waveforms 服务热线:400-655-8788 5 VBFB165R04 EAS , Single Pulse Avalanche Energy (mJ) www.VBsemi.com 800 TOP BOTTOM 600 ID 2.3A 3.3A 4A QG 10 V QGS 400 Q GD VG Charge 200 Fig. 13a - Basic Gate Charge Waveform 0 25 50 75 100 125 150 Starting TJ , Junction Temperature ( °C) Current regulator Same type as D.U.T. Fig. 12c - Maximum Avalanche Energy vs. Drain Current 50 kΩ 12 V 0.2 µF 0.3 µF 800 + V DSav , Avalanche Voltage (V) D.U.T. 780 - VDS VGS 3 mA 760 IG ID Current sampling resistors Fig. 13b - Gate Charge Test Circuit 740 720 700 A 0 1 2 3 4 5 6 I av , Avalanche Current (A) Fig. 12d - Typical Drain-to Source Voltage vs. Avalanche Current 服务热线:400-655-8788 6 VBFB165R04 www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit + D.U.T. Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + - - • • • • RG dV/dt controlled by R G Driver same type as D.U.T. ISD controlled by duty factor "D" D.U.T. - device under test Driver gate drive P.W. + Period D= + - VDD P.W. Period VGS = 10 V* D.U.T. ISD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage VDD Body diode forward drop Inductor crurent Ripple ≤ 5 % ISD * VGS = 5 V for logic level devices Fig. 14 - For N-Channel 服务热线:400-655-8788 7 VBFB165R04 www.VBsemi.com TOĆ251AA E A L2 b2 Dim A A1 b b1 b2 c c1 D E e L L1 L2 L3 D L3 L1 b1 L b MILLIMETERS c1 e c A1 INCHES Min Max Min Max 2.21 2.38 0.087 0.094 0.89 1.14 0.035 0.045 0.71 0.89 0.028 0.035 0.76 1.14 0.030 0.045 5.23 5.43 0.206 0.214 0.46 0.58 0.018 0.023 0.46 0.58 0.018 0.023 5.97 6.22 0.235 0.245 6.48 6.73 0.255 0.265 2.28 BSC 0.090 BSC 3.89 9.53 0.153 0.375 1.91 2.28 0.075 0.090 0.89 1.27 0.035 0.050 1.15 1.52 0.045 0.060 ECN: S-03946—Rev. E, 09-Jul-01 DWG: 5346 Note: Dimension L3 is for reference only. 服务热线:400-655-8788 8 VBFB165R04 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBFB165R04 价格&库存
很抱歉,暂时无法提供与“VBFB165R04”相匹配的价格&库存,您可以联系我们找货
