DIO7003HDST5
DIO7003HDST5
    DIOO(帝奥)
    SOT23-5
    1.5A 2.7V~5.5V
DIO7003HDST5 数据手册
Rev 1.3 DIO7003 5.5V Low Loss Power Distribution Switch Features Descriptions Input voltage: 2.7V to 5.5V The Typical 75mΩ on-resistance intended for applications where precision current Five different continuous current versions limiting is required or heavy capacitive loads and Under voltage lockout short circuits are encountered. The power switch Over current protection, short circuit rising and falling times are controlled to minimize protection and over temperature protection current surges during turning on/off. DIO7003 power distribution switch is Fault time 5ms typically with blanking Reverse blocking (no body diode) The No reverse current when power ON or power 350mA/700mA/1A/1.5A/2A five current levels. DIO7003A/B/C/D/E provide separately OFF Enable polarity: active high or active low The DIO7003 device limits the output current Compact SOT23-5, SOIC-8, EP-MSOP8 and under a safe level by using a constant current MSOP-8 packages mode when the output load exceeds the current limit threshold. Applications USB Ports/Hubs Digital TV Set-Top Boxes The DIO7003 is available in the SOT23-5, SOIC-8, EP-MSOP8 and MSOP-8 packages. It is rated over the -40°C to +85°C temperature range. VOIP Phones Typical Application www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 DIO7003 Order Part Top Number Marking Recommended EN/EN Continuous Package Current DIO7003HAST5 W3HA 350mA Active High Green SOT23-5 Tape & Reel, 3000 DIO7003HBST5 W3HB 700mA Active High Green SOT23-5 Tape & Reel, 3000 DIO7003HCST5 W3HC 1A Active High Green SOT23-5 Tape & Reel, 3000 DIO7003HDST5 W3HD 1.5A Active High Green SOT23-5 Tape & Reel, 3000 DIO7003HEST5 W3HE 2A Active High Green SOT23-5 Tape & Reel, 3000 DIO7003LAST5 W3LA 350mA Active Low Green SOT23-5 Tape & Reel, 3000 DIO7003LBST5 W3LB 700mA Active Low Green SOT23-5 Tape & Reel, 3000 DIO7003LCST5 W3LC 1A Active Low Green SOT23-5 Tape & Reel, 3000 DIO7003LDST5 W3LD 1.5A Active Low Green SOT23-5 Tape & Reel, 3000 DIO7003LEST5 W3LE 2A Active Low Green SOT23-5 Tape & Reel, 3000 DIO7003HASO8 D703HA 350mA Active High Green SOIC-8 Tape & Reel, 2500 DIO7003HBSO8 D703HB 700mA Active High Green SOIC-8 Tape & Reel, 2500 DIO7003HCSO8 D703HC 1A Active High Green SOIC-8 Tape & Reel, 2500 DIO7003HDSO8 D703HD 1.5A Active High Green SOIC-8 Tape & Reel, 2500 DIO7003HESO8 D703HE 2A Active High Green SOIC-8 Tape & Reel, 2500 DIO7003LASO8 D703LA 350mA Active Low Green SOIC-8 Tape & Reel, 2500 DIO7003LBSO8 D703LB 700mA Active Low Green SOIC-8 Tape & Reel, 2500 DIO7003LCSO8 D703LC 1A Active Low Green SOIC-8 Tape & Reel, 2500 DIO7003LDSO8 D703LD 1.5A Active Low Green SOIC-8 Tape & Reel, 2500 DIO7003LESO8 D703LE 2A Active Low Green SOIC-8 Tape & Reel, 2500 DIO7003HAXM8 D703HA 350mA Active High Green EP-MSOP8 Tape & Reel, 3000 DIO7003HBXM8 D703HB 700mA Active High Green EP-MSOP8 Tape & Reel, 3000 DIO7003HCXM8 D703HC 1A Active High Green EP-MSOP8 Tape & Reel, 3000 DIO7003HDXM8 D703HD 1.5A Active High Green EP-MSOP8 Tape & Reel, 3000 DIO7003HEXM8 D703HE 2A Active High Green EP-MSOP8 Tape & Reel, 3000 DIO7003LAXM8 D703LA 350mA Active Low Green EP-MSOP8 Tape & Reel, 3000 DIO7003LBXM8 D703LB 700mA Active Low Green EP-MSOP8 Tape & Reel, 3000 DIO7003LCXM8 D703LC 1A Active Low Green EP-MSOP8 Tape & Reel, 3000 DIO7003LDXM8 D703LD 1.5A Active Low Green EP-MSOP8 Tape & Reel, 3000 DIO7003LEXM8 D703LE 2A Active Low Green EP-MSOP8 Tape & Reel, 3000 DIO7003HAMP8 D703HA 350mA Active High Green MSOP-8 Tape & Reel, 3000 DIO7003HBMP8 D703HB 700mA Active High Green MSOP-8 Tape & Reel, 3000 DIO7003HCMP8 D703HC 1A Active High Green MSOP-8 Tape & Reel, 3000 DIO7003HDMP8 D703HD 1.5A Active High Green MSOP-8 Tape & Reel, 3000 DIO7003HEMP8 D703HE 2A Active High Green MSOP-8 Tape & Reel, 3000 www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Ordering Information DIO7003 D703LA 350mA Active Low Green MSOP-8 Tape & Reel, 3000 DIO7003LBMP8 D703LB 700mA Active Low Green MSOP-8 Tape & Reel, 3000 DIO7003LCMP8 D703LC 1A Active Low Green MSOP-8 Tape & Reel, 3000 DIO7003LDMP8 D703LD 1.5A Active Low Green MSOP-8 Tape & Reel, 3000 DIO7003LEMP8 D703LE 2A Active Low Green MSOP-8 Tape & Reel, 3000 Ordering Information Complimentary Note Ordering number = Part No. +Enable Active Version+ Continuous Current Version +Package Code DIO7003 H: Enable Active High ST5: Stands for SOT23-5 L: Enable Active Low SO8: Stands for SOIC-8 XM8: Stands for EP-MSOP8 MP8: Stands for MSOP-8 A: 350mA Continuous Current Version B: 700mA Continuous Current Version C: 1A Continuous Current Version D: 1.5A Continuous Current Version E: 2A Continuous Current Version www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch DIO7003LAMP8 DIO7003 SOT23-5(Top View) OUT 1 GND 2 FLG 3 5 IN 4 EN/EN SOIC-8/MSOP-8 (Top View) EP-MSOP8 (Top View) GND 1 8 NC IN 2 7 OUT IN 3 6 OUT EN/EN 4 5 FLG Figure 1 Pin Assignment Pin Description Pin Name OUT Output pin, decoupled with a 10μF capacitor to GND GND Ground pin FLG EN/EN IN www.dioo.com Pin Description Fault flag output Active high or Active low. Do not leave it floating Input pin, decoupled with a 10µF capacitor to GND © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Pin Assignments DIO7003 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter All pins Rating Unit -0.3 to 6 V θJA ,SOT23-5 250 θJA ,SOIC-8 130 θJA , EP-MSOP8 100 θJA , MSOP-8 166 Package Thermal Resistance °C/W Junction Temperature Range 150 °C Lead Temperature (Soldering, 10 sec) 260 °C -65 to 150 °C Storage Temperature Range (TSTG) HBM (Human Body Mode) 6 CDM (Charged Device Mode) 2 ESD Susceptibility kV Note: Input and output negative ratings may be exceeded if input and output diode current ratings are observed. Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Rating Unit 2.7 to 5.5 V 0 to 5.5 V Junction Temperature Range -40 to 125 °C Ambient Temperature Range -40 to 85 °C IN All other pins www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Absolute Maximum Ratings DIO7003 TA=25°C VIN = 5V, unless otherwise noted. Symbol VIN ISHDN Parameter Conditions Input Voltage Range Min. Typ. 2.7 Max. Unit 5.5 V Shut down Input Current Open load, IC Disabled 0.2 1 µA Quiescent Supply Current Open load, IC Disabled 50 88 µA RDS(ON) FET RON IOUT=100mA 75 99 mΩ VEN(H) EN Rising Threshold VIN = 2.7V to 5.5V IQ VEN(L) V VIN = 4.5V to 5.5V 0.6 VIN = 2.7V to 4.5V 0.5 EN Falling Threshold IEN EN Leakage Current VIN_UVLO IN UVLO Threshold VIN_HYS IN UVLO Hysteresis ILIM 1.4 Current Limit V VEN=5.0V 1 µA 2.5 V 240 400 mV DIO7003HA, DIO7003LA 0.375 0.5 0.625 DIO7003HB, DIO7003LB 0.75 1 1.25 DIO7003HC, DIO7003LC 1.1 1.5 1.9 DIO7003HD, DIO7003LD 1.5 2 2.5 DIO7003HE, DIO7003LE 2.1 2.5 3.1 ILIM,Typ ILIM,Max ×1.2 ×1.2 A IOS Short Current Limit TON Turn-on Time RL=10Ω, COUT=1μF 400 µs TOFF Turn-off Time RL=10Ω, COUT=1μF 20 µs TSD Thermal Shut down Temperature 140 °C Thermal Shut down Hysteresis 20 °C www.dioo.com A © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Electrical Characteristics DIO7003 Application Information Power Supply Considerations A 10μF ceramic capacitor from VIN to GND to prevent the input voltage from dropping during the hot-plug condition is strongly recommended. However higher capacitance could help reduce the voltage drop. Further more, bypassing the output with a 10μF ceramic capacitor improves the immunity of the device to short-circuit transients, because an output short will cause ringing on the input without the input capacitor. It could destroy the internal circuitry when the input transient voltage exceeds the absolute maximum supply voltage even for a short duration. Under Voltage Lockout A voltage sense circuit monitors the input voltage. When the input voltage is below approximately 2.4V, a control signal turns off the power switch. Enable The logic enable controls the power switch, the bias for the charge pump, driver, and other circuitry to reduce the supply current. The EN control pin must be driven to a logic high or logic low for a clearly defined signal input. Floating these control lines may cause unpredictable operation. Over-Current Protection The DIO7003 responds to over current conditions by limiting output current to the ILIM levels. When an over current condition is detected, the device maintains a constant output current and reduces the output voltage accordingly. Complete shut down occurs only if the fault is present long enough to activate thermal limit. Two possible overload conditions can occur. In the first condition, an excessive load occurs while the device is enabled. When the excessive load occurs, very high currents may flow for a short time before the current limit circuit can react. After the current limit circuit has tripped (reached the overcurrent trip threshold) the device switches into constant current mode to limit the current close to ILIM. In the second condition, the load is gradually increasing beyond the recommended operating current. The current is permitted to rise until the currentlimit threshold (ILIM) is reached or until the thermal limit of the device is www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Block Diagram DIO7003 Thermal Protection Thermal protection prevents damage to the IC when heavy overload or short circuit conditions are present for extended periods of time. The conditions force the DIO7003 into constant current mode, and under short circuit conditions, the voltage across the switch is equal tothe input voltage. The increased dissipation causes the junction temperature to rise to high levels. The protection circuit senses the junction temperature of the switch and shuts it off. Hysteresis is built into the thermal sense circuit, and after the device has cooled approximately 20 degrees, the switch turns back on. The switch continuesto cycle in this way until the overload or input power is removed. Reverse-voltage Protection The reverse-voltage protection feature turns off the P-channel MOSFET whenever the output voltage exceeds the input voltage by 175mV (typ) for 4ms (typ). A reverse current of (VOUT-VIN)/RDS(on) will be present when this occurs. This prevents damage to devices on the input side of the DIO7003 by preventing significant current from sinking into the input capacitance. The DIO7003 devices allow the P-channel MOSFET to turn on once the output voltage goes bellow the input voltage for the same 4ms deglitch time. FLG Output An error Flag is an open-drained output of an N-channel MOSFET. Flag output is pulled low when the below conditions happen: input under voltage lockout, output current limit, output short circuit and over temperature shut down. The flag response delay time is 5ms typically. www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch exceeded. The DIO7003 is capable of delivering current up to the current limit threshold (ILIM) without damaging the device. Once the threshold has been reached, the device switches into its constant current mode. DIO7003 TA=25°C VIN = 5V, unless otherwise noted. Current Limit Output Short Response EN Turn On EN Turn Off (Iload=0.7A, Vin=5V, R=7ohm) (Iload=0.7A, Vin=5V, R=7ohm) www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch Typical Performance Characteristics DIO7003 UVLO Turn Off (Iload=0.7A, Vin=5V, R=7ohm) No-Load to Over-Load Transient Response Over-Load to No-Load Recovery Response (Vin=5V, R=1ohm) (Vin=5V, R=1ohm) Full-Load to Short-Circuit Transient Response Short-Circuit to Full-Load Recovery Response (Iload=0.7A, Vin=5V) (Iload=0.7A, Vin=5V) www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch UVLO Turn On (Iload=0.7A, Vin=5V, R=7ohm) DIO7003 Short-Circuit to No-Load Recovery Response (Vin=5V) (Vin=5V) www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch No-Load to Short-Circuit Transient Response DIO7003 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2016 DIOO MICROCIRCUITS CO., LTD DIO7003• Rev 1.3 5.5V Low Loss Power Distribution Switch CONTACT US
DIO7003HDST5 价格&库存
很抱歉,暂时无法提供与“DIO7003HDST5”相匹配的价格&库存,您可以联系我们找货
