ME2110
PFM Step-up DC/DC Converter, ME2110 Series
General Description
Features
ME2110 Series is a PFM Step-up DC/DC converter
Low ripple and low noise
IC with low supply current by CMOS process. High
Operating voltage range:0.9V~6.0V
frequency noise that occurs during switching is
Output voltage range:1.8V~6.0V(step 0.1V)
reduced by using advanced circuit designed, output
Output voltage accuracy:±2%
voltage is programmable in 0.1V steps between
Output Current:If VIN=1.2V and VOUT=1.9V,then
1.8~6.0V.A low ripple, high efficiency step-up DC/DC
IOUT=100mA
converter can be constructed of ME2110Xxx with
Low start voltage:≤0.9V(at IOUT =1mA)
only three external components.
Maximum
Also available is a
CE (chip enable) function that reduce power
oscillator
frequency : 360KHz
(TYP. ME2110C25)
dissipation during shut-down mode. ME2110Xxx is
High Efficiency:85% (TYP.)
suitable for use with battery-powered instruments
Package: SOT89-3,SOT23-5,SOT23-3
with low noise and low supply current.
Selection Guide
Typical Application
Power source for battery-powered equipment
Power source for wireless mouse, wireless
keyboard, toys, cameras, camcorders, VCRs,
PDAs, and hand-held communication equipment
Power source for appliances which require higher
cell voltage than that of batteries used in the
appliances
V05
www.microne.com.cn
Page 1 of 15
ME2110
Pin Configuration
Pin Assignment
TYPE
POSTFIX
PACKAGE
SWITCHING TRANSISTOR
CE FUNCTION
FEATURE
ME2110Axx
P
SOT89-3
Build in Transistor
No
Lx
ME2110Axx
M3
SOT23-3
Build in Transistor
No
Lx
ME2110Cxx
M5
SOT23-5
Build in Transistor
Yes
Lx CE
ME2110AXX
PIN Number
Pin Name
Function
SOT89-3
SOT23-3
1
1
GND
Ground
2
3
VOUT
Output voltage monitor, IC internal power supply
3
2
Lx
Switch
ME2110CXX
PIN Number
Pin Name
Function
1
CE
Chip enable
2
VOUT
3
NC
NC
4
GND
Ground
5
Lx
Switch
SOT23-5
V05
www.microne.com.cn
Page 2 of 15
ME2110
Absolute Maximum Ratings
PARAMETER
SYMBAL
RATING
UNIT
VIN Input Voltage
VIN
6.5
V
Lx Pin voltage
VLX
6.5
V
CE Pin voltage
VCE
-0.3~ VOUT +0.3
V
VOUT=1.9V
ILX
800
mA
VOUT=2.5V,3.0V,3.3V
ILX
1300
mA
VOUT=5V
ILX
2000
mA
Vdd
6.5
V
SOT89-3
Pd
500
mW
SOT23-5
Pd
300
mW
SOT23-3
Pd
300
mW
Operating Ambient Temperature
TOpr
-25~+85
Storage Temperature
Tstg
-40~+125
Soldering temperature and time
Tsolder
260℃, 10s
Lx Pin current
Vdd input voltage
Continuous Total Power Dissipation
Block Diagram
V05
www.microne.com.cn
Page 3 of 15
ME2110
Electrical Characteristics
ME2110A19
Fosc=150KHz
(, VIN=VOUT×0.6,IOUT=10mA,Topt=25℃. Unless otherwise specified)
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
VOUT×
0.98
VOUT
VOUT×
1.02
V
VOUT
Output Voltage
Vstart
Oscillation Start-up
Voltage
IOUT=1mA,
VIN:0→2V
0.80
0.90
V
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
No external component
VOUT=VOUT×0.95,
27
µA
IDD2
Supply Current 2
VOUT=VOUT+0.5V
4.5
µA
ILX
Lx Switching Current
VLX=0.4V,
VOUT=VOUT×0.95
100
mA
ILXleak
Lx Leakage Current
VOUT=VLX=6V
0.5
µA
Fosc
Oscillation
Frequency
VOUT=set VOUT×0.95
150
KHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
ME2110C25
Fosc=360KHz
(VIN =VOUT×0.6,VCE =VOUT ,IOUT=10mA,Topt=25℃. Unless otherwise specified)
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
VOUT×
0.98
VOUT
VOUT×
1.02
V
VOUT
Output Voltage
Vstart
Voltage
IOUT=1mA,
VIN:0→2V
0.84
0.90
V
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.33
V
IDD1
Supply Current 1
VOUT=VOUT×0.95,
85
µA
IDD2
Supply Current 2
VOUT=VOUT+0.5V
7
µA
IDD3
Supply Current 3
VOUT=VOUT+0.5V
VCE =0V
1.0
µA
ILX
VLX=0.4V
VOUT= set VOUT×0.95
100
mA
ILXleak
Lx Leakage Current
VOUT=VLX=6V
0.5
µA
V05
www.microne.com.cn
Page 4 of 15
ME2110
Fosc
Oscillation
Frequency
VOUT=set VOUT×0.95
360
KHz
Maxdty
Duty Ratio
on(VLX“L”)side
77
EFFI
Efficiency
85
ME2110C33 Fosc=360KHz
(VIN =VOUT×0.6, VCE =VOUT ,IOUT=10mA,Topt=25℃. Unless otherwise specified)
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
VOUT×
0.98
VOUT
VOUT×
1.02
V
VOUT
Output Voltage
Vstart
Voltage
IOUT=1mA,
VIN:0→2V
0.84
0.90
V
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.33
V
IDD1
Supply Current 1
VOUT=VOUT×0.95,
110
µA
IDD2
Supply Current 2
VOUT=VOUT+0.5V
7
µA
Supply Current 3
VOUT=VOUT+0.5V
VCE =0V
1.0
µA
ILX
VLX=0.4V
VOUT= set VOUT×0.95
100
mA
ILXleak
Lx Leakage Current
VOUT=VLX=6V
0.5
µA
Fosc
Oscillation
Frequency
VOUT=set VOUT×0.95
360
KHz
Maxdty
Duty Ratio
on(VLX“L”)side
77
EFFI
Efficiency
85
IDD3
ME2110C50 Fosc=310KHz
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
VOUT×
0.98
VOUT
VOUT×
1.02
V
VOUT
Output Voltage
Vstart
Voltage
IOUT=1mA,
VIN:0→2V
0.85
0.90
V
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.38
V
V05
www.microne.com.cn
Page 5 of 15
ME2110
IDD1
Supply Current 1
VOUT=VOUT×0.95,
165
µA
IDD2
Supply Current 2
VOUT=VOUT+0.5V
8
µA
Supply Current 3
VOUT=VOUT+0.5V
VCE =0V
1.0
µA
ILX
VLX=0.4V
VOUT= set VOUT×0.95
110
mA
ILXleak
Lx Leakage Current
VOUT=VLX=6V
0.5
µA
Fosc
Oscillation
Frequency
VOUT=set VOUT×0.95
310
KHz
Maxdty
Duty Ratio
on(VLX“L”)side
74
EFFI
Efficiency
85
MIN
TYP
MAX
UNITS
VOUT×
0.98
VOUT
VOUT×
1.02
V
IDD3
ME2110A50 Fosc=310KHz
(VIN =VOUT×0.6, IOUT=10mA,Topt=25℃. Unless otherwise specified)
SYMBOL
PARAMETER
CONDITIONS
VOUT
Output Voltage
Vstart
Voltage
IOUT=1mA,
VIN:0→2V
0.85
0.90
V
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.38
V
IDD1
Supply Current 1
VOUT=VOUT×0.95,
165
µA
IDD2
Supply Current 2
VOUT=VOUT+0.5V
8
µA
ILX
VLX=0.4V
VOUT= set VOUT×0.95
110
mA
ILXleak
Lx Leakage Current
VOUT=VLX=6V
0.5
µA
Fosc
Oscillation
Frequency
VOUT=set VOUT×0.95
310
KHz
Maxdty
Duty Ratio
on(VLX“L”)side
74
EFFI
Efficiency
85
Note:1、Diode use Schottky diode such as IN5817 or IN5819 (forward voltage drop:0.2V)
2、Inductor:22μH(r
很抱歉,暂时无法提供与“ME2110C50M5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48449
- 100+0.38600
- 300+0.33675
- 国内价格
- 1+0.45540
- 200+0.29370
- 1500+0.25520
- 3000+0.22660
