SL9193 Series
Low Dropout Linear Regulator
SOT-23
Description
3.VIN
The SL9193 Series are highly precise,low noise,positive voltage
LDO regulators manufactured using CMOS processes. The
SL9193 performance is optimized for battery-powered systems
to deliver ultra low noise and low quiescent current. Regulator
ground current increases only slightly in dropout, further
1.GND
2.VOUT
SOT-23-3
3.VIN
prolonging the battery life. The SL9193 Series also works with
low-ESR ceramic capacitors, reducing the amount of board
space necessary for power applications, critical in hand-held
wireless devices. The SL9193 Series consumes less than 1μA
in shutdown mode and has fast turn-on time less than 50μs.
1.GND
2.VOUT
The other features include ultra low dropout voltage, high
SOT-89
output accuracy, current limiting protection, and high ripple
2.VIN
rejection ratio.
Features
Ultra Low Noise for RF Application
Ultra Fast Response in Line/Load Transient
Low Power Consumption:70uA(Typ.)
1.GND 2.VIN 3.VOUT
PSRR=70dB@1KHz
Maximum Output Current: 300mA
Low Dropout : 130mV @ 100mA at VOUT=3.3V
Operating Voltage Ranges : 2V to 6.5V
Over Temperature Protection
Current Limiting Protection
Thermal Shutdown Protection
SOT-23-5
1.VIN
Applications
Battery-Powered Equipment
CDMA/GSM Cellular Handsets
Portable Information Appliances
www.slkormicro.com
4. NC
5. VOUT
1
2.GND
3.EN
SL9193 Series
Typical Application Circuit
SL9193
VIN
CIN
1µF
Chip Enable
VIN
VOUT
GND
COUT
1µF
VOUT
NC
EN
Functional Pin Description
Pin Name
Pin Function
EN
Chip Enable (Active High). Note that this pin is high impedance
NC
NO Connected
GND
Ground.
VOUT
Output Voltage.
VIN
Power Input Voltage.
Marking Code:
Ordering Information
SL9193-
Package Type
SA:SOT-23 SC:SOT-23-3
SQ:SOT-89 SE:SOT-23-5
Output Voltage
12 : 1.2V 15 : 1.5V 18 : 1.8V
25 : 2.5V 28 : 2.8V 30 : 3.0V
33 : 3.3V 36 : 3.6V
XX: Output Voltage
33 : 3.3V 36 : 3.6V
Output current tap
M : 300mA
www.slkormicro.com
2
SL9193 Series
Function Block Diagram
www.slkormicro.com
3
SL9193 Series
Absolute Maximum Ratings Note1
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Input Voltage
Value
Unit
VIN
-0.3~7
V
VON/OFF
-0.3~0.3
V
Output Voltage
-0.3~VIN+0.3
V
SOT-23
300
mW
SOT-23-3
250
mW
SOT-23-5
250
mW
SOT-89
400
mW
SOT-23
330
℃/W
SOT-23-3
400
℃/W
SOT-23-5
400
℃/W
SOT-89
250
℃/W
Operating Ambient Temperature
-40~85
Maximum Junction Temperature
260
-40~125
ESD(HBM) Note2
4
KV
ESD(CDM) Note2
400
V
Power Dissipation
Thermal Resistance,Junction-to-Ambient
Storage temperature range
Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device.
These are stress ratings only, and functional operation of the device at these or any other conditions beyond those
indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating
conditions may affect device reliability.
2. ESD testing is performed according to the respective JESD22 JEDEC standard. The human body model is a 100pF
capacitor discharged through a 1.5KΩ resistor into each pin.The machine model is a 200pF capacitor discharged directly
into each pin.
Parameter
Value
Unit
2~6.5
V
Operating Junction Temperature Range,Tj
-40~125
Operating Free Air Temperature Range,TA
-40~85
Supply Voltage
www.slkormicro.com
4
SL9193 Series
Electrical Characteristics
(VIN=VOUT+1, VOUT = 3.3V, CIN=COUT=1µF, TA= 25℃ , unless otherwise noted.)
Parameter
Symbol
Input Voltage
VIN
Output Voltage Accuracy
∆VOUT
Quiescent Current
IQ
Conditions
MIN.
TYP.
MAX.
Unit
-0.3
6.5
V
IOUT=40mA
-2
+2
VIN>VOUT,EN=VIN
IOUT=0mA
70
µA
IOUT=100mA
130
IOUT=200mA
250
Dropout Voltage
VDROP
Line Regulation
∆VLINE
VIN=VOUT+1V to 7V
IOUT=40mA
0.05
%/V
Load Regulation
∆VLOAD
1mA
很抱歉,暂时无法提供与“SL9193M25SE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.25920
- 6000+0.25488
- 12000+0.24840
- 24000+0.23760
