SD5351A
Shouding
_______________________________________________________________________________________________________
One Cell Lithium-ion/Polymer Battery Protection IC
GENERAL DESCRIPTION
FEATURES
The SDB5351 series product is a high
integration solution for lithiumion/polymer battery protection. SD5351
contains advanced power MOSFET,
high-accuracy voltage detection circuits
and delay circuits. SD5351 is put into an
ultra-small SOT23-5 package and only
one external component makes it an
ideal solution in limited space of battery
pack.
SD5351 has all the protection functions
required in the battery application including
overcharging, overdischarging, overcurrent
and load short circuiting protection etc. The
accurate overcharging detection voltage
ensures safe and full utilization charging.
The low standby current drains little current
from the cell while in storage.
The device is not only targeted for digital
cellular phones, but also for any other
Li-Ion and Li-Poly battery-powered
information appliances requiring longterm battery life.
· Protection of Charger Reverse
Connection
· Protection of Battery Cell Reverse
Connection
· Integrate Advanced Power MOSFET
with Equivalent of 54mΩ RDS(ON)
· Ultra-small SOT23-5 Package
· Only One External Capacitor
Required
· Over-temperature Protection
· Overcharge Current Protection
· Two-step Overcurrent Detection:
-Overdischarge Current
-Load Short Circuiting
· Charger Detection Function
· 0V Battery Charging Function
- Delay Times are generated inside
· High-accuracy Voltage Detection
· Low Current Consumption
- Operation Mode: 2.8μA typ.
- Power-down Mode: 1.5μA typ.
· RoHS Compliant and Lead (Pb) Free
APPLICATIONS
One-Cell Lithium-ion Battery Pack
Lithium-Polymer Battery Pack
Figure 1. Typical Application Circuit
www.shouding.net
1
REV0.6
SD5351A
Shouding
__________________________________________________________________________________________ ____________
ORDERING INFORMATION
Overcharg Overcharge Overdischarge Overdischarge Overcurrent
Release
Detection
Release
Detection
PART
Pack e Detection
Voltage
Voltage
Voltage
Voltage
Current
NUMBER age
[IOV1] (A)
[VCU] (V)
[VCL] (V)
[VDL] (V)
[VDR] (V)
SD5351A
SOT
23-5
4.30
4.10
2.40
3.0
3
Top Mark
5351AYW(note)
Note: “YW” is manufacture date code, “Y” means the year, “W” means the week
PIN CONFIGURATION
Figure 2. PIN Configuration
PIN DESCRIPTION
SD5351 PIN
NUMBER
PIN NAME
1
VT
2
GND
Ground, connect the negative terminal of the battery to this pin
3
VDD
Power Supply
4,5
VM
PIN DESCRIPTION
Test pin;only for vendor not used by application
The negative terminal of the battery pack. The internal FET switch
connects this terminal to GND
ABSOLUTE MAXIMUM RATINGS
(Note: Do not exceed these limits to prevent damage to the device. Exposure to absolute maximum rating
conditions for long periods may affect device reliability.)
PARAMETER
VALUE
UNIT
VDD input pin voltage
-0.3 to 6
V
VM input pin voltage
-6 to 10
V
Operating Ambient Temperature
-40 to 85
°C
Maximum Junction Temperature
125
°C
www.shouding.net
2
REV0.6
SD5351A
Shouding
Storage Temperature
-55 to 150
°C
Lead Temperature ( Soldering, 10 sec)
300
°C
Power Dissipation at T=25°C
0.4
W
Package Thermal Resistance (Junction to Ambient) θJA
250
°C/W
Package Thermal Resistance (Junction to Case) θJC
130
°C/W
ESD
2000
V
ELECTRICAL CHARACTERISTICS
Typicals and limits appearing in normal type apply for TA = 25oC, unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
Detection Voltage
Overcharge Detection Voltage
VCU
Overcharge Release Voltage
VCL
Overdischarge Detection Voltage
VDL
Overdischarge Release Voltage
VDR
Charger Detection Voltage
VCHA
4.25
4.30
4.35
4.05
4.10
4.15
V
V
2.3
2.4
2.5
V
2.9
3.1
3.0
V
-0.07
-0.12
-0.2
V
Detection Current
Overdischarge Current1 Detection
Load Short-Circuiting
Detection
Current Consumption
IIOV1
VDD=3.5V
ISHORT
VDD=3.5V
Current Consumption in Normal
Operation
IOPE
Current Consumption in power
Down
IPDN
2.1
3
3.9
A
A
VDD=3.5V
VM =0V
VDD=2.0V
VM pin floating
2.8
6
μA
VDD=3.5V
VM=1.0V
VDD=2.0V
320
10
1.5
μA
VM Internal Resistance
Internal Resistance between
VM and VDD
RVMD
Internal Resistance between VM
and GND
RVMS
kΩ
100
kΩ
VM=1.0V
FET on Resistance
Equivalent FET on Resistance
RDS(ON)
VDD=3.6V IVM =1.0A
54
63
mΩ
Over Temperature Protection
TSHD+
120
Over Temperature Recovery Degree TSHD-
100
www.shouding.net
3
oC
REV0.6
SD5351A
Shouding
Detection Delay Time
Overcharge Voltage Detection
Delay Time
tCU
130
mS
Overdischarge Voltage Detection
Delay Time
Detection
Delay Time
Load Short-Circuiting Detection
Delay Time
tDL
40
mS
tIOV
VDD=3.5V
10
mS
tSHORT
VDD=3.5V
75
uS
Figure 3. Functional Block Diagram
FUNCTIONAL DESCRIPTION
The SD5351 monitors the voltage and
current of a battery and protects it from
being damaged due to overcharge voltage,
overdischarge voltage, overdischarge
current, and short circuit conditions by
disconnecting the battery from the load
or charger. These functions are required in
order to operate the battery cell within
specified limits.
The device requires only one external
capacitor. The MOSFET is integrated and
its RDS(ON) is as low as 54mΩ typical.
Normal operating mode
If no exception condition is detected,
charging and discharging can be carried
out freely. This condition is called the
normal operating mode.
Overcharge Condition
When the battery voltage becomes higher
than the overcharge detection voltage (VCU)
during charging under normal condition
and the state continues for the overcharge
detection delay time (tCU) or longer, the
SD5351 turns the charging control FET off
www.shouding.net
4
REV0.6
SD5351A
Shouding
overcurrent 2 work. Detection of load shortcircuiting works regardless of the battery voltage.
to stop charging. This condition is called
the overcharge condition. The overcharge
condition is released in the following two
cases:
1, When the battery voltage drops below
the overcharge release voltage (VCL), the
SD5351 turns the charging control FET on
and returns to the normal condition.
2, When a load is connected and
discharging starts, the SD5351 turns the
charging control FET on and returns to the
normal condition. The release mechanism
is as follows: the discharging current flows
through an internal parasitic diode of the
charging FET immediately after a load is
connected and discharging starts, and the
VM pin voltage increases about 0.7 V
(forward voltage of the diode) from the
GND pin voltage momentarily. The SD5351
detects this voltage and releases the
overcharge condition. Consequently, in the
case that the battery voltage is equal to or
lower than the overcharge detection
voltage (VCU), the SD5351returns to the
normal condition immediately, but in the
case the battery voltage is higher than the
overcharge detection voltage (VCU),the chip
does not return to the normal condition
until the battery voltage drops below the
overcharge detection voltage (VCU) even if
the load is connected. In addition, if the VM
pin voltage is equal to or lower than the
overcurrent 1 detection voltage when a
load is connected and discharging starts,
the chip does not return to the normal
condition.
Overdischarge Condition
When the battery voltage drops below the
overdischarge detection voltage (VDL)
during discharging under normal condition
and it continues for the overdischarge
detection delay time (tDL) or longer, the
SD5351 turns the discharging control FET
off and stops discharging. This condition is
called overdischarge condition. After the
discharging control FET is turned off, the
VM pin is pulled up by the RVMD resistor
between VM and VDD in SD5351.
Meanwhile when VM is bigger than 1.5
V (typ.) (the load short-circuiting detection
voltage), the current of the chip is reduced
to the power-down current (IPDN). This
condition is called power-down condition.
The VM and VDD pins are shorted by the
RVMD resistor in the IC under the
overdischarge and power-down conditions.
The power-down condition is released
when a charger is connected and the
potential difference between VM and VDD
becomes 1.3 V (typ.) or higher (load shortcircuiting detection voltage). At this time,
the FET is still off. When the battery
voltage becomes the overdischarge
detection voltage (VDL) or higher (see note),
the SD5351 turns the FET on and changes
to the normal condition from the
Remark If the VM pin voltage is no less than the
charger detection voltage (VCHA), when the battery
under overdischarge condition is connected to a
charger, the overdischarge condition is released
(the discharging control FET is turned on) as usual,
provided that the battery voltage reaches the
overdischarge release voltage (VDU) or higher.
Remark If the battery is charged to a voltage higher
than the overcharge detection voltage (VCU) and
the battery voltage does not drops below the
overcharge detection voltage (VCU) even when a
heavy load, which causes an overcurrent, is
connected, the overcurrent 1 and overcurrent 2 do
not work until the battery voltage drops below the
overcharge detection voltage (VCU). Since an actual
battery has, however, an internal impedance of
several dozens of mΩ, and the battery voltage
drops immediately after a heavy load which causes
an overcurrent is connected, the overcurrent 1 and
www.shouding.net
Overcurrent Condition
When the discharging current becomes
equal to or higher than a specified value
(the VM pin voltage is equal to or higher
than the overcurrent detection voltage)
5
REV0.6
SD5351A
Shouding
and the state continues for the overcurrent
detection delay time or longer, the SD5351
turns off the discharging control FET to
stop discharging. This condition is called
overcurrent condition. (The overcurrent
includes overcurrent, or load shortcircuiting.)
The VM and GND pins are shorted
internally by the RVMS resistor under the
overcurrent condition. When a load is
connected, the VM pin voltage equals the
VDD voltage due to the load.
The overcurrent condition returns to the
normal condition when the load is released
and the impedance between the B+ and Bpins becomes higher than the automatic
recoverable impedance. When the load is
removed, the VM pin goes back to the
GND potential since the VM pin is shorted
the GND pin with the RVMS resistor.
Detecting that the VM pin potential is lower
(VIOV), the IC returns to the normal
condition.
elapses.
Abnormal charge current detection is
released when the voltage difference
between VM pin and GND pin becomes
lower than the charger detection voltage
(VCHA) by separating the charger. Since the
0 V battery charging function has higher
priority than the abnormal charge current
detection function, abnormal charge
current may not be detected by the product
with the 0 V battery charging function while
the battery voltage is low.
Load Short-circuiting condition
If voltage of VM pin is equal or below
short circuiting protection voltage (VSHORT),
the SD5351 will stop discharging and
battery is disconnected from load. The
maximum delay time to switch current off is
tSHORT. This status is released when voltage
of VM pin is higher than short protection
voltage (VSHORT), such as when
disconnecting the load.
Delay Circuits
The detection delay time for overdischarge
current 2 and load short-circuiting starts
when overdischarge current 1 is detected.
As soon as overdischarge current 2 or load
short-circuiting is detected over detection
delay time for overdischarge current 2 or
load short- circuiting, the SD5351 stops
discharging. When battery voltage falls
below overdischarge detection voltage due
to overdischarge current, the SD5351 stop
discharging by overdischarge current
detection. In this case the recovery of battery
voltage is so slow that if battery voltage
after overdischarge voltage detection delay
time is still lower than overdischarge
detection voltage, the SD5351 shifts to
power-down.
Abnormal Charge Current Detection
If the VM pin voltage drops below the
charger detection voltage (VCHA) during
charging under the normal condition and it
continues for the overcharge detection
delay time (tCU) or longer, the SD5351 turns
the charging control FET off and stops
charging. This action is called abnormal
charge current detection.
Abnormal charge current detection works
when the discharging control FET is on
and the VM pin voltage drops below the
charger detection voltage (VCHA). When an
abnormal charge current flows into a
battery in the overdischarge condition, the
SD5351 consequently turns the charging
control FET off and stops charging after
the battery voltage becomes the
overdischarge detection voltage and the
overcharge detection delay time (tCU)
6
www.shouding.net
REV0.6
SD5351A
Shouding
the discharging control FET is off and the
charging current flows through the internal
parasitic diode in the discharging control
FET. If the battery voltage becomes equal
to or higher than the overdischarge release
voltage (VDU), the normal condition returns.
Note
(1) Some battery providers do not recommend
charging of completely discharged batteries. Please
refer to battery providers before the selection of 0 V
battery charging function.
(2) The 0V battery charging function has higher
priority than the abnormal charge current detection
function. Consequently, a product with the 0 V
battery charging function charges a battery and
abnormal charge current cannot be detected during
the battery voltage is low (at most 1.8 V or lower).
Figure 4. Overcurrent delay time
0V Battery Charging Function (1) (2) (3)
This function enables the charging of a
connected battery whose voltage is 0 V by
self-discharge. When a charger having 0 V
battery start charging charger voltage
(V0CHA) or higher is connected between B+
and B- pins, the charging control FET gate
is fixed to VDD potential. When the voltage
between the gate and the source of the
charging control FET becomes equal to or
higher than the turn-on voltage by the
charger voltage, the charging control FET
is turned on to start charging. At this time,
www.shouding.net
(3) When a battery is connected to the IC for
the first time, the IC may not enter the normal
condition in which discharging is possible. In
this case, set the VM pin voltage equal to the
GND voltage (short the VM and GND pins or
connect a charger) to enter the normal
condition.
7
REV0.6
SD5351A
Shouding
TIMING CHART
1.
Overcharge and overdischarge detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
ON
CHARGE
OFF
VDD
VMVov1
VSS
VCHA
Charger connection
Load connection
tCL
tCU
(1)
(2)
(1)
(1)
(3)
Figure5-1 Overcharge and Overdischarge Voltage Detection
2.
Overdischarge current detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
VDD
VSHORT
VM
Vov2
Vov1
VSS
Charger connection
Load connection
tIOV2
tIOV1
(1)
(4)
(1)
tSHORT
(4)
(1)
(4)
(1)
Figure5-2 Overdischarge Current Detection
Remark: (1) Normal condition (2) Overcharge voltage condition (3) Overdischarge voltage condition (4)
Overcurrent condition
8
www.shouding.net
REV0.6
SD5351A
Shouding
3.
Charger Detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
VDD
VM
VSS
VCHA
Charger connection
Load connection
tDL
(1)
(3)
(1)
Figure5-3 Charger Detection
4.
Abnormal Charger Detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
ON
CHARGE
OFF
VDD
VM
VSS
VCHA
Charger connection
Load connection
tCU
tDL
(1)
(3)
(1)
(2)
(1)
Figure5-4 Abnormal Charger Detection
www.shouding.net
9
REV0.6
SD5351A
Shouding
TYPICAL CHARACTERISTICS
(Test based on SD5351A version, VBAT = 3.6V, TA= 25°C unless otherwise specified)
Internal FET On-Resistance vs. Junction Temperature
TYPICAL APPLICATION
As shown in Figure 6, the bold line is the high density current path which must be kept as
short as possible. For thermal management, ensure that these trace widths are adequate. C1
is a decoupling capacitor which should be placed as close as possible to SD5351.
Fig 6 SD5351 in a Typical Battery Protection Circuit
Precautions
• Pay attention to the operating conditions for input/output voltage and load current so that the
power loss in SD5351 does not exceed the power dissipation of the package.
• Do not apply an electrostatic discharge to this SD5351 that exceed s the performance ratings of the
built-in electrostatic protection circuit.
www.shouding.net
REV0.6
10
SD5351A
Shouding
PACKAGE OUTLINE
SOT23-5 PACKAGE OUTLINE AND DIMENSIONS
SYMB
OL
DIMENSION
DIMENSION
IN
IN INCHES
MILIMETERS
MIN
MAX
1.050
1.250 0.041 0.049
A1
0.000
0.100 0.000 0.004
A2
1.050
1.150 0.041 0.045
b
0.300
0.400 0.012 0.016
c
0.100
0.200 0.004 0.008
D
2.820
3.020
E
1.500
1.700 0.059 0.067
E1
2.650
2.950 0.104 0.116
e1
L
11
MIN
A
e
www.shouding.net
MAX
0.950 TYP
1.800
0.300
θ
0°
0.037 TYP
2.000 0.071 0.079
0.700 REF
L1
0.111 0.119
0.028 REF
0.600 0.012 0.024
8°
0°
8°
REV0.6
