EA8103T5R
EA8103T5R
    EVERANALOG(申风)
    SOT23-5
    降压型 1.2A 2.6V~6V
EA8103T5R 数据手册
Ultra Low Quiescent Current 1.2A Sync. Buck Converter EA8103 Datasheet General Description The EA8103 is a high switching frequency, high efficiency synchronous buck regulator, designed to operate from 2.6V to 6V input voltage range. Built-in low RDS(ON) high/low side Power-MOSFETS not only reduce external components and has up to 95% efficiency, ideal for 1.2A output current applications. The EA8103 is designed to take into account the light load mode operation and can provide high efficiency over a wide range of the load current. The internal compensation design not only allows users to more simplified application, and can reduce the cost of external components. The EA8103 is available in the SOT-23-5 package and easy to use. Features               1uA Ultra Low Quiescent Current Built-in Low RDS(ON) Power-MOSFETS Efficiency Up to 96% 2.6V to 6V Input Voltage Range Adjustable Output Voltage Range as Low as to 1.13V Fixed 1.35MHz Switching Frequency 1.2A Continuous Load Current
EA8103T5R 价格&库存
很抱歉,暂时无法提供与“EA8103T5R”相匹配的价格&库存,您可以联系我们找货
