SD6411
1.5MHz, 1.3A Synchronous Step-Down Converter
GENERAL DESCRIPTION
FEATURES
The SD6411 are high-efficiency, high
High Efficiency: Up to 96%
frequency synchronous step-down DC-DC
1.5MHz Constant Frequency Operation
regulator ICs capable of delivering up to
1.3A Output Current
can
No Schottky Diode Required
operate over a wide input voltage range from
2.3V to 6V Input Voltage Range
2.3V to 6V and integrates main switch and
Adjustable Output Voltage Range
1.3A output currents. The SD6411
synchronous switch with very low RDS(ON)
Options from 0.6V to Vin
to minimize the conduction loss.
It is ideal for powering portable equipment
100% Duty Cycle Low Dropout
Operation
that runs from a single cell Lithium-Ion (Li+)
Low Quiescent Current: 35µA
battery. The output voltage can be regulated
Slope Compensated Current Mode
as low as 0.6V. The SD6411 can also run
Control for Excellent Line and Load
at 100% duty cycle for low dropout operation,
Transient Response
extending battery life in portable system.
Short Circuit Protection
This device offers two operation modes,
Thermal Fault Protection
PWM mode and PFM Mode switching
Inrush Current Limit and Soft Start
control, which allows a high efficiency over
很抱歉,暂时无法提供与“SD6411”相匹配的价格&库存,您可以联系我们找货
