ZTP7106T
ZTP7106T
    ZILLTEK(钰太)
    SOT23-5
    降压型 1A 2.5V~5.5V
ZTP7106T 数据手册
ZTP7106 1A, 1.5MHz, Synchronous Step-Down Converter FEATURES DESCRIPTION         ZTP7106 is a high efficiency step down DC/DC converter operated with current mode and constant frequency. The internal switch and synchronous rectifier are integrated for high efficiency. External Schottky diodes are not required. The supply current is only 110µA during operation and drops to less than 1µA in shutdown. ZTP7106 can supply 1A of load current from 2.5V to 5.5V supply voltage. The switching frequency is set at 1.5MHz, allowing the use of small surface mount inductors and capacitors. It can run 100% duty cycle for low dropout application. The output voltage of ZTP7106 is adjustable from the FB pin. ZTP7106 is RoHS compliant and Lead (Pb) Free.  1A output current Current mode operation High efficiency up to 95% Shutdown current < 1µA 2.5V to 5.5V supply voltage Over temperature protection Constant frequency operation Full duty ratio, 0 – 100% in dropout RoHS Compliant and Lead (Pb) Free APPLICATIONS         Cellular phones PDAs and smart phones MP3 players Digital still cameras Slim-type DVD Wireless and DSL card Microprocessors and DSP core supplies Portable instruments Pins Configuration Top View TDFN 2x2-6L Top View TSOT23-5L EN ORDERING INFORMATION 1 5 FB GND 2 PART NO. PACKAGE Output Ship, Quantity ZTP7106T TSOT-23-5L Adjust. Tape and Reel ZTP7106D TDFN 2x2-6L Adjust. Tape and Reel SW 3 4 Vin NC 1 6 FB EN 2 5 GND Vin 3 4 SW Typical Application Circuit, Adjustable Output Voltage Vin L1 = 2.2uH Vin Cin = 4.7uF SW ZTP7106 EN C1 R1 Vout Cout = (Adjustable) 10uF FB GND R2 Vout = VFB × (1 + R1/R2) with R1 = 300k for typical application, and C1 should be in the range between 10pF and 47pF for component selection. DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. -1- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 Absolute Maximum Ratings Package Thermal Characteristics (Note 1) Vin to GND …………………………………………… –0.3V to +6V SW Voltage to GND ...…………………… –0.3V to Vin+0.3V EN Voltage to GND ..……………………………… –0.3V to Vin FB/Vout to GND ..………………………………… –0.3V to Vin SW Peak Current ………………………………………….………. 3A Operating Temperature Range ……...… –40°C to +85°C Junction Temperature ……………..………….…........ +150°C Storage Temperature Range …………... –65°C to +150°C Lead Temperature (Soldering 10s) …………...…. +260°C ESD Classification …………………………………………… Class 2 (Note 2) TSOT23-5L: Thermal Resistance, θJA …………..………………… 250°C/W Thermal Resistance, θJC …………..………………… 130°C/W TDFN 2x2-6L: Thermal Resistance, θJA …………..…………………. 120°C/W Thermal Resistance, θJC …………..…………………… 20°C/W Recommended Operating Conditions (Note 3) Supply Input Voltage ……….………………… +2.5V to +5.5V Junction Temperature Range…………… –40°C to +125°C Ambient Temperature Range …………… –40°C to +85°C CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Pins Description TSOT TDFN Symbol Description 23-5L 2x2-6L 1 2 EN Enable control input pin. Electro-Static Discharge Sensitivity This integrated circuit can be damaged by ESD. It is recommended that all integrated circuits be handled with proper precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. 2 5 GND Ground pin. 3 4 SW Power switch output. 4 3 Vin Main supply pin. --- 1 NC 5 6 FB No connected. Feedback pin. Vout=0.6×(1+R1/R2). Add optional C1 to speed up transient response. Block Diagram Vin EN Slop Comp + _ Current Sense Amplifier Reference UG + _ 0.6V FB M1 PWM PWM Comparator Logic Error Amplifier SW LG Oscillator M2 Clock + _ DCC GND Zero-current comparator DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. -2- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 Electrical Specifications (Vin = 5V, Vout= 1.8V, L = 2.2uH, Cout = 10uF, TA = 25°C, unless otherwise specified) PARAMETER Symbol Supply Voltage Output Voltage Line Regulation Output Voltage Load Regulation Reference Voltage Output Range (Adjustable Voltage) Shutdown Current Vin ∆Vout VLR VREF Vout IS Quiescent Current SW Leakage Current IQ ILEAK PMOSFET On Resistance* NMOSFET On Resistance* RDSONP RDSONN PMOSFET Current Limit* ILIM Oscillator Frequency Thermal Shutdown Threshold* EN High Level Input Voltage EN Low Level Input Voltage EN Input Current FOSC TS VENH VENL IEN TEST CONDITIONS Vin = 2.5V to 5.5V For adjustable Vout Vin = 2.5V to 5.5V VEN = 0V VEN = Vin, VFB = VREF × 1.1 No Switching VEN = 0V, VSW = 0V or Vin ISW = 100mA ISW = −100mA Duty cycle = 100% Current Pulse Width < 1ms MIN 2.5 −3 −3 0.588 −3 0.6 0.1 MAX UNIT 5.5 3 3 0.612 +3 1 V %V % V % µA 110 −1 1.2 −40°C ≤ TA ≤ 85°C −40°C ≤ TA ≤ 85°C VEN = 0V to Vin TYP µA 1 250 200 mΩ mΩ 2 A 1.5 160 1.8 1.5 −1 µA 0.4 1 MHz °C V V µA * Guaranteed by design not for test. Note 1: Stresses beyond those listed “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may affect device reliability. Note 2: θJA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity test board of JEDEC 51-3 thermal measurement standard. Pin 2 of TSOT23-5 packages is the case position for θJC measurement. Measured at the exposed pad of the package. Note 3: The device is not guaranteed to function outside its operating conditions. DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. -3- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 Typical Characteristics Startup (Vin=5.0V, Vout=1.8V, Iload=1A) Shutdown (Vin=5.0V, Vout=1.8V, Iload=1A) Vin 5V/div Ven 5V/div Vin 5V/div Ven 5V/div Vout 1V/div Vout 1V/div Isw 1A/div Isw 1A/div 10us/div 200us/div Output Ripple (Vin=5.0V, Vout=1.8V, Iload=1A) Load Transient (Vin=5.0V, Vout=1.8V, Iload=0.05A~1A) Vout 50mV/div Vout 10mV/div IL 1A/div Isw 1A/div 500ns/div 200us/div Short Protection/Current limit (Vin=5.0V, Vout=1.8V, Iload=0A~short) Vout 1V/div Isw 2A/div 200us/div Light Load Efficiency Curve DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. Efficiency vs. Load Current Curve -4- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 FUNCTIONAL DESCRIPTION Dropout Operation Overview ZTP7106 allows the main switch to remain on for more than one switching cycle and increases the duty cycle while the input voltage is dropping close to the output voltage. When the duty cycle reaches 100%, the main switch is held on continuously to deliver current to the output up to the P MOSFET current limit. The output voltage then is the input voltage minus the voltage drop across the main switch and the inductor. The ZTP7106 is a constant frequency current mode PWM step down converter. ZTP7106 is optimized for low voltage, Li-ion battery, powered applications where high efficiency and small size are critical. The device integrates both a main switch and a synchronous rectifier, which provides high efficiency and eliminates an external Schottky diode. ZTP7106 can achieve 100% duty cycle. The duty cycle D of a step down converter is defined as: Short Circuit Protection Where TON is the main switch on time, FOSC is the oscillator frequency (1.5MHz), Vout is the output voltage and Vin is the input voltage. The ZTP7106 has short circuit protection. When the output is shorted to ground, the oscillator frequency is reduced to prevent the inductor current from increasing beyond the P MOSFET current limit. The frequency will return to the normal values once the short circuit condition is removed and the Vout reaches regulated voltage. Current Mode PWM Control Maximum Load Current Slope compensated current mode PWM control provides stable switching and cycle-by-cycle current limit for superior load and line response and protection of the internal main switch and synchronous rectifier. ZTP7106 switches at a constant frequency (1.5MHz) and regulates the output voltage. During each cycle the PWM comparator modulates the power transferred to the load by changing the inductor peak current based on the feedback error voltage. During normal operation, the main switch is turned on for a certain time to ramp the inductor current at each rising edge of the internal oscillator, and switched off when the peak inductor current is above the error voltage. When the main switch is off, the synchronous rectifier will be turned on immediately and stay on until either the next cycle starts or the inductor current drops to zero. The device skips pulses to improve efficiency at light load. The ZTP7106 can operate down to 2.5V input voltage; however the maximum load current decreases at lower input due to large IR drop on the main switch and synchronous rectifier. The slope compensation signal reduces the peak inductor current as a function of the duty cycle to prevent sub-harmonic oscillations at duty cycles greater than 50%. Conversely the current limit increases as the duty cycle decreases. D = TON × FOSC × 100% ≈ Vout × 100% Vin DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. -5- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 required. The ripple voltage is given by: APPLICATION INFORMATION ΔVO = ΔIL [ESR + 1/(8 × f × CO)] Inductor Selection Output Voltage Programming (Adjustable Voltage Version) A 2.2μH to 4.7μH is recommended for general used. The value of inductor depends on the operating frequency. Higher frequency allows smaller inductor and capacitor but increases internal switching loss. Two inductor parameters should be considered, current rating and DCR. The inductor with the lowest DCR is chosen for the highest efficiency. The inductor value can be calculated as: The output voltage of ZTP7106 is set by the resistor divider according to the following formula: VOUT = VFB × (1 + R1/R2) R1 is the upper resistor of the voltage divider. For transient response reasons, a small feed-forward capacitor (CF) is required in parallel to the upper feedback resistor, and 22pF is recommended. L ≥ [VOUT/(f × ΔIL)](1 – VOUT/VIN) ΔIL: inductor ripple current, which is defined as: ΔIL = VOUT[(1 – VOUT/VIN)/(L × f)] ≈ α × IO-MAX Checking Transient Response (General Setting) (α = 0.2~0.4) The regulator loop response can be checked by looking at the load transient response. Switching regulators take several cycles to respond to a step in load current. When a load step occurs, VOUT will be shifted immediately by an amount equal to (ΔILOAD × ESR), where ESR is the effective series resistance of COUT. ΔILOAD will also begin to charge or discharge COUT, which generates a feedback error signal. Then the regulator loop will act to return VOUT to its steady state value. During this recovery time, VOUT can be monitored for overshoot or ringing that will indicate the stability problem. The discharged bypass capacitors are effectively put in parallel with COUT, causing a rapidly drop in VOUT. No regulator can deliver enough current to prevent this problem if the load switch resistance is low and it is driven quickly. The only solution is to limit the rise time of the switch drive, so that the load rise time will be limited to approximately (25 × CLOAD). The inductor should be rated for the maximum output current (IO-MAX) plus the inductor ripple current (ΔIL) to avoid saturation. The maximum inductor current (IL-MAX) is given by: IL-MAX = IO-MAX +ΔIL/2 Capacitor Selection The small size of ceramic capacitors are ideal for ZTP7106 applications. X5R and X7R types are recommended because they retain their capacitance over wider voltage and temperature ranges than other types, such as Y5V or Z5U. A 4.7μF input capacitor and a 10μF output capacitor are sufficient for most ZTP7106 applications. When selecting an output capacitor, consider the output ripple voltage and the ripple current. The ESR of capacitor is a major factor to the output ripple. For the best performance, a low ESR output capacitor is DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. -6- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 PACKAGE DIMENSION (TSOT23-5L) D C B e b A H A1 L Symbol A A1 B b C D e H L Dimensions in mm Min Max 0.700 1.100 0.000 0.130 1.500 1.700 0.300 0.559 2.500 3.100 2.800 3.100 0.950 BSC 0.080 0.200 0.200 0.800 DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. Dimensions in Inch Min Max 0.028 0.043 0.000 0.005 0.059 0.067 0.012 0.022 0.098 0.122 0.110 0.122 0.037 BSC 0.003 0.008 0.008 0.031 -7- 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com ZTP7106 PACKAGE DIMENSION (TDFN 2x2-6L) D D2 L E E2 SEE DETAIL A 1 e A b A3 A1 2 1 DETAIL A A DIMENSION (MM) MIN NOM MAX 0.700 --0.800 DIMENSION (INCH) MIN NOM MAX 0.028 --0.031 A1 0.000 --- 0.050 0.000 --- 0.002 A3 0.175 --- 0.250 0.007 --- 0.010 b 0.200 --- 0.350 0.008 --- 0.014 D 1.950 2.000 2.050 0.077 0.079 0.081 D2 1.000 --- 1.450 0.039 --- 0.057 E 1.950 2.000 2.050 0.077 0.079 0.081 E2 0.500 --- 0.850 0.020 --- 0.033 SYMBOLS e L 0.650 0.250 DS-19; Feb. 10, 2014 Copyright © ZillTek Technology Corp. --- 0.026 0.400 -8- 0.010 --- 0.016 4F-3, No.5, Technology Rd., Science-Based Industrial Park, Hsinchu 30078, Taiwan Tel: (886) 3577 7509; Fax: (886) 3577 7390 Email: sales@zilltek.com
ZTP7106T 价格&库存
很抱歉,暂时无法提供与“ZTP7106T”相匹配的价格&库存,您可以联系我们找货
