FP6396S5
FP6396S5
    FITIPOWER(天鈺科技)
    SOT23-5
    降压型 1.2A 2.5V~6V 停产
FP6396S5 数据手册
FP6396 High Efficiency 1.5MHz 1.2A Synchronous Step Down Converter Description Features The FP6396 is a high efficiency, high frequency synchronous DC-DC step-down converter. The 100% duty cycle feature provides low dropout operation, extending battery life in portable systems.     The internal synchronous switch increases efficiency and eliminates the need for external Schottky diode. At shutdown mode, the input supply current is less than 1µA.           The FP6396 fault protection includes over current protection, short circuit protection, UVLO and thermal shutdown. The Internal soft-start function prevents inrush current at turn-on. The FP6396 is offered in SOT-23-5 and SOT-23-6 Packages. 2.5V~6V Input Voltage Range 0.6V Reference Voltage 1.2A Output Current Low RDS(ON) for Internal Switch (Top/Bottom): 340/210mΩ 1.5MHz Switching Frequency Internal 1ms Soft-Start Time Internal Compensation Function 100% Dropout Operation Power Good Indicator Output (SOT-23-6 Only) Input Over Voltage Protection Over Current Protection Hiccup Short Circuit Protection Over Temperature Protection with Auto Recovery RoHS Compliant and Halogen Free Applications      Pin Assignments Ordering Information FP6396□ S5 Package (SOT-23-5) FB VIN 5 4 1 Set Top Box LCD TV & Tablet AP Router & WiFi Dongle 3.5G & 4G Dongle USB3.0 & SSD storage 2 Package Type S5: SOT-23-5 S6: SOT-23-6 3 EN GND LX S6 Package (SOT-23-6) FB PG VIN 6 5 4 1 2 3 EN GND LX SOT-23-5 Marking Part Number Product Code FP6396S5 FV4 SOT-23-6 Marking Part Number Product Code FP6396S6 FV5 Figure 1. Pin Assignment of FP6396 FP6396-Preliminary 0.3-JAN-2018 1 FP6396 Typical Application Circuit OFF ON EN L1 VIN VIN C1 C4 PG LX VOUT FP6396 R3 PG R1 C3 C2 (opt.) FB GND R2 Figure 2. Schematic Diagram VIN=5V, the recommended BOM list is as below. VOUT 3.3V 2.5V 1.8V 1.5V 1.2V 1.05V C1 4.7μF MLCC 4.7μF MLCC 4.7μF MLCC 4.7μF MLCC 4.7μF MLCC 4.7μF MLCC C4 0.1μF MLCC 0.1μF MLCC 0.1μF MLCC 0.1μF MLCC 0.1μF MLCC 0.1μF MLCC R1 453kΩ 316kΩ 200kΩ 150kΩ 100kΩ 75kΩ R2 100kΩ 100kΩ 100kΩ 100kΩ 100kΩ 100kΩ L1 2.2μH 2.2μH 2.2μH 1.8μH 1.8μH 1.5μH C2 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC Table 1. Recommended Component Values FP6396-Preliminary 0.3-JAN-2018 2 FP6396 Functional Pin Description Pin Name Pin No. (SOT-23-6) Pin No. (SOT-23-5) Pin Function EN 1 1 Enable control pin. Pull high to turn the IC on, and pull low to disable the IC. Don’t leave this pin floating. GND 2 2 Ground pin. LX 3 3 Power switching node. Connect an external inductor to this switching node. VIN 4 4 Power supply input pin. Placed input capacitors as close as possible from VIN to GND to avoid noise influence. PG 5 -- Open drain power good output pin. FB 6 5 Voltage feedback input pin. Connect FB and VOUT with a resistive voltage divider. This IC senses feedback voltage via FB and regulates it at 0.6V. Block Diagram PG (SOT-23-6) EN VIN 2M Power Good Enable Control VIN OVP UVLO Slope Compensation 90% VREF FB 1 COMP Control Logic EA VREF Soft Start OSC OTP Driver Logic X LX COMP GND Figure 3. Block Diagram of FP6396 FP6396-Preliminary 0.3-JAN-2018 3 FP6396 Absolute Maximum Ratings (Note 1) ● VIN to GND ------------------------------------------------------------------------------------------------- -0.3V to +6.5V ● LX to GND --------------------------------------------------------------------------------------------------- -0.3V to (VIN +0.3V) ● EN, FB, PG to GND --------------------------------------------------------------------------------------- -0.3V to VIN ● Package Thermal Resistance, (θJA) (Note 2) SOT-23-5 ---------------------------------------------------------------------------------------- 250°C/W SOT-23-6 ---------------------------------------------------------------------------------------- 250°C/W ● Package Thermal Resistance, (θJC) SOT-23-5 ---------------------------------------------------------------------------------------- 130°C/W SOT-23-6 ---------------------------------------------------------------------------------------- 110ºC/W ● Maximum Junction Temperature (T J) ----------------------------------------------------------------- +150°C ● Lead Temperature (Soldering, 10sec.) --------------------------------------------------------------- +260°C ● Storage Temperature (TS) ------------------------------------------------------------------------------- -65°C to +150°C Note 1: Stresses beyond this listed under “Absolute Maximum Ratings" may cause permanent damage to the device. Note 2: θJA is measured at 25°C ambient with the component mounted on a high effective thermal conductivity 4-layer board of JEDEC-51-7. The thermal resistance greatly varies with layout, copper thickness, number of layers and PCB size. Recommended Operating Conditions ● Supply Voltage (VIN) ------------------------------------------------------------------------------------------- +2.5V to +6V ● Operation Temperature Range (T OPR) -------------------------------------------------------------------- -40°C to +85°C FP6396-Preliminary 0.3-JAN-2018 4 FP6396 Electrical Characteristics (VIN=5V, VOUT=2.5V, TA=25°C, unless otherwise specified.) Parameter Symbol Input Supply Voltage Conditions VIN Input Over Voltage Protection Min 2.5 VIN OVP Shutdown Current ISHDN Quiescent Current Iq Reference Voltage VREF FB Input Leakage Current IFB Typ Max Unit 6.0 V 6.3 V EN=0V 0.1 1 μA VFB=0.65V, IOUT=0A 30 50 μA 0.6 0.612 V 0.01 1 µA 0.588 VFB=VIN P-Channel MOSFET On-Resistance (Note 3) RDS(ON) 340 mΩ N-Channel MOSFET On-Resistance (Note 3) RDS(ON) 210 mΩ ILIM 1.5 A P-Channel Current Limit (Note 3) EN High-Level Input Voltage VEN(H) EN Low-Level Input Voltage VEN(L) EN Input Current 1.5 V 0.4 V IEN 2.5 µA UVLO 2.4 V UVLO Hysteresis VHYS 0.3 V Oscillation Frequency FOSC Under Voltage Lockout Voltage IOUT=200mA 1.2 Minimum On Time 1.5 50 Maximum Duty Cycle 100 Internal Soft Start Time TSS 1.8 MHz ns % 1 ms PG Rising Threshold VPG (H) VFB Rising 90 % PG Low Threshold VPG (L) VFB falling 85 % IPG VPG=0.1V 1 mA 100 Ω 150 °C PG Sink Current LX Discharge Resistance Thermal Shutdown Temperature (Note 3) TSD Note 3: Guarantee by design. FP6396-Preliminary 0.3-JAN-2018 5 FP6396 Typical Performance Curves VIN=5V, VOUT=1.2V, C1=4.7μF//0.1μF, C2=10μF, L1=1.8μH, TA=+25°C, unless otherwise noted. VOUT=1.2V VOUT=3.3V 90 90 80 80 70 70 Efficiency(%) 100 Efficiency(%) 100 60 50 40 30 60 50 40 30 20 20 VIN=3.3V VIN=5V 10 0 VIN=4.2V VIN=5V 10 0 0.01 0.1 1 10 0.01 0.1 Load Current(A) Figure 5. Efficiency vs. Load Current IOUT=1.2A VOUT 20mV/div. IL 100mA/div. VLX 2V/div. VOUT 2mV/div. IL 500mA/div. VLX 2V/div. 20ms/div 1μs/div Figure 6. Steady State Waveform Figure 7. Steady State Waveform IOUT=0A IOUT=1.2A VIN 2V/div. VOUT 500mV/div. VOUT 500mV/div. IOUT IOUT VIN 10 Load Current(A) Figure 4. Efficiency vs. Load Current IOUT=0A 1 2V/div. 500mA/div. VLX 5V/div. VLX 500mA/div. 5V/div. 4ms/div. 4ms/div. Figure 8. Power On through VIN Waveform Figure 9. Power On through VIN Waveform FP6396-Preliminary 0.3-JAN-2018 6 FP6396 Typical Performance Curves (Continued) VIN=5V, VOUT=1.2V, C1=4.7μF//0.1μF, C2=10μF, L1=1.8μH, TA=+25°C, unless otherwise noted. IOUT=1.2A IOUT=0A VIN 2V/div. VIN VOUT 500mV/div. VOUT 500mV/div. IOUT IOUT 1A/div. 500mA/div. VLX VLX 2V/div. 5V/div. 5V/div. 10ms/div. 10ms/div. Figure 10. Power Off through VIN Waveform Figure 11. Power Off through VIN Waveform IOUT=0A IOUT=1.2A VEN 5V/div. VOUT 500mV/div. IOUT VLX 500mA/div. VEN 5V/div. VOUT 500mV/div. IOUT 5V/div. 500mA/div. VLX 5V/div. 4ms/div. 4ms/div. Figure 12. Power On through EN Waveform IOUT=0A Figure 13. Power On through EN Waveform IOUT=1.2A VEN 5V/div. VEN 5V/div. VOUT 500mV/div. VOUT 500mV/div. IOUT IOUT 500mA/div. VLX VLX 1A/div. 5V/div. 5V/div. 4ms/div. 4ms/div. Figure 14. Power Off through EN Waveform Figure 15. Power Off through EN Waveform FP6396-Preliminary 0.3-JAN-2018 7 FP6396 Typical Performance Curves (Continued) VIN=5V, VOUT=1.2V, C1=4.7μF//0.1μF, C2=10μF, L1=1.8μH, TA=+25°C, unless otherwise noted. IOUT=0.1A to 1.2A VOUT 100mV/div. IL 500mA/div. 200μs/div. Figure 16. Load Transient Waveform FP6396-Preliminary 0.3-JAN-2018 8 FP6396 Function Description The FP6396 is a high efficiency, internal compensation and constant frequency current mode step-down synchronous DC/DC converter. It has integrated high-side (340mΩ, typ.) and low-side (210mΩ, typ.) power switches, and provides 1.2A continuous load current. It regulates input voltage from 2.5V to 6V, and down to an output voltage as low as 0.6V. Enable The FP6396 EN pin provides digital control to turn on/off the regulator. When the voltage of EN exceeds the threshold voltage, the regulator will start the soft start function. If the EN pin voltage is below the shutdown threshold voltage, the regulator will turn into the shutdown mode and the shutdown current will be smaller than 1μA. For auto start-up operation, connect EN to VIN. Over Current Protection The FP6396 over current protection function is implemented by using cycle-by-cycle current limit architecture. The inductor current is monitored by measuring the high-side MOSFET series sense resistor voltage. When the load current increases, the inductor current will also increase. When the peak inductor current reaches the current limit threshold, the output voltage will start to drop. When the over current condition is removed, the output voltage will return to the regulated value. Short Circuit Protection The FP6396 employs internal soft start function to reduce input inrush current during start up. The internal soft start time will be 1ms. The FP6396 provides short circuit protection function to prevent the device damaged from short condition. When the short condition occurs and the feedback voltage drops lower than 40% of the regulation level, the oscillator frequency will be reduced and hiccup mode will be triggered to prevent the FP6396 from overheating during the extended short condition. Once the short condition is removed, the frequency and current limit will return to normal. Under Voltage Lockout Over Temperature Protection When the FP6396 is power on, the internal circuits will be held inactive until VIN voltage exceeds the UVLO threshold voltage. And the regulator will be disabled when VIN is below the UVLO threshold voltage. The hysteretic of the UVLO comparator is 200mV (typ). The FP6396 incorporates an over temperature protection circuit to protect itself from overheating. When the junction temperature exceeds the thermal shutdown threshold temperature, the regulator will be shutdown. And the hysteretic of the over temperature protection is 30°C (typ). PG Signal Output Input Over Voltage Protection PG pin is an open-drain output and requires a pull up resistor. PG is actively held low in soft-start, standby and shutdown. It is released when the output voltage rises above 90% of nominal regulation point. The FP6396 supports input over voltage protection. When input voltage exceeds the input over Voltage threshold, the regulator will be shutdown unless the input over voltage is removed. Soft Start FP6396-Preliminary 0.3-JAN-2018 9 FP6396 Application Information Output Voltage Setting The output voltage VOUT is set by using a resistive divider from the output to FB. The FB pin regulated voltage is 0.6V. Thus the output voltage is: T =0. 1+ Output Capacitor Selection R1 R2 Table 2 lists recommended values of R1 and R2 for most used output voltage. Table 2 A low ESR capacitor is required to keep the noise minimum. Ceramic capacitors are better, but tantalum or low ESR electrolytic capacitors may also suffice. The output capacitor is used to keep the DC output voltage and supply the load transient current. When operating in constant current mode, the output ripple is determined by four components: Recommended Resistance Values VOUT R1 R2 3.3V 453kΩ 100kΩ 2.5V 316kΩ 100kΩ 1.8V 200kΩ 100kΩ 1.5V 150kΩ 100kΩ 1.2V 100kΩ 100kΩ R PPL t = R PPL + C t + R PPL ( L R PPL t + R t t The following figures show the form of the ripple contributions. VRIPPLE(ESR)(t) Place resistors R1 and R2 close to FB pin to prevent stray pickup. Input Capacitor Selection The use of the input capacitor is filtering the input voltage ripple and the MOSFETS switching spike voltage. Because the input current to the step-down converter is discontinuous, the input capacitor is required to supply the current to the converter to keep the DC input voltage. The capacitor voltage rating should be 1.25 to 1.5 times greater than the maximum input voltage. The input capacitor ripple current RMS value is calculated as: C (RM = = 1 T T + VRIPPLE(ESL) (t) (t) + VRIPPLE(C) (t) (t) + VNOISE (t) (t) Where D is the duty cycle of the power MOSFET. This function reaches the maximum value at D=0.5 and the equivalent RMS current is equal to IOUT/2. The following diagram is the graphical representation of above equation. = VRIPPLE(t) 0.6 1A ICIN(RMS) (A) 0.5 0.4 (t) 0.3 0.5A 0.2 0.1 0 10 20 30 40 50 60 70 80 90 D (%) FP6396-Preliminary 0.3-JAN-2018 10 FP6396 Application Information (Continued) R PPL ( R = R PPL ( L = R PPL (C = T F C T 1 L R L That will lower ripple current and result in lower output ripple voltage. The Δ L is inductor peak-to-peak ripple current: L L= T F C 2 L C 1 T F C T T The following diagram is an example to graphically represent Δ L equation. Where FOSC is the switching frequency, L is the inductance value, VIN is the input voltage, ESR is the equivalent series resistance value of the output capacitor, ESL is the equivalent series inductance value of the output capacitor and the COUT is the output capacitor. 0.45 It is important to use the proper method to eliminate high frequency noise when measuring the output ripple. The figure shows how to locate the probe across the capacitor when measuring output ripple. Remove the scope probe plastic jacket in order to expose the ground at the tip of the probe. It gives a very short connection from the probe ground to the capacitor and eliminates noise. L=1.5μH ΔIL (A) 0.4 Low ESR capacitors are preferred to use. Ceramic, tantalum or low ESR electrolytic capacitors can be used depending on the output ripple requirements. When using the ceramic capacitors, the ESL component is usually negligible. 0.35 L=1.8μH 0.3 L=2.2μH 0.25 0.2 0.15 2.5 3 3.5 FP6396-Preliminary 0.3-JAN-2018 5.5 6 T(MA T F T C L To guarantee sufficient output current, peak inductor current must be lower than the FP6396 high-side MOSFET current limit. The peak inductor current is shown as below: Ceramic Capacitor P A Load Current The output inductor is used for storing energy and filtering output ripple current. But the trade-off condition often happens between maximum energy storage and the physical size of the inductor. The first consideration for selecting the output inductor is to make sure that the inductance is large enough to keep the converter in the continuous current mode. 5 A good compromise value between size and efficiency is to set the peak-to-peak inductor ripple current Δ L equal to 30% of the maximum load current. But setting the peak-to-peak inductor ripple current Δ L between 20%~50% of the maximum load current is also acceptable. Then the inductance can be calculated with the following equation: L= Inductor Selection 4.5 VOUT=1.2V, FOSC=1.5MHz L =0. GND 4 VIN (V) Probe Ground VOUT T 1 L = T(MA + L 2 IPEAK IOUT(MAX) ∆IL Time 11 FP6396 Application Information (Continued) Feedforward Capacitor Selection PCB Layout Recommendation Internal compensation function allows users saving time in design and saving cost by reducing the number of external components. The use of a feedforward capacitor C6 in the feedback network is recommended to improve transient response or higher phase margin. The device’s performance and stability are dramatically affected by PCB layout. It is recommended to follow these general guidelines shown as below: VOUT R1 FP6396 C3 FB R2 1. Place the input capacitors and output capacitors as close to the device as possible. The traces which connect to these capacitors should be as short and wide as possible to minimize parasitic inductance and resistance. 2. Place feedback resistors close to the FB pin. 3. Keep the sensitive signal (FB) away from the switching signal (LX). 4. Multi-layer PCB design is recommended. C = 2 1 FCR 1 R1 1 1 + R1 R2 GND C1 VOUT L1 C3 VIN 4 3 LX PG 5 2 GND FB 6 1 EN R1 VIN R3 For optimizing the feedforward capacitor, knowing the cross frequency is the first thing. The cross frequency (or the converter bandwidth) can be determined by using a network analyzer. When getting the cross frequency with no feedforward capacitor identified, the value of feedforward capacitor C6 can be calculated with the following equation: C2 GND R2 Figure 17. Recommended Layout Diagram Where FCROSS is the cross frequency. To reduce transient ripple, the feedforward capacitor value can be increased to push the cross frequency to higher region. Although this can improve transient response, it also decreases phase margin and causes more ringing. In the other hand, if more phase margin is desired, the feedforward capacitor value can be decreased to push the cross frequency to lower region. In general, the feedforward capacitor range is between 10pF to 330pF. FP6396-Preliminary 0.3-JAN-2018 12 FP6396 Outline Information SOT-23-5 Package (Unit: mm) SYMBOLS UNIT DIMENSION IN MILLIMETER A A1 A2 B D E E1 e e1 L MIN MAX 0.90 0.00 0.90 0.30 2.80 2.60 1.50 0.90 1.80 0.30 1.45 0.15 1.30 0.50 3.00 3.00 1.70 1.00 2.00 0.60 Note: Followed From JEDEC MO-178-C. Carrier Dimensions Tape Size (W1) mm Pocket Pitch (P) mm 8 4 FP6396-Preliminary 0.3-JAN-2018 Reel Size (A) mm Reel Width (W2) mm Empty Cavity Length mm Units per Reel in 7 180 8.4 300~1000 3,000 13 FP6396 Outline Information (Continued) SOT-23-6 Package (Unit: mm) SYMBOLS UNIT A A1 A2 B D E E1 e e1 L DIMENSION IN MILLIMETER MIN MAX 0.90 0.00 0.90 0.30 2.80 2.60 1.50 0.90 1.80 0.30 1.45 0.15 1.30 0.50 3.00 3.00 1.70 1.00 2.00 0.60 Note: Followed From JEDEC MO-178-C. Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP6396-Preliminary 0.3-JAN-2018 14
FP6396S5 价格&库存
很抱歉,暂时无法提供与“FP6396S5”相匹配的价格&库存,您可以联系我们找货
FP6396S5
  • 1+0.20460
  • 3000+0.18150
库存:9871
FP6396S5
    • 1+0.47330
    库存:27
