Low Dropout Linear Regulator
SD5087
Feature
Description
The SD5087 is 300mA low dropout linear regulator optimized to provide a high performance solution to low power system.
The device offers a new level of cost-effective
performance in cellular phones, laptop and notebook computers, and other portable devices.
Proprietary design techniques ensure high performance.
The SD5087 is designed to make use of low cost
ceramic capacitors which ensure the stability of
the output current, and enhance the efficiency in
order to prolong the battery life of those portable
devices.
The SD5087 regulators are available in the industry standard SOT-23-5/ SC70-5/ DFN1.2*1.6
-4L/ DFN2*2-6L power packages (or upon request).
Input Voltage: 1.8V ~ 5.5V
0.47μF~10μF Ceramic Capacitors Ensure the
Stability
300mA Maximum Output Current
Low Quiescent Current: 60μA
Shut-down Current: < 0.1μA
Overload/Over Temperature Protection
Specified from: -45℃ ~ +80℃
Application
Laptop/notebook/palmtop computers
Portable devices
Disk driver
Battery chargers
Bluetooth and other radio products
MP3/MP4 Players
Cellular phones, radiophone, digital cameras,
and portable electronics
Order Information
SD5087- ① ②:
SYMBOL
①
②
DESCRIPTION (SOT)
Denotes Output Voltage:
K: 1.2V I: 1.3V B: 1.5V C: 1.8V H: 2.5V E: 2.8V F: 3.0V G: 3.3V
Denotes Package Type:
B: SOT-353-5(SC70-5)
SYMBOL
①
②
Rev.1,Jan-2014
E: SOT-23-5L
DESCRIPTION (DFN)
E: 2.8V L:3.1V G: 3.3V
D: DFN1.2*1.6-4L
K: DFN2*2-6L
www.shouding.net
-1-
SD5087
Typical Application Circuit
SD5087
Pin Assignment and Description
PIN No.
NAME
DESCRIPTION
5, 7
GND
Ground
4
4
VOUT
Output Voltage
1
3
3
VIN
Power Supply
3
1
2
EN
ON/OFF Control
4
5
1, 6
NC
No Connect
SOT-23-5L/ SC70-5L
DFN1.2*1.6-4L
DFN2*2-6L
2
2
5
Absolute Maximum Ratings (Note 1)
Input Supply, EN Voltage .......................................................................................................-0.3V ~ 6V
Power Dissipation, PD @ TA=25℃
SOT-23-5L ......................................................................................................................................0.4W
SC70-5, DFN1.2*1.6-4L .................................................................................................................0.3W
DFN2*2-6L ........................................................................................................................................0.5W
Operating Temperature Range (Note 2)............................................................................-45℃ ~ +80℃
Storage Temperature Range.......................................................................................... -65℃ ~ +150℃
Junction Temperature Range.........................................................................................................+125℃
Lead Temperature (Soldering, 10 sec.)......................................................................................... +265℃
Note 1: Stresses beyond those listed Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime.
Note 2: The SD5087 is guaranteed to meet performance specifications from 0℃ to 70℃. Specifications over the –40℃
to 85℃ operating temperature range are assured by design, characterization and correlation with statistical process
controls.
Rev.1,Jan-2014
www.shouding.net
-2-
SD5087
Electrical Characteristics
Operating Conditions: TA=25℃, VIN =VOUT + 0.5V, CIN = COUT =1μF , unless otherwise specified.
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
1.8
5.5
V
-2
+2
VIN
Operating Voltage Range
ΔVOUT
Output Voltage Accuracy
IOUT = 10mA
IQ
Quiescent Current
2.2V ≤ VIN ≤ 5.5V
60
μA
IOFF
Shutdown Current
VEN = 0V, VIN = 5V
0.02
μA
VDROP
Dropout Voltage: VIN -VOUT
IOUT =150mA, VOUT ≤1.8V
IOUT =150mA, VOUT ≥2.8V
150
mV
VENH
EN Threshold Voltage
(High)
VIN = 5V
VENL
(Low)
IEN
Enable Pin Current
ILIM
Current Limited
VIN =VOUT + 1V
PRSS
Power Supply Rejection
Rate
f = 1kHz, IOUT = 100mA
ΔVLINE
Line Regulation
ΔVLOAD
Load Regulation
TSD
ΔTSD
1.4
V
0.8
0.1
330
400
V
μA
560
mA
-65
dB
VIN = (VOUT+0.5) to 5.5V,
IOUT = 0mA
2
mV
0mA ≤ IOUT ≤ 100mA
10
mV
Thermal Shutdown Temperature
160
Thermal Shutdown Hysteresis
Rev.1,Jan-2014
www.shouding.net
-3-
SD5087
Typical Performance Characteristics
Quiescent Current vs. Input Voltage
(Vout=1.8V Io=0A)
140
100
130
95
IO=300mA
120
90
Ground Current (uA)
Quiescent Current(uA)
Ground Current vs. Input Voltage
(Vout=1.8V)
85
80
75
70
65
110
100
90
60
70
55
60
50
IO=150mA
80
IO=1mA
50
2
3
4
5
2
6
2.5
3
(Vout=2.8V Io=0A)
4.5
5
5.5
6
(Vout=2.8V)
150
95
140
90
130
Ground Current (uA)
100
85
80
75
70
65
60
IO=300mA
120
110
IO=150mA
100
90
IO=1mA
80
70
55
60
50
2.5
3
3.5
4
4.5
5
5.5
50
6
2.5
3
3.5
Input Voltage (V)
4
4.5
5
5.5
6
Input Voltage (V)
(Vout=3.3V)
(Vout=3.3V Io=0A)
160
100
95
150
90
140
Ground Current (uA)
4
Input Voltage (V)
Input Voltage (V)
3.5
85
80
75
70
65
60
130
120
110
IO=300mA
100
90
IO=150mA
80
55
70
50
3
3.5
4
4.5
5
5.5
6
Input Voltage (V)
Rev.1,Jan-2014
IO=1mA
60
2
2.5
3
3.5
4
4.5
5
5.5
6
Input Voltage (V)
www.shouding.net
-4-
SD5087
Typical Performance Characteristics(con’t)
Output Voltage vs. Input Voltage
(Vout=1.8V)
1.9
1.9
1.88
1.88
1.86
IO=1mA
1.84
1.86
Output Voltage (V)
Output Voltage (V)
Output Voltage vs. Output Current
(Vout=1.8V)
1.82
1.8
1.78
IO=150mA
1.76
IO=300mA
1.74
1.84
1.82
1.78
2
2.5
3
3.5
4
4.5
5
5.5
1.7
6
Input Voltage (V)
(Vout=2.8V)
50
100 150 200 250 300 350
Output Current (mA)
(Vout=2.8V)
3
3
2.9
IO=1mA
2.9
2.8
2.8
2.7
2.7
2.6
Output Voltage (V)
Output Voltage (V)
VIN =4V
1.72
1.7
IO=150mA
2.5
IO=300mA
2.4
2.3
VIN =4V
VIN =5V
2.6
2.5
2.4
2.3
2.2
2.2
2.1
2.1
2
2
2.5
3
3.5
4
4.5
5
Input Voltage (V)
5.5
6
100 150 200 250
Output Current (mA)
300
350
(Vout=3.3V)
(Vout=3.3V)
3.5
4
3.4
3.9
IO=1mA
3.8
3.2
Output Voltage (V)
Output Voltage (V)
VIN =5V
1.76
1.74
1.72
3.3
VIN =3V
1.8
IO=150mA
3.1
3
2.9
IO=300mA
2.8
3.7
3.6
3.5
3.3
2.7
3.2
2.6
3.1
2.5
2.5
3
3.5
4
4.5
5
5.5
6
Input Voltage (V)
Rev.1,Jan-2014
www.shouding.net
VIN =5V
3.4
VIN =4V
3
100 150 200 250
Output Current (mA)
300
350
-5-
LDO linear regulator
SD5087
Start Up
(VIN = 3.6V, IOUT = 100mA)
VOUT
2.00V/div
VIN
2.00V/div
M 2.50ms
Rev.1,Jan-2014
www.shouding.net
-6-
Pin Functions
SD5087
NC: Not Connect.
EN: ON/OFF Control (High Enable). Forcing this pin above 1.4V enables the part. Forcing this pin below
0.8V can shuts down the device. In shutdown, all functions are disabled drawing 1μF on the
SD5087 input and the amount of capacitance can
be increased without limit. The input capacitor
must be located a distance of not more than 0.5
inch from the input pin of the IC and returned to a
clean analog ground. Any good quality ceramic or
tantalum can be used for this capacitor. The capacitor with larger value and lower ESR
(equivalent series resistance) provides better
PSRR and line-transient response. The output capacitor must meet both requirements for minimum
amount of capacitance and ESR in all LDOs application.
The power supply rejection ratio (PSRR) is defined
as the gain from the input to output divided by the
gain from the supply to the output. The PSRR is
found to be :
The SD5087 is designed specifically to work with
low ESR ceramic output capacitor in space-saving
and performance consideration. Using a ceramic
capacitor whose value is at least 1μF with ESR is
> 25mΩ
The SD5087 still works well with output capacitor
of other types due to the wide stable ESR range.
Note that when heavy load measuring, Δsupply will
cause Δtemperature. And Δtemperature will cause
Δoutput voltage. So the heavy load PSRR measuring must include temperature effect.
Current Limit
The SD5087 contains an independent current limiter, which monitors and controls the pass transistor's gate voltage, limiting the output current to
0.3A (typ.). The output can be shorted to ground
indefinitely without damaging the part.
Enable Function
The SD5087 features an LDO regulator enable/
disable function. To assure the LDO regulator will
switch on, the EN turn on control level must be
greater than 1volts.
For to protecting the system, the SD5087 have a
quick-discharge function. If the enable function is
not needed in a specific application, it may be tied
to VIN to keep the LDO regulator in a continuously
on state.
Rev.1,Jan-2014
www.shouding.net
-8-
SD5087
Packaging Information
SOT-23-5L Package Outline Dimension
Symbol
Dimensions In Millimeters
Min
Max
Dimensions In Inches
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
Rev.1,Jan-2014
www.shouding.net
-9-
SD5087
SC70-5 Package Outline Dimension
Symbol
Min
Max
Min
Max
A
0.900
1.100
0.035
0.043
A1
0.000
0.100
0.000
0.004
A2
0.900
1.100
0.035
0.039
b
0.150
0.350
0.006
0.014
c
0.080
0.150
0.003
0.006
D
2.000
2.200
0.079
0.087
E
1.150
1.350
0.045
0.053
E1
2.150
2.450
0.085
0.096
e
e1
0.650(BSC)
1.200
L
0.026(BSC)
1.400
0.047
0.055
0.021 REF
0.525 REF
L1
0.260
0.460
0.010
0.018
θ
0°
8°
0°
8°
Rev.1,Jan-2014
www.shouding.net
-10-
SD5087
DFN1.2*1.6-4L Package Outline Dimension
Symbol
Min
Max
Min
Max
A
0.500
0.600
0.020
0.024
A1
0.000
0.050
0.000
0.002
A3
0.152 REF.
0.006 REF.
D
1.500
1.700
0.059
0.067
E
1.100
1.300
0.043
0.051
D1
0.560
0.760
0.022
0.030
E1
0.700
0.900
0.028
0.035
b
0.250
0.350
0.010
0.014
b1
0.175
0.275
0.007
0.011
e
L
k
Rev.1,Jan-2014
0.600 TYP.
0.150
0.024 TYP.
0.250
0.200 MIN.
www.shouding.net
0.006
0.010
0.008 TYP.
-11-
SD5087
DFN2*2-6L Package Outline Dimension
Symbol
Min
Max
Min
Max
A
0.700/0.800
0.800/0.900
0.028/0.031
0.031/0.035
A1
0.000
0.050
0.000
0.002
A3
0.203 REF.
0.008 REF.
D
1.924
2.076
0.076
0.082
E
1.924
2.076
0.075
0.083
D1
1.100
1.300
0.043
0.051
E1
0.600
0.800
0.024
0.031
k
b
0.200 MIN.
0.200
e
L
0.008 MIN.
0.300
0.007
0.650 TYP.
0.274
0.012
0.026 TYP.
0.426
0.011
0.017
Shouding reserves the right to update the version of datasheet without notice at any time. Information furnished by
Shouding is believed to be accurate and reliable.
However, no responsibility is assumed for its use.
Rev.1,Jan-2014
www.shouding.net
-12-
很抱歉,暂时无法提供与“SD5087-GEC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75903
- 50+0.59314
- 150+0.51020
- 500+0.44799
- 3000+0.39820
- 6000+0.37325
