BP1361
30V/750mA High Dimming Ratio Constant Current LED Driver
GENERAL DESCRIPTION
APPLICATIONS
The BP1361 is a continuous conduction mode inductive
step-down converter, designed for driving single or
multiple series connected LEDs efficiently from a
voltage source higher than the total LEDs chain voltage.
With few outside components, BP1361 provides a high
price performance ratio solution on the following
applications: MR16 LEDs cup lighting, LEDs stage
lighting, LEDs automotive lighting, LEDs solar lighting
and LEDs Street lighting. The device operates from an
input supply between 5V and 30V and the nominal
average output current is set by an external resistor. The
device provides an externally adjustable output current
of up to 750mA for a single LED. Using the patent
technology, the constant current of LED can be up to
± 3%. A dedicated DIM pin accepts either a DC
voltage (0.5V~2.5V) dimming or a wide range of
pulsed dimming. Applying a voltage of 0.3V or lower
to the DIM pin turns the output off and switches the
device into a low current standby state.
z
z
z
z
z
z
Low voltage halogen replacement MR16/11 LEDs
Automotive LED lighting
LED stage lighting
Solar LED lighting
LED signal lighting
LED Street lighting
FEATURES
z
z
z
z
z
z
z
z
z
Simple low parts count
Wide input voltage range: 5V to 30V
Typical ±3% output current accuracy
LED open-circuit protection
LED short-circuit protection
Up to 750mA output current
Single pin on/off and brightness control using DC
voltage or PWM
High efficiency (up to 97%)
Adjustable Constant LED Current
BP1361 has a build-in power switch, based on different
input voltage, BP1361 can drive several 1W or 3W
LEDs. The device has the function of thermal shutdown
protection and LED short/open-circuit protection.
The BP1361 is available in SOT89-5 packages.
TYPICAL APPLICATION CIRCUIT
Figure 1. Typical Application Circuit
Bright Power Semiconductor
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 1
BP1361
PIN ASSIGNMENT
PIN DESCRIPTIONS
PIN No.
PIN
NAMES
1
CS
2
GND
Signal and power ground. Connect directly to ground plane.
3
DIM
Enable switch, analog and PWM dimming input.
4
SW
Switch Output. SW is the drain of the internal N-Channel MOSFET switch.
5
VIN
Input Supply Pin. Must be locally bypassed.
DESCRIPTION
Current sense input, sampling resistant contacts between CS and VIN
ORDERING INFORMATION
PACKAGE
SOT89-5
TEMPERATURE
ORDERING PART
TRANSPORT
RANGE
NUMBER
MEDIA
-40 ℃ to 85 ℃
BP1361E89E
Tape and Reel
BP1361_DS_EN_V1.1
www.bpsemi.com
MARKING
BP1361
Page 2
BP1361
ABSOLUTE MAXIMUM RATINGS (Note1)
SYMBOL
ITEMS
VALUE
UNIT
VIN
Supply Voltage
-0.3~40
V
SW
Drain Voltage of the internal power switch
-0.3~40
V
CS
Current sense input (Respect to VIN)
+0.3~(-6.0)
V
-0.3~6
V
1
A
DIM
ISW
PDMAX
Logic level dimming input
Switch output current
Power Dissipation (Note 2)
0.6
PTR
Thermal Resistance, SOT89-5
TJ
Operation Junction Temperature Range
TSTG
θJA
Storage Temperature
ESD Susceptibility (Note 3)
100
W
o
C /W
-40 to 150
o
-55 to 150
o
2
C
C
kV
Note 1: Absolute Maximum Ratings indicate that operating beyond these ratings may damage the device.
Recommended Operating Range indicates that the device is functional in that range, but do not guarantee specific
performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test
conditions which guarantee specific performance limits. This assumes that the device is within the Operating Range.
Specifications are not guaranteed for parameters where no limit is given, however, the typical value is a good
indication of device performance.
Note 2: The maximum power dissipation must be decreasing with elevating temperatures and is dictated by TJMAX,
θJA, and the ambient temperature TA. The maximum allowable power dissipation is PDMAX = (TJMAX - TA)/ θJA or the
lower number given in Absolute Maximum Ratings.
Note 3: Human body model, 100pF discharged through a 1.5kΩ resistor.
RECOMMENDED OPERATING RANGE
SYMBOL
ITEMS
VIN
VDD Supply Voltage
TOPT
Operating Temperature
BP1361_DS_EN_V1.1
VALUE
UNIT
0 ~ 30
V
-40 to +85
www.bpsemi.com
o
C
Page 3
BP1361
ELECTRICAL CHARACTERISTICS (Note 4, 5)
Unless specified otherwise, the following specifications apply for VIN=12V, TA=25 oC.
SYMBOL
VIN
ITEMS
CONDITIONS
Input Voltage
VUVLO
VUVLO, HYS
Min.
Typ.
5
Max.
UNIT
30
V
Under voltage lock out
VIN falling
4.7
V
UVLO hysteresis
VIN rising
100
mV
Current Sense
VCS
Mean current sense threshold voltage
VCS_HYS
ICS
VIN-VCS
97
Sense threshold hysteresis
CS Pin Input Current
VIN-VCS=50mV
100
103
mV
±15
8
µA
Operating Frequency
FSW
Maximum operation frequency
1
MHz
Turn Off Current
IOFF
Quiescent supply current with output off
VDIM 115mV, the output of CS
The voltage of DIM pin is divided by the internal and
comparator switches low and the switch turns off. The
external resistor.
current flowing on the RS decreases at another rate.
When (VIN-VCS) < 85mV, the switch turns on again and
the mean current on the LEDs is determined by
I OUT
0.085 + 0.115
= 0.1 / Rs
2 × Rs
DIM pin can be floated at normal working. When a
voltage applied to DIM falls below the threshold (0.3V
nom.), the output switch is turned off. The internal
regulator and voltage reference remain powered during
shutdown to provide the reference for the shutdown
The high-side current-sensing scheme and on-board
circuit. Quiescent supply current during shutdown is
current-setting circuitry minimize the number of
nominally 100uA.
external components while delivering LEDs current
with ±3% accuracy, using a 1% sense resistor.
The BP1361 allows dimming with a PWM signal at the
DIM input. A logic level below 0.3V at DIM forces
BP1361 to turn off the LEDs and the logic level at DIM
must be at least 2.5V to turn on the full LEDs current.
The frequency of PWM dimming ranges from 100Hz to
BP1361_DS_EN_V1.1
Additionally, to ensure the reliability, the BP1361 is
built with a thermal shutdown (TSD) protection and can
link a NTC closing to LEDs by the pin DIM. As a result,
the BP1361 can detect the temperature of LEDs and
change the LEDs current to protect LEDs, (The detail is
in the following application notes.)
www.bpsemi.com
Page 5
BP1361
APPLICATION NOTES
Setting nominal average output current with
external resistor RS
The nominal average output current in the LEDs is
determined by the value of the external current sense
resistor (RS) connected between VIN and CS and is
given by:
I OUT = 0.1 / Rs
( Rs ≥ 0.12Ω)
This equation is valid when DIM pin is floating or
applied with a voltage higher than 2.5V (must be less
than 5V). Actually, RS sets the maximum average
current which can be adjusted to a less one by
dimming.
Output current adjustment by external DC control
voltage
The DIM pin can be driven by an external dc voltage
(VDIM), as shown, to adjust the output current to a
value below the nominal average value defined by
0.1/RS.
(2.5V ≤ V DIM ≤ 5V )
Output current adjustment by PWM control
A Pulse Width Modulated (PWM) signal with duty
cycle PWM can be applied to the DIM pin, as shown
below, to adjust the output current to a value below the
nominal average value set by resistor RS:
I OUT =
0.1 × D
Rs
(0 ≤ D ≤ 100%,2.5V < V pulse < 5V )
If the high voltage is below 2.5V,
I OUT =
(V
pulse
− 0.5) × 0.1 × D
2 × Rs
(0 ≤ D ≤ 100%,0.5V < V pulse < 2.5V )
PWM dimming provides reduced brightness by
modulating the LEDs forward current between 0% to
100%. The LEDs brightness is controlled by adjusting
the relative ratios of the on time to the off time. For
example, a 25% pulse width can set LEDs average
current to 25% of the nominal value defined by 0.1/Rs.
To ensure this switching process between on and off
state is invisible by human eyes, the switching
frequency must be greater than 120 Hz. The advantage
of PWM dimming is that the forward current is always
constant; therefore the LEDs color does not vary with
brightness as it does with analog dimming. Pulsing the
current provides precise brightness control while
preserving the color purity. The dimming frequency of
BP1361 can be as high as 20 kHz.
Shutdown mode
Taking the DIM pin to a voltage below 0.3V will turn
off the output and the supply current will fall to a low
standby level of 100μA nominal.
The average output current is given by:
(0.5V ≤ V DIM ≤ 2.5V )
Soft-start
An external capacitor from the DIM pin to ground will
provide additional soft-start delay on DIM pin, so LED
current will increase slowly and soft-start can be done.
Normally, the relation of soft-start time and capacitance
is approximately 150us/nF.
Note that 100% brightness setting current equaling
Inherent open-circuit and short-circuit LED
to I OUT = 0.1 / Rs , which corresponds to VDIM:
protection
If the connection to the LEDs is open-circuited,
I OUT =
0.1 × (V DIM − 0.5)
2 × Rs
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 6
BP1361
BP1361 will operate in safely low power mode. If
LEDs is short-circuited, BP1361 will operate in the safe
mode with low frequency current limiting protection.
Bypass Capacitor selection
A low ESR capacitor should be used for input
decoupling. The larger ESR value will lead to the lower
efficient. This capacitor has to support the relatively
high peak current to the coil and smooth the current
ripple on the input supply. The minimum value of
2.2uF is acceptable in the case of DC input source. For
the rectified AC input or low voltage input, the bypass
capacitor should be 220uF and the tantalum capacitor
is recommended. The input capacitor should be placed
as close as possible to the input pin.
For guarantee the stability over temperature and voltage,
capacitors with X7R, X5R, or better dielectric are
recommended.
Inductor selection
Recommended inductor value for the BP1361 is 47uH.
The inductor saturation current must be 30% ~ 50%
higher than the output current.
Diode selection
To maximize efficiency and performance, the Diode
should be Schottky diode with a fast recovery, low
forward voltage, low capacitance and low current
leakage. The current and voltage ability depend on the
application. Note that diode should have 30% design
buffer for stable and reliable operation.
It is very important to consider the reverse leakage of
the diode when operating above 85°C. Excess leakage
current will increase the power dissipation of system.
The rectifier diode, rectifying AC12V, must use low
forward voltage Schottky diode to reduce diode
dissipation.
Reducing output ripple
Peak to peak ripple current in the LEDs can be reduced,
if required, by shunting a capacitor across the LEDs:
A value of 1uF will reduce the supply ripple current by
a factor three approximately. Lower ripple can be
achieved with higher capacitor values. Note that the
capacitor will not affect operating frequency or
efficiency, but it will increase start-up delay and change
the frequency of dimming.
Operation Notation at low input voltage
The internal regulator disables the internal power
BP1361_DS_EN_V1.1
switch until the input voltage is above the startup
threshold (VUVLO+100mV). Above the threshold, the
device will start to operate. However, there is an
especial case that if the input voltage is above the
threshold and is too close to the output voltage, then the
switch duty cycle will be high and the device power
dissipation will enlarge. When device operates in this
case for a long time, the device will trigger thermal
shutdown (See detail in section of thermal shutdown
TSD). In practical application, it’s necessary to keep
the potential difference between input and output. The
drive to the switch is turned off when the input voltage
falls below the under-voltage threshold (VUVLO).
Thermal considerations
When the device operates at high ambient temperatures,
or drives the maximum load current, care must be taken
to avoid exceeding the power limitation. The larger
copper area around the chip pin is good to radiate heat.
In practical application, the device mounted on a
25mm2 PCB must have 1oz copper in current density.
Note that the system efficiency will decrease, if
utilizing unsuitable coils or excessive parasitic output
capacitance on the switch output.
Thermal compensation of output current
High luminance LEDs often need to be supplied with a
temperature compensated current in order to maintain
stable and reliable operation at all drive levels. BP1361
can use an external temperature sensing network,
normally using Negative Temperature Coefficient
(NTC) thermal resistors and/or diodes, mounted very
close to the LEDs detecting temperature of LEDs and
changing LEDs current. The output of the sensing
network can be used to drive the DIM pin in order to
reduce output current with increasing temperature.
Thermal shutdown protection
To ensure the reliability, the BP1361 is built with a
thermal shutdown (TSD) protection function. The TSD
protects the IC from over temperature (150℃). When
the chip temperature decreases below (130℃), the IC
recovers again.
PCB Layout considerations
Careful PCB layout is critical to achieve low switching
losses and stable operation. Use a multilayer board
whenever possible for better noise immunity. In order
to minimize current loop noise, the input bypass
capacitor should have an isolate ground plane.
www.bpsemi.com
Page 7
BP1361
SW pin
The SW pin of the device is a fast switching node, so
PCB tracks should be kept as short as possible.
Moreover, the ground pin of the device should be
soldered directly to the ground plane.
Coil and decoupling capacitors and current sense
resistor
It is particularly important to mount the coil and the
input decoupling capacitor as close to the device pins as
possible to minimize parasitic resistance and inductance,
if not system efficiency will be degraded. Depending
on PCB design, more copper tracks between coil and
GND/VCC are useful for lowering interface of coil
skein. It is also important to minimize any track
resistance in series with current sense resistor RS, to
keep the accuracy of sampling current.
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 8
BP1361
TYPICAL PERFORMANCE CHARACTERISTICS
1) Output Current vs Input Voltage of 1W LED
400
350
300
Iout (mA)
250
200
1*1W
3*1W
5*1W
150
100
50
10
12
14
16
18
24
26
28
30
Vin (V)
2)Output Current Deviation vs Input Voltage of 1W LED
5
4
1*1W
3*1W
5*1W
Iout Deviation (%)
3
2
1
-2
-3
-4
-5
8
10
12
14
16
18
24
26
28
30
Vin (V)
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 9
BP1361
3)System Efficiency vs Input Voltage of 1W LED
100
95
Eff (%)
90
85
80
1*1W
3*1W
5*1W
75
70
8
10
12
14
16
18
24
26
28
30
Vin (V)
4)Output Current vs Input Voltage of 3W LED
800
750
Iout (mA)
700
650
600
1*3W
3*3W
550
500
8
10
12
14
16
18
24
26
28
30
Vin (V)
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 10
BP1361
5)Output Current Deviation vs Input Voltage of 3W LED
5
4
3
Deviation (%)
2
1
-2
1*3W
3*3W
-3
-4
-5
8
10
12
14
16
18
24
26
28
30
24
26
28
30
Vin (V)
6)System Efficiency vs Input Voltage of 3W LED
100
95
Eff (%)
90
85
80
1*3W
3*3W
75
70
8
10
12
14
16
18
Vin (V)
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 11
BP1361
7) LED Current vs Vdim
400
350
Iout (mA)
300
250
200
150
100
1*1W
50
0.5
1.0
1.5
2.0
2.5
3.0
Vdim (V)
8) Output Current vs Dim Duty (200Hz)
Duty vs Iout
800
700
1W LED
3W LED
600
Iout (mA)
500
400
300
200
100
60
80
100
Duty (%)
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 12
BP1361
9) Vcs vs Temperature
102.0
101.8
101.6
Vcs (mV)
101.4
101.2
101.0
100.8
100.6
100.4
100.2
100.0
-20
60
80
100
Temp
TYPICAL APPLICATION CIRCUIT of MR16
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 13
BP1361
PACKAGE INFORMATION
SOT89-5 Package
BP1361_DS_EN_V1.1
www.bpsemi.com
Page 14
