1N5399G
1N5399G
    PINGWEI(平伟)
    DO-15(DO-204AC)
    1N5399G
1N5399G 数据手册
1N5391G THRU 1N5399G 1.5AMPS . GLASS PASSIVATED RECTIFIERS FEATURE DO-15 .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10sec/ 0.375" lead length at 5 lbs tension 1.0(25.4) M IN . .140(3.6) D IA. .104(2.6) + .300(7.6) .230(5.8) MECHANICAL DATA .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any - 1.0(25.4) M IN . .034(0.9) D IA. .028(0.7) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% SYM BOL Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TA =55°C 1N 1N 1N 1N 1N 1N 1N 5391G 5392G 5393G 5395G 5397G 5398G 5399G 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V 50 100 200 400 600 800 1000 V VRRM VRMS VDC units IF(AV) 1.5 A IFSM 45.0 A VF 1.0 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 1.5A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =125°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Storage Temperature Operation JunctionTemperature 5.0 IR 100.0 CJ R(JA) TSTG TJ 30 pF 75 °C/W -55 to +150 °C -55 to +175 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. - 351 - µA RATING AND CHARACTERISTIC CURVES (1N5391G THRU 1N5399G) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 2.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 1.5 1.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1.0 .1 .01 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle LEAD TEMPERTURE,(℃) 1.0 .8 .6 1.2 1.4 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 80 8.3ms Single Half Sine-Wave (JEDEC Method) INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 10 60 40 20 0 1 10 100 1.0 ℃ .1 .01 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz - 352 - 140
1N5399G
物料型号:1N5391G 至 1N5399G
器件简介: - 高电流能力 - 低正向电压降 - 低功耗,高效率 - 高浪涌能力 - 保证260°C/10秒/0.375英寸引脚长度在5磅张力下的高温焊接
引脚分配:根据MIL-STD 202E标准,方法208C,采用镀轴向引脚可焊
参数特性: - 工作温度范围:-55°C 至 +150°C(存储);-55°C 至 +175°C(运行) - 封装:模塑,符合UL-94 V-0阻燃环氧树脂
功能详解: - 极性:色环表示阴极 - 安装位置:任意
应用信息:适用于单相、半波、60Hz、电阻性或感性负载。对于电容性负载,电流需降低20%。
封装信息: - 尺寸:以英寸和毫米为单位提供,包括最小和最大尺寸
电气特性: - 最大重复峰值反向电压(VRRM) - 最大RMS电压(Vrms) - 最大直流阻断电压(VDC) - 最大平均正向整流电流(IF) - 峰值正向浪涌电流(IFSM) - 在25°C环境温度下,1.5A直流时的最大正向电压(VF @TA=25°C) - 典型结电容 - 典型热阻
1N5399G 价格&库存
很抱歉,暂时无法提供与“1N5399G”相匹配的价格&库存,您可以联系我们找货
