SR2200
SR2200
    SUNMATE(森美特)
    DO-15(DO-204AC)
    电压:200V 电流:2A
SR2200 数据手册
SR2150 - SR2200 SCHOTTKY BARRIER RECTIFIER DIODE VOLTAGE RANGE: 150 - 200V CURRENT: 2.0 A Features ! ! ! ! ! Low forward voltage drop High current capability High reliability High surge current capability Epitaxial construction B A A Mechanical Data ! ! ! ! C D Case: DO-15,Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed Polarity: Color band denotes cathode end Mounting position: Any DO-15 Dim Min Max A 25.40 — B 5.50 7.62 C 0.686 0.889 2.60 3.60 D All Dimensions in mm Maximum Ratings and Electrical Characteristics TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbol SR2150 SR2200 Unit Maximum repetitive peak reverse voltage VRRM VRMS VDC 150 105 150 200 140 200 Volts Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range Characteristic Volts Volts I(AV) 2.0 Amps IFSM 50.0 Amps VF IR CJ RθJA TJ TSTG 0.85 0.95 0.2 2.0 80 88 -65 to +150 -65 to +150 Volts mA pF C/W C C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 1 of 2 www.sunmate.tw AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES SR2150 THRU SR2200 PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 1.6 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.8 0.4 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 10 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 SR2150 0.1 SR2200 0.01 0.2 0.4 0.6 0.8 1.0 1.1 100 10 TJ=100 C 1 TJ=75 C 0.1 TJ=25 C 0.01 0.001 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 TRANSIENT THERMAL IMPEDANCE, C/W PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 100 2000 1000 100 TJ=25 C FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 10 0.1 1.0 10 0.1 1 10 100 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 2 of 2 www.sunmate.tw
SR2200 价格&库存
很抱歉,暂时无法提供与“SR2200”相匹配的价格&库存,您可以联系我们找货
SR2200
  • 10+0.28708
  • 100+0.22798
  • 300+0.19843
  • 2000+0.17135
  • 4000+0.15360
  • 10000+0.14467
库存:1463
