HER203-TB
HER203-TB
    GDGROUP(台湾固锝)
    DO-15(DO-204AC)
    耐压:200V 电流:2A 反向恢复时间:50NS
HER203-TB 数据手册
HER201 THRU HER208 HIGH EFFICIENCY RECTIFIERS Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Amperes DO-15 FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 High speed switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.0 (25.4) MIN. 0.140(3.6) 0.104(2.6) DIA. 0.300(7.6) 0.230(5.8) MECHANICAL DATA 1.0 (25.4) MIN. 0.034(0.86) 0.028(0.70) DIA. Dimensions in inches and (millimeters) Case: JEDEC DO-15 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.014 ounce, 0.40 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS HER Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=50 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) VRRM VRMS VDC 201 HER 202 50 35 50 100 70 100 HER 203 HER HER 204 205 HER 206 HER 207 HER 208 UNITS 200 300 400 140 210 280 200 300 400 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS I(AV) 2.0 Amps IFSM 60.0 Amps VF 1.0 1.3 1.70 5.0 100.0 IR trr 50 CJ 30.0 R JA 50.0 TJ,TSTG -65 to +150 Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted Typical thermal resistance (NOTE 3) Operating junction and storage temperature range 1 Volts A 70 ns 20.0 pF C/W C GOOD ELECTRONIC CO., LTD FIG. 1- FORWARD CURRENT DERATING CURVE PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES HER201 THRU HER208 2.0 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 60 50 40 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 20 175 10 1 10 AMBIENT TEMPERATURE, C 20 TJ=25 C 10 PULSE WIDTH=300 s 1%DUTY CYCLE 1 0.1 HER201-HER203 HER204-HER205 HER206-HER208 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 0.01 0.2 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 FIG. 5-TYPICAL JUNCTION CAPACITANCE 100 TJ=25 C 10 HER201-HER205 HER206-HER208 TRANSIENT THERMAL IMPEDANCE, C/W PERCENT OF PEAK REVERSE VOLTAGE,% 200 JUNCTION CAPACITANCE, pF 100 NUMBER OF CYCLES AT 60 Hz FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 2 GOOD ELECTRONIC CO., LTD
HER203-TB 价格&库存
很抱歉,暂时无法提供与“HER203-TB”相匹配的价格&库存,您可以联系我们找货
