S R220 THRU S R225 0
2.0 AMP. Schottky Barrier Rectifiers
Features
· Low forward voltage drop
· High current capability
DO-15
· High reliability
· High surge current capability
· Plastic material-UL flammability 94V-0
MIN.
DIA.
Mechanical Data
· Case: Molded plastic
DO-15
· Terminals: Plated leads solderable per
MIL-STD-202,Method 208 guaranteed
DIA.
· Polarity: Color band dentes cathode end
MIN.
· Mounting Position: Any
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified
Single phase,half wave,60Hz,resistive or inductive load
For capacitive load derate current by 20%
Type Number
SYMBOL
SR SR SR
220 230 240
SR SR SR
245 250 260
SR SR SR SR SR
Unit
280 2100 2150 2200 2250
30
40
60
80
100
150
200
250
V
21
26
45 50
31. 5 35
42
56
80
105
140
175
V
30
40
45
60
80
100
150
200
250
V
Maximum Recurrent Peak Reverse Voltage
VRRM
Maximum RMS Voltage
VRMS
Maximum DC Blocking Voltage
VDC
Average Rectified Output Current (Note 1)
@TL=100 ℃
Peak Forward Surge Current 8.3ms Single half
sine-wave superimposed on rated load (JEDEC
Method)
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage
@IF=2.0A
Peak Reverse Current
@TA=25℃
IF(AV)
2.0
A
IFSM
60
A
I 2t
14.94
A2s
At Rated DC Blocking Voltage @TA=100℃
Typical Junction Capacitance
CJ
Operating Temperature Range
Storage Temperature Range
0.55
VFM
IR
Typical Thermal Resistance Junction to
Ambient(Note 2)
50
0.7
0.85
0.92
0.1
0.05
10.0
5.0
220
R θJA
V
mA
180
pF
75.0
℃/W
TJ
-55 to + 150
TSTG
-55 to + 150
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case
2.P.C.B.mounted with 0.2x 0.2" (5.0x 5.0mm) copper pad areas
version:02
0.95
1of3
www.dyelec.com
FIG.2-TYPICAL FORWARD CHARACTERISTICS
INSTANTANEOUS FORWARD CURRENT ( A )
1.6
1.2
0.8
0.4
75
100
125
150
175
10.0
1
0.01
LEAD TEMPERATURE, ℃
INSTANTANEOUS REVERSE CURRENT (mA )
PEAK FORWARD SURGE CURRENT (A)
60
45
30
15
4
6 8 10
0.4
0.6
0.8
1.0
1.2
1.4
1.6
V
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
60
REVERSE VOLTAGE
NUMBER OF CYCLES AT 60Hz
version:02
0.2
FIG. 4 – TYPICAL JUNCTION CAPACITANCE
75
2
FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT
1
SR220-SR245
SR250-SR260
SR280-SR2100
SR2150-SR2200
SR2250
0.1
2of3
80
25
TA=25 C
100
2.0
AVERAGE FORWARD CURRENT (A)
FIG. 1 – FORWARD CURRENT DERATING CURVE
www.dyelec.com
Important Notice and Disclaimer
•Reproducing and modifying information of the document is prohibited without permission
from DIYI.
• DIYI reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design, purchase or use.
•DIYI disclaims any and all liability arising out of the application or use of
any product including damages incidentally and consequentially occurred.
•DIYI does not assume any and all implied warranties, including warranties of fitness for
particular purpose, non-infringement and merchantability.
Applications shown on the here in document are examples of standard use and
operation. Customers are responsible in comprehending the suitable use in particular
applications.
DIYI makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
•The products shown here in are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving
or life-sustaining, such as medical instruments, transportation equipment, aerospace
machinery et cetera. Customers using or selling these products for use in such applications
do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such
improper use or sale.
•Since DIYI uses lot number as the tracking base, please provide the lot number for tracking
when complaining.
version:02
3 of 3
www.dyelec.com
很抱歉,暂时无法提供与“SR240”相匹配的价格&库存,您可以联系我们找货
