MOSPEC
SR2100L
Schottky Barrier rectifiers
SCHOTTKY BARRIER
RECTIFIERS
Using the Schottky Barrier principle with a Refractory metal capable of
high temperature operation metal. proprietary barrier technology allows for
reliable operation up to 150℃ junction temperature. Typical application are
in switching Mode Power Supplies such as adaptors, DC/DC converters
free- wheeling and polarity protection diodes.
2.0 AMPERES
100 VOLTS
*Low Forward Voltage.
*Low Switching noise.
*High Current Capacity
*Guarantee Reverse Avalanche.
*Guard-Ring for Stress Protection.
*Low Power Loss & High efficiency.
*150℃ Operating Junction Temperature
*Low Stored Charge Majority Carrier Conduction.
*Plastic Material used Carries Underwriters Laboratory
Flammability Classification 94V-O
DO-201AD
*In compliance with EU RoHs 2002/95/EC directives
The marking is indicated by part no. with. “M”. ex:SR2100LM
MAXIMUM RATINGS
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectifier Forward Current
Non-Repetitive Peak Surge Current (Surge
applied at rate load conditions halfware, single
phase, 60Hz)
Operating and Storage Junction Temperature
Range
Symbol
SR2100L
Unit
VRRM
VRWM
VR
100
V
VR(RMS)
70
V
IO
2.0
A
50
A
-65 to +150
IFSM
TJ , TSTG
ELECTRICAL CHARACTERISTICS
Characteristic
Maximum Instantaneous Forward Voltage
( IF =0.1 Amp TC = 25℃)
( IF =1.0 Amp TC = 25℃)
( IF =2.0 Amp TC = 25℃)
Maximum Instantaneous Reverse Current
( Rated DC Voltage, TC = 25℃ )
( Rated DC Voltage, TC = 125℃ )
Maximum Thermal Resistance Junction to case
Typical Junction Capacitance
( Reverse Voltage of 4 volts & f=1 MHz )
Symbol
VF
SR2100L
Min.
Typ.
0.36
0.65
0.79
Unit
Max.
0.38
0.70
0.82
0.01
10
mA
RθJC
55
℃/W
80
MILLIMETERS
MIN
A
5.00
MAX
5.60
B
25.40
C
8.50
9.50
D
1.20
1.30
V
IR
CP
DIM
PF
CASE--Transfer molded
plastic
OLARITY--Cathode indicated
polarity band
SR2100L
NSTANTANEOUS FORWARD CURRENT (Amp.)
FIG-2 TYPICAL FORWARD CHARACTERISITICS
TJ=125℃
TJ=75℃
TJ=25℃
CASE TEMPERATURE (℃)
FORWARD VOLTAGE (Volts)
FIG-3 TYPICAL REVERSE CHARACTERISTICS
FIG-4 TYPICAL JUNCTION CAPACITANCE
Tj=125
o
o
Tj=75 c
o
Tj=25 c
REVERSE VOLTAGE (Volts)
JUNCTION CAPACITANCE (PF)
INSTANTANEOUS REVERSE CURRENT (mA.)
AVERAGE FORWARD RECTIFIED CURRENT (Amp.)
FIG-1 FORWARD CURRENT DERATING CURVE
PEAK FORWARD SURGE
CURRENT (Amp.)
FIG-5 PEAK FORWARD SURGE CURRENT
NUMBER OF CYCLES AT 60 Hz
7M-A
很抱歉,暂时无法提供与“SR2100L”相匹配的价格&库存,您可以联系我们找货
免费人工找货 - 国内价格
- 10+ 0.21525 10+ 0
- 100+ 0.2106 100+ 0
- 300+ 0.20747 300+ 0
- 1000+ 0.20434 1000+ 0
- 国内价格
- 10+ 0.3263 10+ 0
- 100+ 0.25865 100+ 0
- 300+ 0.22483 300+ 0
- 3000+ 0.19946 3000+ 0
- 6000+ 0.17914 6000+ 0
- 9000+ 0.16903 9000+ 0
- 国内价格
- 10+ 0.37887 10+ 0
- 100+ 0.30262 100+ 0
- 300+ 0.2646 300+ 0
- 3000+ 0.22086 3000+ 0
