SR340
SR340
    GDGROUP(台湾固锝)
    DO-15(DO-204AC)
    电压:40V 电流:3A
SR340 数据手册
SR320 THRU SR3200 SCHOTTKY BARRIER RECTIFIER REVERSE VOLTAGE: FORWARD CURRENT: 20 to 200 VOLTS 3.0 AMPERE FEATURES · High current capability DO-201AD · High surge current capability · Low forward voltage drop · Exceeds environmental standards of MIL-S-19500/228 · For use in low voltage, high frequency inverters free wheeling, and porlarlity protection applications MECHANICAL DATA Case: Molded plastic, DO-201AD Epoxy: UL 94V-O rate flame retardant Lead: Axial leads, solderable per MIL-STD-202, method 208 guaranteed Polarity: Color band denotes cathode end Mounting position: Any Weight: 0.04ounce, 1.1gram Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60HZ, resistive or inductive load. For capacitive load, derate current by 20%. Symbols SR320 SR330 SR340 SR350 SR360 Maximum Recurrent Peak Reverse Voltage VRRM 20 30 40 50 60 80 100 150 200 Volts Maximum RMS Voltage VRMS 14 21 28 35 42 56 70 105 140 Volts Maximum DC Blocking Voltage VDC 20 30 40 50 60 80 100 150 200 Volts Maximum Average Forward Rectified Current .375"(9.5mm) Lead Length SR380 SR3100 SR3150 SR3200 Units I(AV) 3.0 Amp IFSM 80 Amp Peak Forward Surge Current, 8.3ms single half-sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A DC and 25℃ Maximum Reverse Current at TA=25℃ at Rated DC Blocking Voltage TA=100℃ Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Operating Junction Temperature Range Storage Temperature Range VF 0.55 0.85 2.0 IR 200 ℃/W -55 to +150 -55 to +125 Tstg NOTES: 1- Measured at 1 MHZ and applied reverse voltage of 4.0 VDC. 2- Thermal Resistance From Junction to Ambient 0.375"(9.5mm) lead length P.C.B. Mounted -55 to +150 Volts pF 40 RθJA 0.95 mAmp 30 CJ TJ 0.7 ℃ ℃ SR320 THRU SR3200 SCHOTTKY BARRIER RECTIFIER RATINGS AND CHARACTERISTIC CURVES
SR340
物料型号:SR320 至 SR3200 SCHOTTKY BARRIER RECTIFIER
器件简介:肖特基势垒整流器,具有高电流能力、高浪涌电流能力、低正向电压降,超过MIL-S-19500/228环境标准,适用于低电压、高频逆变器自由轮转和极性保护应用。
引脚分配:轴向引脚,根据MIL-STD-202方法208保证可焊性。
参数特性:包括最大重复峰值反向电压(VRRM)、最大RMS电压(VRMS)、最大直流阻断电压(VDe)、最大平均正向整流电流(L(AV))、峰值正向浪涌电流(IysM)、最大正向电压(Vy)、在额定直流阻断电压下的最大反向电流(Ig)、典型结电容(C1)、典型热阻(ROJA)、工作结温范围(TJ)和存储温度范围(Tstg)。
功能详解:文档提供了正向电流、反向电压降、瞬态正向电压特性和结电容的典型曲线图。
应用信息:适用于低电压、高频逆变器自由轮转和极性保护应用。
SR340 价格&库存
很抱歉,暂时无法提供与“SR340”相匹配的价格&库存,您可以联系我们找货
