RL207G
RL207G
    DY(迪一电子)
    DO-15(DO-204AC)
    二极管配置:-;直流反向耐压(Vr):1kV;平均整流电流(Io):2A;正向压降(Vf):1V@2A;反向电流(Ir):5uA@1kV;
RL207G 数据手册
RL201G THRU RL207G 2.0 AMPS. Glass Passivated Rectifiers Features · Low forward voltage drop DO-15 · High current capability · High reliability · High surge current capability MIN. Mechanical Data DIA. · Case: Molded plastic DO-15 · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end DIA. · Mounting Position: Any MIN. · Weight: 0.40Grams Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% RL SYMBOL 201G Type Number RL 202G RL 203G RL 204G RL 205G RL 206G RL 207G Unit Maximum Recurrent Peak Reverse Voltage VRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Average Rectified Output Current (Note 1) @TL =100 ℃ IF(AV) 2.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=2.0A Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @T A =125 ℃ Typical Junction Capacitance (Note 2) Typical Thermal Resistance Junction to Ambient (Note 3) Operating Temperature Range Storage Temperature Range I 2t A2s 10.375 1.0 VFM V 5.0 IR uA 100 Cj R θJA 8 pF 65 ℃ /W Tj -65 to +150 ℃ TSTG -65 to +150 ℃ Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 3.P.C.B.mounted with 0.2x 0.2" (5.0x 5.0mm) copper pad areas version:03 1of3 www.dyelec.com RL201G THRU RL207G FIG.2 – TYPICAL FORWARD CHARACTERISTICS 10 FIG. 1 - FORWARD CURRENT DERATING CURVE INSTANTANEOUS FORWARD CURRENT(A) 2.0 1.5 1.0 0.5 0 25 50 75 100 125 150 LEAD TEMPERATURE, ℃ TA = 25℃ C 0.1 PULSE WIDTH 300us 0.01 0 1.2 1.4 0.4 0.6 0.8 1.0 4 INSTANTANEOUS FORWARD VOLTAGE 0.2 1.6 ) 0 1.0 V 1.8 ( AVERAGE FORWARD CURRENT AMPERES (A) 2.5 FIG. 4 – TYPICAL JUNCTION CAPACITANCE 100 FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 90 70 CAPACITANCE, (pF), PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) 80 60 50 40 30 10 TA = 25°C f = 1 MHz 20 10 0 2 5 10 20 50 100 1 NUMBER OF CYCLES AT 60Hz 1 4 10 REVERSE VOLTAGE version:03 2of3 40 ) 1 V ( PEAK FORWARD SURGE CURRENT AMPERES (A) 100 www.dyelec.com 100 RL201G THRU RL207G Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:03 3of3 www.dyelec.com
RL207G 价格&库存
很抱歉,暂时无法提供与“RL207G”相匹配的价格&库存,您可以联系我们找货
RL207G
  • 20+0.17076
  • 200+0.13395
  • 600+0.11348
  • 3000+0.10118
  • 9000+0.09056
  • 21000+0.08484
库存:37
