FR204
FR204
    PINGWEI(平伟)
    DO-15(DO-204AC)
    FR204
FR204 数据手册
FR201 THRU FR20 FR2077 AMP S . FAST RECOVERY RECTIFIERS 2.0 2.0AMP AMPS FEATURE DO-15 .Fast switching .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10sec/ 0.375" lead length at 5 lbs tension 1.0(25.4) MIN. .140(3.6) .104(2.6) + .300(7.6) .230(5.8) MECHANICAL DATA .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any DIA. - 1.0(25.4) MIN. .034(0.9) .028(0.7) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% SYM BOL Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TA =55°C VRRM VRMS VDC FR 201 50 FR 202 100 FR 203 200 FR 204 400 FR 205 600 FR 206 800 FR 207 1000 35 70 140 280 420 560 700 V 50 100 200 400 600 800 1000 V units V IF(AV) 2.0 A IFSM 60.0 A VF 1.3 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous forward Voltage at 2.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Typical Thermal Resistance (Note 3) Storage Temperature Operation JunctionTemperature 5.0 IR µA 100.0 trr CJ R(JA) TSTG TJ 150 250 nS 30 pF 75 °C/W -55 to +150 °C -55 to +125 °C Note: 1. Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 3. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. - 137 - 500 RATING AND CHARACTERISTIC CURVES (FR201 THRU FR207) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 2.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 1.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 150 100 1.0 TJ=25℃ Pulse Width=300μs 1% Duty Cycle .1 .01 200 1.4 1.0 .6 1.8 2.2 AMBIENT TEMPERTURE,(℃) INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT FIG.4-TYPICAL REVERSE CHARACTERISTICS 80 INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 10 8.3ms Single Half Sine-Wave (JEDEC Method) 60 40 20 1.0 TJ=25℃ .1 .01 0 0 100 10 0 20 40 60 FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERSITIC (+) 25Vdc (approx) (-) 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 50 Ω NONINDUCTIVE 80 10 Ω NONINDUCTIVE +0.5A 0 (+) PULSE -0.25A GENERATOR (NOTE 2) 1Ω (NOTE 1) NON- OSCILOSCOPE INDUCTIVE (-) -1.0A NOTES: NOTES:1. Rise Time=7ns max, Input Impedance= 1 megohm.22pF. 2. Rise Time=10ns max, Souce Impedance= 50 ohms. - 138 - trr 140
FR204 价格&库存
很抱歉,暂时无法提供与“FR204”相匹配的价格&库存,您可以联系我们找货
