FR201
THRU
FR207
2.0 AMP FAST RECOVERY RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
2.0 Amperes
FEATURES
* Low forward voltage drop
* High current capability
* High reliability
* High surge current capability
DO-15
.140(3.6)
.104(2.6)
DIA.
1.0(25.4)
MIN.
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Lead: Axial leads, solderable per MIL-STD-202,
method 208 guranteed
* Polarity: Color band denotes cathode end
* Mounting position: Any
.300(7.6)
.230(5.8)
1.0(25.4)
MIN.
.034(.9)
.028(.7)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
FR201 FR202 FR203
50
35
50
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
100
70
100
FR204 FR205 FR206 FR207 UNITS
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
.375"(9.5mm) Lead Length at Ta=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
2.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 2.0A
Maximum DC Reverse Current
Ta=25 C
60
1.3
5.0
A
V
A
100
at Rated DC Blocking Voltage
Ta=100 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Operating and Storage Temperature Range TJ, TSTG
250
150
-65
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
180
40
+150
500
A
nS
pF
C
RATING AND CHARACTERISTIC CURVES (FR201 THRU FR207)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
3.0
2.5
2.0
Single Phase
1.5
Half Wave 60Hz
Resistive Or Inductive Load
1.0
0.375"(9.5mm) Lead Length
0.5
60
Tj=25 C
80
100
120
140
160
180
200
AMBIENT TEMPERATURE,( C)
Pulse Width 300us
1% Duty Cycle
0.1
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PEAK FORWARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
PULSE
GENERATOR
(NOTE 2)
100
80
60
Sine Wave
40
JEDEC method
5
1W
NONINDUCTIVE
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
-0.25A
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
+0.5A
50
10
NUMBER OF CYCLES AT 60Hz
OSCILLISCOPE
(NOTE 1)
trr
8.3ms Single Half
Tj=25 C
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
50
120
100
80
60
40
-1.0A
1cm
.01
SET TIME BASE FOR
.05
.1
.5
1
REVERSE VOLTAGE,(V)
50 / 10ns / cm
181
5
10
50
100
很抱歉,暂时无法提供与“FR204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28998
- 100+0.23145
- 300+0.20218
