SB2P45-41
SB2P45-41
2.0AMPS. PLANAR MOS SCHOTTKY RECTIFIERS
DO-41
FEATURE
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /1 0sec/0.375" lead length at 5 lbs tension
1.0(25.4)
MIN.
.110(2.8)
.080(2.0)
.205(5.2)
.166(4.2)
MECHANICAL DATA
.Terminal: Plated axial leads solderable per
MIL-STD 202E, method 208C
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Polarity: color band denotes cathode
.Mounting position: any
1.0(25.4)
MIN.
DIA.
.032(0.8)
.025(0.65)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rated load
Maximum Forward Voltage
@2.0A DC
at Tj=25℃
@0.5A DC
@2.0A DC
at Tj=100℃
@0.5A DC
Maximum DC Reverse Current
@Tj=25°C
atratedDCblockingvoltage
@Tj=100°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
SYM
BOL
VRRM
VRMS
VDC
IF(AV)
IFSM
SB2P45
units
45
V
31.5
V
45
V
2.0
A
50
A
0.49
VF Max
0.33
0.45
V
0.30
IR
CJ
R(JA)
R(JC)
TSTG
TJ
0.2
40.0
130
75
25
pF
°C /W
-55 to +150
°C
-55 to +150
°C
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C. Board Mounted
-1-
mA
SB2P45-41
RATING AND CHARACTERISTIC CURVES (SB2P45-41)
2.0
1.0
Single Phase Half Wave
60Hz Resistive or
inductive Load
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
1
LEAD TEMPERTURE,(℃)
40
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
60
8.3ms Single Half
Sine-Wave (JEDEC
Method)
0.5
0.7
9
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
80
3
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
-2-
SB2P45-41
Marking and packaging illustration
1、Marking
A
SB2P45
PY 41
B
C
SYMBOL
A
B
C
Explanation
Color Band Denotes Cathode
Product Name
Trademark
2、Packaging
ITEM
SYMBOL
SPECIFICATIONS
SPECIFICATIONS
(mm)
(inch)
Component alignment
Z
1.2max
0.048max
Tape width
T
6.0±0.4
0.2±0.016
Exposed adhesive
E
0.8max
0.032max
Body eccentricity
|L1-L2|
1.0max
0.040max
Component
A
5.0±0.5
0.2±0.02
Inner tap
B
52.0~53.5
2.06~2.11
NOTE:
Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch)
-3-
很抱歉,暂时无法提供与“SB2P45-41”相匹配的价格&库存,您可以联系我们找货
