HER108GR
HER108GR
    PINGWEI(平伟)
    DO-41(DO-204AL)
    HER108GR
HER108GR 数据手册
HER101GR THRU HER108GR HER101GR THRU HER108GR 1.0AMP. GLASS PASSIVATED HIGH EFFICIENT RECTIFIERS DO-41 FEATURE .Low leakage .Low forward voltage drop .High current capability .High surge capability .High reliability .High temperature soldering guaranteed 260°C /10sec / 0.375" lead length at 5 lbs tension 1.0(25.4) MIN. .110(2.8) .080(2.0) + .205(5.2) .166(4.2) MECHANICAL DATA - .032(0.8) .025(0.65) 1.0(25.4) MIN. .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy(free halogen) .Polarity: color band denotes cathode DIA. DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% SYM BOL Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length VRRM VRMS VDC HER HER HER HER HER HER HER HER 101G 102G 103G 104G 105G 106G 107G 108G R R R R R R R R 50 100 200 300 400 600 800 1000 V 35 70 140 210 280 420 560 700 V 50 100 200 300 400 600 800 1000 V units IF(AV) 1.0 A IFSM 30 A Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous forward Voltage at 1.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TJ =25°C @TJ =125°C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Typical Thermal Resistance (Note 3) Storage Temperature Operation Junction Temperature VF 1.0 1.3 1.7 5.0 IR µA 100.0 trr CJ R(JA) R(JL) TSTG TJ 50 75 8 75 25 nS pF °C/W -55 to +150 °C -55 to +150 °C Note:1. Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 3. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. -1- V HER101GR THRU HER108GR RATING AND CHARACTERISTIC CURVES (HER101GR THRU HER108GR) Single Phase Half Wave 60Hz Resistive or inductive Load 50 V30 0V FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 0V 40 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 4 1.0 8 2.2 LEAD TEMPERTURE,(℃) INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT FIG.4-TYPICAL REVERSE CHARACTERISTICS 8.3ms Single Half Sine-Wave (JEDEC Method) NUMBER OF CYCLES AT 60Hz INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) V 00 10 0V 60 TJ=125℃ TJ=100℃ PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERSITIC 50 Ω NONINDUCTIVE (+) 25Vdc (approx) (-) TJ=25℃ 10 Ω NONINDUCTIVE (-) PULSE GENERATOR (NOTE 2) 1Ω (NOTE 1) NON- OSCILOSCOPE INDUCTIVE NOTES:1. Rise Time=7ns max, Input Impedance= 1 megohm.22pF. 2. Rise Time=10ns max, Souce Impedance= 50 ohms. -2- (+) HER101GR THRU HER108GR Marking and packaging illustration 1、Marking A HER10XGR B PY C SYMBOL A Explanation Color Band Denotes Cathode B Product Name C Trademark 2、Packaging ITEM SYMBOL SPECIFICATIONS SPECIFICATIONS (mm) (inch) Component alignment Z 1.2max 0.048max Tape width T 6.0±0.4 0.236±0.016 Exposed adhesive E 0.8max 0.032max Body eccentricity |L1-L2| 1.0max 0.040max Component A 5.0±0.5 0.2±0.02 Inner tap B 52.0~53.5 2.05~2.11 NOTE: Each component lead shall be sandwiched between tapes for a minimum of 2.5mm(0.1inch) -3-
HER108GR
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
HER108GR 价格&库存
很抱歉,暂时无法提供与“HER108GR”相匹配的价格&库存,您可以联系我们找货
