BZX85B16V
BZX85B16V
    LGE(鲁光)
    DO-41(DO-204AL)
    独立式 耐压:16V 电流:0.5UA@12V
BZX85B16V 数据手册
BZX85B Series Silicon Zener Diodes VZ : 2.4 - 220 Volts PD : 1.3 Watts Features — — — — — DO-41 Complete Voltage Range 2.4 to 220 Volts High peak reverse power dissipation High reliability Low leakage current Pb / RoHS Free .034(0.9) 1.0(25.4) MIN Mechanical Data — — — — — — DIA. .028(0.7) .205(5.2) .165(4.2) Case : DO-41 Molded plastic Epoxy : UL94V-0 rate flame retardant Lead : Axial lead solderable per MIL-STD-202, method 208 guaranteed Polarity : Color band denotes cathode end Mounting position : Any Weight : 0.34 gram .107(2.7) DIA .080(2.0) 1.0(25.4) MIN Dimensions in inches and (millimeters) MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit DC Power Dissipation at T L = 50 °C (Note1) PD 1.3 W Maximum Forward Voltage at IF = 200 mA VF 1.2 V RӨJA 130 K/W Junction Temperature Range TJ - 65 to + 200 °C Storage Temperature Range TSTG - 65 to + 200 °C Maximum Thermal Resistance Junction to Ambient Air (Note2) Notes : (1) TL = Lead temperature at 3/8 " (9.5mm) from body (2) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case. Fig. 1 POWER TEMPERATURE DERATING PD, MAXIMUM DISSIPATION (WATTS) 1.5 L = 3/8" (9.5mm) 1.2 0.9 0.6 0.3 0 ht t p : // Revision:20170701-P1 25 50 75 100 125 150 175 TL, LEAD TEMPERATURE (°C) www.lgesem i .c o m 200 mail:lge@lgesemi.com BZX85B Series Silicon Zener Diodes ELECTRICAL CHARACTERISTICS TYPE BZX85B2V4 BZX85B2V7 BZX85B3V0 BZX85B3V3 BZX85B3V6 BZX85B3V9 BZX85B4V3 BZX85B4V7 BZX85B5V1 BZX85B5V6 BZX85B6V2 BZX85B6V8 BZX85B7V5 BZX85B8V2 BZX85B9V1 BZX85B10V BZX85B11V BZX85B12V BZX85B13V BZX85B15V BZX85B16V BZX85B18V BZX85B19V BZX85B20V BZX85B22V BZX85B24V BZX85B27V BZX85B30V BZX85B33V BZX85B36V BZX85B39V BZX85B43V BZX85B47V BZX85B51V BZX85B56V BZX85B62V BZX85B68V BZX85B75V BZX85B82V BZX85B91V BZX85B100V BZX85B110V (Rating at 25 °C ambient temperature unless otherwise specified) Nominal Zener Maximum Zener Maximum Reverse Maximum DC Voltage IZK Leakage Current IR @ V R Zener Current IZM VZ @ IZT IZT ZZT @ IZT Impedance ZZK @ IZK (V) (mA) (Ω) (Ω) (mA) (µA) (V) (mA) 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 19 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 150 160 180 200 220 80 80 80 80 70 60 50 45 45 45 35 35 35 25 25 25 20 20 20 15 15 15 15 10 10 10 8.0 8.0 8.0 8.0 6.0 6.0 4.0 4.0 4.0 4.0 4.0 4.0 2.7 2.7 2.7 2.7 2.0 2.0 2.0 1.5 1.5 1.5 1.5 20 20 20 20 20 15 13 13 10 7.0 4.0 3.5 3.0 5.0 5.0 7.0 8.0 9.0 10 15 15 20 20 24 25 25 30 30 35 40 50 50 90 115 120 125 130 135 200 250 350 450 550 700 1000 1100 1200 1900 1500 400 400 400 400 500 500 500 500 500 400 300 300 200 200 200 200 300 350 400 500 500 500 550 600 600 600 750 1000 1000 1000 1000 1000 1500 1500 2000 2000 2000 2000 3000 3000 3000 4000 4500 5000 6000 6500 7000 9990 8000 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 150 150 100 40 20 10 3.0 3.0 1.0 1.0 1.0 50 50 50 50 50 50 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.5 2.0 3.0 4.0 4.5 6.2 6.8 7.5 8.2 9.1 10 11 12 13 14 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 150 167 410 370 340 320 290 280 250 215 200 190 170 155 140 130 120 105 97 88 79 71 66 62 58 56 52 47 41 36 33 30 28 26 23 21 19 16 15 14 12 10 9.4 8.6 7.8 7.0 6.4 5.8 5.2 4.7 4.5 BZX85B120V BZX85B130V BZX85B150V BZX85B160V BZX85B180V BZX85B200V BZX85B220V Notes : (1) The type number listed have a standard tolerance on the nominal zener voltage of ± 2.0%. (2) " BZX " will be omitted in marking on the diode ht t p : // Revision:20170701-P1 www.lgesem i .c o m mail:lge@lgesemi.com
BZX85B16V
物料型号:BZX85B Series(硅齐纳二极管)
器件简介:BZX85B系列是一系列硅齐纳二极管,符合RoHS标准,具有2.4至220伏的完整电压范围,高峰值反向功率耗散,高可靠性,低漏电电流,并且不含铅。
引脚分配:采用DO-41封装,轴向引脚,色带表示阴极端,任何位置都可安装。
参数特性:包括工作电压、最大正向电压、最大热阻、结温范围等,具体数值依据不同型号有所不同。
功能详解:文档提供了功率温度降额曲线图,显示了在不同引脚温度下,器件可承受的最大耗散功率。
应用信息:适用于需要电压稳定和过压保护的电路。
封装信息:DO-41塑封,符合UL94V-0阻燃等级,重量约0.34克。
BZX85B16V 价格&库存
很抱歉,暂时无法提供与“BZX85B16V”相匹配的价格&库存,您可以联系我们找货
