SR160-TB
SR160-TB
    GDGROUP(台湾固锝)
    DO-41(DO-204AL)
    电压:60V 电流:1A
SR160-TB 数据手册
SR120 thru SR1200 Schottky barrier Rectifiers Reverse Voltage 20 to 200 Volts Forward Current 1.0 Amperes Features ◆ Metal-Semiconductor junction with guardring ◆ Epitaxial construction ◆ Low forward voltage drop ◆ High current capability ◆ The plastic material carries UL recognition 94V-0 ◆ For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Mechanical Data ◆Case: JEDEC DO-204AL(DO-41)/A-405 molded plastic ◆ Polarity : Color band denotes cathode ◆Weight : DO-41 - 0.012 ounce, 0.33 gram A-405 - 0.008 ounce, 0.22 gram ◆ Mounting position : Any Maximum Ratings and Electrical Characteristics Ratings at 25oC ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20% Symbols SR 120 SR 130 SR 140 SR 150 SR 160 SR 170 SR 180 SR 190 SR 1100 SR 1150 SR 1200 Unit Maximum repetitive peak reverse voltage V RRM 20 30 40 50 60 70 80 90 100 150 200 Volts Maximum RMS voltage V RMS 14 21 28 34 42 49 56 63 70 105 140 Volts Maximum DC blocking voltage to V DC 20 30 40 50 60 70 80 90 100 150 200 Volts Parameter Maximum average forward rectified current .375" (9.5mm) lead length@TL =100℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Maximum forward voltage at 1.0A DC Maximum average reverse current TA =25℃ at rated DC blocking voltage TA =100℃ Typical thermal resistance (Note2) I F(AV) 1.0 Amp I FSM 40 Amps VF 0.7 0.8 0.9 0.5 0.2 10.0 RQJA CJ Operating junction temperature range TJ T STG Notes: 1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 2. Thermal Resistance Junction to Lead. 0.5 IR Typical junction capacitance (Note1) Storage temperature range s 5.0 ℃/W 80 -55 to +125 mA 2.0 50.0 110 Volts PF -55 to +150 -55 to +150 ℃ ℃ RATINGS AND CHARACTERISTIC CURVES (TA:25℃ unless otherwise noted) SR120 thru SR1200 Schottky barrier Rectifiers Reverse Voltage 20 to 200 Volts Forward Current 1.0 Amperes
SR160-TB 价格&库存
很抱歉,暂时无法提供与“SR160-TB”相匹配的价格&库存,您可以联系我们找货
