TC1N4754ATB
TC1N4754ATB
    TC(德昌)
    DO-41(DO-204AL)
    39V 1W
TC1N4754ATB 数据手册
TAK CHEONG SE MI COND U C TO R 1 Watt DO-41 Hermetically Sealed Glass Zener Voltage Regulators AXIAL LEAD DO41 Absolute Maximum Ratings TA = 25°C unless otherwise noted Parameter Value Units -65 to +175 °C +175 °C Total Device Dissipation 1.0 Watt Thermal Resistance Junction to Lead 53.5 °C / W Thermal Resistance Junction to Ambient 100 °C / W Storage Temperature Range Maximum Junction Operating Temperature DEVICE MARKING DIAGRAM L 1N 47 xx T L : Logo Device Code : TC1N47xxT VZ Tolerance (T) : A = ±5% C = ±2% These ratings are limiting values above which the serviceability of the diode may be impaired. Specification Features: § § § § § § § § Zener Voltage Range 3.3 to 56 Volts Through-Hole Device Type Mounting Hermetically Sealed Glass Compression Bonded Construction Cathode Anode All External Surfaces Are Corrosion Resistant And Leads Are Readily Solderable RoHS Compliant ELECTRICAL SYMBOL Solder Hot Dip Tin (Sn) Terminal Finish Cathode Indicated By Polarity Band Electrical Characteristics TA = 25°C unless otherwise noted ZZT @ IZT IZT IZK (Ω) (mA) (mA) Max ZZK @ IZK (Ω) Max IR @ VR (µA) Max VR (Volts) 1 400 100 1 1 400 100 1 9 1 400 50 1 58 9 1 400 10 1 4.7 53 8 1 500 10 1 TC1N4733A 5.1 49 7 1 550 10 1 TC1N4734A 5.6 45 5 1 600 10 2 TC1N4735A 6.2 41 2 1 700 10 3 TC1N4736A 6.8 37 3.5 1 700 10 4 TC1N4737A 7.5 34 4 0.5 700 10 5 TC1N4738A 8.2 31 4.5 0.5 700 10 6 TC1N4739A 9.1 28 5 0.5 700 10 7 TC1N4740A 10 25 7 0.25 700 10 7.6 TC1N4741A 11 23 8 0.25 700 5 8.4 TC1N4742A 12 21 9 0.25 700 5 9.1 TC1N4743A 13 19 10 0.25 700 5 9.9 TC1N4744A 15 17 14 0.25 700 5 11.4 Device Type VZ @ IZT (Volts) Nominal TC1N4728A 3.3 76 10 TC1N4729A 3.6 69 10 TC1N4730A 3.9 64 TC1N4731A 4.3 TC1N4732A Number: DB-031 Jun 2016/ I Page 1 TC1N4728A through TC1N4761A ® ® TAK CHEONG SE MI COND U C TO R Electrical Characteristics TA = 25°C unless otherwise noted Device Type VZ @ IZT (Volts) Nominal IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (µA) Max VR (Volts) TC1N4745A 16 15.5 16 0.25 700 5 12.2 TC1N4746A 18 14 20 0.25 700 5 13.7 TC1N4747A 20 12.5 22 0.25 750 5 15.2 TC1N4748A 22 11.5 23 0.25 750 5 16.7 TC1N4749A 24 10.5 25 0.25 750 5 18.2 TC1N4750A 27 9.5 35 0.25 750 5 20.6 TC1N4751A 30 8.5 40 0.25 1000 5 22.8 TC1N4752A 33 7.5 45 0.25 1000 5 25.1 TC1N4753A 36 7 50 0.25 1000 5 27.4 TC1N4754A 39 6.5 60 0.25 1000 5 29.7 TC1N4755A 43 6 70 0.25 1500 5 32.7 TC1N4756A 47 5.5 80 0.25 1500 5 35.8 TC1N4757A 51 5 95 0.25 1500 5 38.8 TC1N4758A 56 4.5 110 0.25 2000 5 42.6 TC1N4759A 62 4.0 125 0.25 2000 5 47.1 TC1N4760A 68 3.7 150 0.25 2000 5 51.7 TC1N4761A 75 3.3 175 0.25 2000 5 56.0 VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types Notes: 1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ) The type numbers listed have a standard tolerance on the nominal zener voltage of ± 5%. Device tolerance of ±2% is indicated by a “C” instead of an “A”. 2. SPECIALS AVAILABLE INCLUDE Nominal zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery, contact you nearest Tak Cheong representative. 3. ZENER VOLTAGE (VZ) MEASUREMENT The zener voltage (VZ) is tested under pulse condition. 4. ZENER IMPEDANCE (ZZ) DERIVATION The zener impedance is derived from the 60 cycle AC voltage, which results when an AC current having an RMS value equal to 10% of the DC zener current (IZT or IZK) is superimposed on IZT or IZK. Number: DB-031 Jun 2016/ I Page 2 ® TAK CHEONG SE MI COND U C TO R Typical Characteristics 1000 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 VR = 2V 100 VR = 5V VR = 30V 0.1 1 0 20 40 60 80 100 120 140 160 180 0 200 5 10 15 20 25 Figure 1. Power Dissipation vs Ambient Temperature 50 55 60 Figure 2. Total Capacitance Valid provided leads at a distance of 0.8mm from case are kept at ambient temperature 1000 30 35 40 45 VZ - Reverse Voltage [V] Temperature [℃] 1000 Iz=1mA Iz=2mA Ta = 25℃ Ta = 25℃ Iz=5mA 100 Forward Current [mA] Differential Zener Impedance [Ω] VR = 20V 10 0.0 Iz=10mA 10 1 100 10 1 0.1 0.1 0 10 20 30 40 VZ - Reverse Voltage [V] 50 0 60 0.2 0.4 0.6 0.8 VF - Forw ard Voltage [V] 1 1.2 Figure 4. Forward Current vs. Forward Voltage Figure 3. Differential Impedance vs. Zener Voltage 1000 100 Reverse Current [mA] Reverse Current [mA] f = 1MHz Ta = 25℃ VR = 0V Total Capacitance [pF] PD-Power Passipation [W] 1.0 100 Ta = 25℃ 10 1 10 Ta = 25℃ 1 0.1 0.01 0.1 0 3 6 9 VZ - Reverse Voltage [V] 12 Figure 5. Reverse Current vs. Reverse Voltage 15 10 20 30 40 50 VZ - Reverse Voltage [V] 60 70 Figure 6. Reverse Current vs. Reverse Voltage Number: DB-031 Jun 2016/ I Page 3 ® TAK CHEONG SE MI COND U C TO R Package Outline Package Case Outline D0-41 DO-41 DIM Millimeters Inches Min Max Min Max A 0.68 0.81 0.027 0.032 B --- 4.25 --- 0.167 C 25.40 --- 1.000 --- D 2.10 2.60 0.083 0.102 Notes: . 1. DO41 polarity denoted by cathode band. Number: DB-031 Jun 2016/ I Page 4
TC1N4754ATB 价格&库存
很抱歉,暂时无法提供与“TC1N4754ATB”相匹配的价格&库存,您可以联系我们找货
